BPEL Designer prob [message #7291] |
Wed, 11 April 2007 20:02 |
Originally posted by: alexandre_boudreault.hotmail.com
Here's my situation :
I have Eclipse sdk 3.2.2 and i installed the BPEL visual designer via the
update site at http://download.eclipse.org/technology/bpel/update-site/
The installation complete with no prob, eclipse restart and then... nothing.
- I don't have any option to create a BPEL project
- I don't have any option to create a BPEL file
- When i open a .bpel file, i got a design view that show me a tree of my
bpel process.
Any clues on how to get the visuel bpel designer ?
Re: BPEL Designer prob [message #7305 is a reply to message #7291] |
Wed, 11 April 2007 20:26 |
Michal Chmielewski Messages: 58 Registered: July 2009 |
Member |
Have come accross something similar recently too. Read below.
-m
--- snip ----
1) I've downloaded virgin 3.2.2 and installed the plugins from the
update site no problem.
2) If you are developing with them and have the source checked out
that's another matter.
3) Please check JDK, it should be 5.0
4) Go to the plugin registry view. It's Window->Show View ...->
Plugin-Registry make sure that these plugins are all there.
-m
Mohamed Amine Belkoura wrote:
> Hi Michal
> I am on Windows XP.
> I have tried -clean, with same results.
> One think I have noticed. When I go to Help->about eclipse->about
eclipse SDK plugins, I see only
> org.eclipse.bpel.common.ui
> org.eclipse.bpel.common.model
> while in the plugin directory, I have the whole five that I listed
before.
> I did not understand how to see if some plugins are active or no.
> What I did , is go to plugins developpement perspective, then plugins
tab, and there I can see all 5.
> any other idea?
> Amine
> ----- Original Message ----
> From: Michal Chmielewski <michal.chmielewski@oracle.com>
> To: BPEL Designer project developer discussions. <bpel-dev@eclipse.org>
> Sent: Monday, April 9, 2007 7:21:31 PM
> Subject: Re: [bpel-dev] Can not see new project-> BPEL option
> Yikes, should not happen.
> I just did what you did, and it seems to be working ok. Downloaded,
3.2.2 (exact version of what you have), installed from the update site.
> Can you look at the plugins view and see which ones are not active ?
> Sometimes starting eclipse with -clean works, so eclipse -clean
> What platform are you using ?
> -m
>> Hi all,
>> I installed a fresh copy of eclipse SDK3.2.2 (Version: 3.2.2 Build
>> I then installed the M2 build of BPEL, using the instructions from
>> The install when fine, but when I restarted Eclipse, I could not
fing the wizard (new->project->BPEL) at all.
>> I double checked in the plugin directory, and I could see the following:
>> org.eclipse.bpel.common.model_0.2.0.jar
>> org.eclipse.bpel.common.ui_0.2.0.jar
>> org.eclipse.bpel.model_0.2.0.jar
>> org.eclipse.bpel.ui_0.2.0.jar
>> and the directory org.eclipse.bpel.runtimes_0.2.0
>> Any idea what I am doing wrong?
>> Thanks
>> Amine
> bpel process.
FUDForum. Page generated in 0.02301 seconds
