Home » Archived » M2M (model-to-model transformation) » [ATL] uml2bpel problem
[ATL] uml2bpel problem [message #81988] Thu, 22 May 2008 05:40 Go to next message
Originally posted by: hr_mi.live.cn
Hi everyone,
I want to make a transformation from uml to bpel ,my code is as following :
--@atlcompiler atl2006
module uml2bpel; -- Module Template
create OUT : BPEL from IN : UML;
rule process{
from
u : UML!Activity
to
p : BPEL!Process(
exitOnStandardFault <- true,
expressionLanguage <- '',
queryLanguage <- 'urn:oasis:names:tc:wsbpel:2.0:sublang:xpath1.0',
suppressJoinFailure <- true,
targetNamespace <- 'edu.xidian.ictt.webservices.bpelmodeling',
name <- u.name,
imports <- imp
imp : BPEL!Import(
location <- 'onlinesale.bpel.wsdl/',
importType <- 'http://schemas.xmlsoap.org/wsdl/',
namespace <- 'edu.xidian.ictt.webservices.bpelmodeling.wsdl'
when i debug ,it makes an error as following :
严重: Message: feature location does not exist on BPEL!Import
严重: A.main() : ??#24 null
严重: local variables = {self=uml2bpel : ASMModule}
严重: local stack = []
严重: A.__exec__() : ??#8 null
严重: local variables = {e=TransientLink {rule = 'process',
sourceElements = {u = IN!onlinesale}, targetElements = {imp =
OUT!<unnamed>, p = OUT!onlinesale}, variables = {}}, self=uml2bpel :
ASMModule}
严重: A.__applyprocess(1 : NTransientLink;) : ??#55 26:6-26:41
严重: local variables = {p=OUT!onlinesale, u=IN!onlinesale,
link=TransientLink {rule = 'process', sourceElements = {u =
IN!onlinesale}, targetElements = {imp = OUT!<unnamed>, p =
OUT!onlinesale}, variables = {}}, self=uml2bpel : ASMModule,
imp=OUT!<unnamed>}
严重: local stack = [OUT!<unnamed>]
严重:
严重: ********************************* ERROR
严重:
java.lang.Exception
at
org.eclipse.m2m.atl.engine.vm.NetworkDebugger.error(NetworkD ebugger.java:165)
at
org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:95)
at
org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:87)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.exec(ASMOperation .java:173)
at
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:143)
at
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:101)
at
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:240)
at
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:338)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.exec(ASMOperation .java:171)
at
at
at
at
org.eclipse.m2m.atl.engine.vm.ASMInterpreter.<init>(ASMInterpreter.java:299)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:169)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:111)
at org.eclipse.m2m.atl.engine.AtlLauncher.debug(AtlLauncher.jav a:105)
at
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:359)
at
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:463)
at
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.access$0(AtlR egularVM.java:445)
at
org.eclipse.m2m.atl.adt.launching.AtlRegularVM$1.run(AtlRegu larVM.java:423)
严重: null
at
org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModelElement.set(A SMEMFModelElement.java:260)
at
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:305)
at
at
at
at
at
at
at
at
at
at
at
at
ASMModule}
imp=OUT!<unnamed>}
严重:
Who can help me ??
Thanks very much!
Best whishes
Re: [ATL] uml2bpel problem [message #82017 is a reply to message #81988] Thu, 22 May 2008 12:48 Go to previous messageGo to next message
neto Mising name is currently offline neto Mising nameFriend
Member
Hie
Verify in your BPEL metamodel if the element Import has the field
location. In the metamodel this field can have a diferent name, maybe
locationName, loc, so on.
i hope this information help you.
Re: [ATL] uml2bpel problem [message #83102 is a reply to message #82017] Sat, 31 May 2008 06:34 Go to previous messageGo to next message
Netuh 写道:
> Hie
Hi Netuh,
Thanks for your help,I have solved it .
Re: [ATL] uml2bpel problem [message #84821 is a reply to message #83102] Thu, 19 June 2008 17:40 Go to previous messageGo to next message
Originally posted by: jihed.touzi.enstimac.fr
Hello to All of you;
I encounter the same problem..
Can i know how you have solved it ?
Thanks.
unique a écrit :
> Netuh 写道:
>> Hie
> Hi Netuh,
[ATL] internal error in Model2BPEL transformation [message #84839 is a reply to message #84821] Fri, 20 June 2008 17:27 Go to previous messageGo to next message
Hi to all,
I encounter an internal error like this :
An internal error occurred during: "Launching SOA2BPEL".
eObject cannot be null in getNamespaceMap()
I don't understand..
But the Big question is that the BPEL metamodel is an imbricated
metamodel, it contains WSDL and XSD metamodel..
i think that to call for example a WSDL element in the BPEL metamodel
we have to do that :
BPEL!"wsdl::nameOfTheElement"
i do that but i obtain the internal error mentionned before..
Some one can help me ??
thank you...
[ATL] internal error in Model2BPEL transformation [message #85688 is a reply to message #84839] Wed, 02 July 2008 08:42 Go to previous message
> Hi to all,
> thank you...
Previous Topic:EMF Changeable problem
Next Topic:UML2OWL - UML 2.0 sample file
Current Time: Sat Feb 29 08:26:27 GMT 2020
Powered by FUDForum. Page generated in 0.06171 seconds
