Contributing to GEF Context menu [message #82079] |
Wed, 04 June 2003 21:19 |
Originally posted by: schmerl+gef.cs.cmu.edu
I'm trying to work out how to use plugin extensions to add contributions to
the context menu that comes up in the GEF diagram. Is this possible? If so,
could someone direct me to the documentation to do it?
So far, I've tried the objectContribution extension, using edit parts as the
objectClass, and also the class of the editor that registers the context
menu, to no avail.
Any help much appreciated,
Bradley.
P.S. This is what I've tried so far:
<extension point="org.eclipse.ui.popupMenus">
<objectContribution
id="myId"
objectClass="org.eclipse.gef.editparts.AbstractGraphicalEditPart ">
</objectContribution>
</extension>
<viewerContribution id="myId"
targetID="org.eclipse.gef.examples.logicdesigner.LogicEditor ">
</viewerContribution>
</extension>
Re: Contributing to GEF Context menu [message #82110 is a reply to message #82079] |
Thu, 05 June 2003 02:28 |
There is another step required in the code that created the MenuManager.
The logic editor does not register its menus for contribution, I don't
believe.
"Bradley Schmerl" <schmerl+gef@cs.cmu.edu> wrote in message
news:bblnps$nr3$1@rogue.oti.com...
to
so,
the
> menu, to no avail.
> Bradley.
> <objectContribution
> id="myId"
> </extension>
> </extension>
Re: Contributing to GEF Context menu [message #82264 is a reply to message #82110] |
Thu, 05 June 2003 13:37 |
That's right. The constructor for org.eclipse.gef.ContextMenuProvider only
allows an EditPartViewer as a parameter. I can't find out how to set the id
for the menu (which is private to MenuManager and only seems to be settable
through construction). Is there a way to set the ID?
Bradley.
"Randy Hudson" <none@us.ibm.com> wrote in message
news:bbm9s5$1sn$1@rogue.oti.com...
> believe.
> > Hi,
> to
> so,
> the
> > menu, to no avail.
> > Bradley.
> > <objectContribution
> > id="myId"
> > </extension>
> > </extension>
Re: Contributing to GEF Context menu [message #82526 is a reply to message #82264] |
Fri, 06 June 2003 02:48 |
You do not need to set the ID. I think this is only for submenus? Use:
IWorkbenchtPartSite#registerContextMenu (ID, menu, provider);
Hey, do you Randy Pausch? He was one of my professors.
news:bbnh38$b1$1@rogue.oti.com...
id
settable
> Bradley.
Re: Contributing to GEF Context menu [message #899712 is a reply to message #899630] |
Thu, 02 August 2012 05:10 |
Karthikeyan Missing name Messages: 47 Registered: July 2011 |
Member |
Thank you for your reply. Sorry myself new to this. Kindly clarify below doubts.
In buildContextmenu in mycontextProvider, how to add palette tools into that.
In plugin.xml
<command
commandId="someCommandId"
style="push">
</command>
what commandId need to be given and from where. And how it is being used.
Note: My requirement is to bring Palette tools into the GEF editor on user mouse click, as like GMF and graphiti ie show in attached image. Kindly refer it. Is it possible?
Thanks & Regards,
Karthikeyan.B
[Updated on: Thu, 02 August 2012 06:45] Report message to a moderator
FUDForum. Page generated in 0.03729 seconds
