Home » Archived » M2M (model-to-model transformation) » [ATL] uml2 models transformation
[ATL] uml2 models transformation [message #81785] Wed, 21 May 2008 03:42 Go to next message
Geam Carlos is currently offline Geam CarlosFriend
Hi everybody,
I'm having a problem at the moment to assign the element namespace to
package element within the rule ATL, for example, set so the ATL rules
with uml1.4:
rule MergePackage {
from s : UML2!Package
to t : UML2!Package mapsTo s (
name <- s.name,
namespace <- s.namespace
But now the rules ATL with uml2 (version 1.0) can not assign.
Someone could help me, please?
[ATL] Re : uml2 models transformation [message #81801 is a reply to message #81785] Wed, 21 May 2008 06:25 Go to previous messageGo to next message
Originally posted by: frederic_thomas_fr.yahoo.fr
Hi Carlos,
ATL can't match the namespace<-s.namespace statement because in the UML
2.0 metamodel, the namespace feature is derived, hence you can only read
it and not write it.
If you want match the package namespace, you must use the
s.owningPackage feature which is a subset of the namespace set.
Best regards
Frédéric
Geam Carlos a écrit :
> Hi everybody,
> with uml1.4:
> rule MergePackage {
> name <- s.name,
Re: [ATL] Re : uml2 models transformation [message #81914 is a reply to message #81801] Wed, 21 May 2008 12:16 Go to previous messageGo to next message
Hello Frédéric, thank for your attention.
I changed to the feature owningPackage, but there was the error that does
not exist on UML2! Package.:
****** BEGIN Stack Trace
message: owningPackage feature does not exist on UML2! Package
I am using this API: eclipse-uml2-1.1.1.jar.
I have the same problem for other elements (Class, Property ,...), the
rules ATL have that to inform the namespace of each element, that is, who
owns the element.
Frédéric, you can help me! Very grateful.
[ATL] Re : uml2 models transformation [message #82151 is a reply to message #81801] Mon, 26 May 2008 07:13 Go to previous message
Hi cralos,
I have not tried yet but if the "s.owningPackage" doesnot work, the
"s.nestingPackage" should (this is also a subset of the namespace feature).
To solve such problem by your own, you have just to look at the "package
" metaclass description in the UML2 superstructure.
Fred
Frédéric Thomas a écrit :
> Hi Carlos,
> Best regards
> Frédéric
>> Hi everybody,
>> with uml1.4:
>> rule MergePackage {
>> name <- s.name,
Previous Topic:[ATL] Re: Two metamodels into one
Next Topic:Problem with simple transformation
Current Time: Sun Jun 16 12:40:47 GMT 2019
Powered by FUDForum. Page generated in 0.01417 seconds
