Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo+hibernate]
Re: [Teneo+hibernate] [message #81676 is a reply to message #81661] |
Wed, 02 May 2007 07:52 |
It seems that the problem is in Hibernate. Possibly the mapping logic of Teneo can be adapted to
give hibernate the right hints.
Can you try with log4j set to debugging? Then you can see how hibernate creates the tables in the
beginning, maybe this gives some more information.
You can manually change the mapping and see what works for you. If you post the updated mapping then
I can see how to adapt the mapping logic.
gr. Martin
wolf_roma wrote:
> Hello.
> I'm use emf 2.3.0.v200703291501, teneo 0.8.0.v200704230019, hibernate 3.2,
> database MySQL.
> I convert XSD into Ecore model. After
> Teneo maps Ecore into database wrong.
> Wrong column types.
> First Problem:
> in XSD:
> <xs:simpleType name="Count2Type">
> <xs:annotation>
> <xs:documentation>Number. form 1. to 2 digit. </xs:documentation>
> </xs:annotation>
> <xs:restriction base="CategoryCust:IntegerCategoriesCust">
> <xs:totalDigits value="2"/>
> <xs:minInclusive value="1"/>
> </xs:restriction>
> </xs:simpleType>
> in DataBase type of column: DECIMAL(2,2) (should be DECIMAL(2,0))
> I take xml mapping (hbds.getMappingXML();) from datastore
> <property name="subLineNumber" lazy="false" insert="true" update="true"
> not-null="false" unique="false" type="java.math.BigInteger">
> <column not-null="false" unique="false" name="`sublinenumber`"
> precision="2"/>
> </property>
> Second Problem:
> in XSD:
> <xs:simpleType name="Code2Type">
> <xs:annotation>
> <xs:documentation>Code. 2 symbols</xs:documentation>
> </xs:annotation>
> <xs:restriction base="CategoryCust:CodeCategoriesCust">
> <xs:length value="2"/>
> </xs:restriction>
> </xs:simpleType>
> in DataBase type of column: varchar(1) (should be varchar(2)) but not for
> every column;
> in xml mapping:
> <property name="goodsStatus" lazy="false" insert="true" update="true"
> not-null="false" unique="false" type="java.lang.String">
> <column not-null="false" unique="false" name="`goodsstatus`"
> length="2"/>
> </property>
> Where is problem in Teneo or Hibernate?
> P.S All types in Ecore equal to all types in XSD.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo+hibernate] [message #81690 is a reply to message #81676] |
Wed, 02 May 2007 08:53 |
Roman Bliznets Messages: 75 Registered: July 2009 |
Member |
Ok, I set Log4j in debug mode;
First problem:
It solved if I manual add attribute: scale="0";
Second Problem:
in xml mapping:
<column not-null="false" unique="false" name="`goodsstatus`" length="2"/>
</property>
<property name="repairStatus" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`repairstatus`"
length="2"/>
</property>
from log:
5157 [main] DEBUG org.hibernate.tool.hbm2ddl.SchemaUpdate - create table
`documentbasetype` (e_id bigint not null auto_increment, `dtype`
varchar(255) not null, e_version integer not null, `prdocumentname`
varchar(250), `prdocumentnumber` varchar(50), `prdocumentdate` varchar(255),
`complationauthoritydate` varchar(255), `linenumber` numeric(2,0),
`sublinenumber` varchar(2), `documentmodecode` varchar(4), `informationcode`
varchar(2), `perioddate` varchar(255), `conditiondate` varchar(255),
`saledate` varchar(255), `presentingdate` varchar(255), `goodsstatus`
varchar(1), `repairstatus` bit, `documentbeginactionsdat` varchar(255),
`documentendactionsdate` varchar(255), `organizationname` varchar(150),
`presentinglackingdate` varchar(255), `presenteddocumentmodecode`
varchar(4), `actnumber` varchar(50), `actdate` varchar(255),
`privelegedocumentmodecode` varchar(2), `excisemarkingmodecodetype`
varchar(1), `customspaymentmodecodetyp` varchar(2), `symbolsublinenumber`
varchar(1), `supplystatus` varchar(2), `exportdate` varchar(255),
`esadoutpresenteddocume_id` bigint, `esadoutpresenteddocum_idx` integer,
`esadcontractlisttype_a_id` bigint, `esadcontractlisttype__idx` integer,
econtainer_class varchar(255), e_container varchar(255),
e_container_featureid integer, primary key (e_id))
`goodsstatus` varchar(1) - should be varchar(2)
`repairstatus` bit - it big wrong :), should be varchar(2)
Another fields right;
May be I have to use definite Hibernate?
Can I take Teneo mapping and use it without Teneo? (How to do?)
Should I post in Hibernate.org about the bug?
you wrote:
> Teneo can be adapted to give hibernate the right hints.
> creates the tables in the beginning, maybe this gives some more
> information.
> post the updated mapping then I can see how to adapt the mapping logic.
> gr. Martin
Re: [Teneo+hibernate] [message #81705 is a reply to message #81690] |
Wed, 02 May 2007 09:05 |
The repairstatus is even more strange, is there by accident another eclass which also has a
repairstatus which is of another type (boolean)?
You can use the hbm in combination with Teneo. In this case Teneo will not do any automatic mapping
but will use the hbm file. See the option: PersistenceOptions.USE_MAPPING_FILE, here:
http://www.elver.org/hibernate/options.html
I would upgrade to the latest version of hibernate. Although I would surprised if that is the issue
here.
Can you try a join table mapping strategy? See the option:
PersistenceOptions.INHERITANCE_MAPPING
gr. Martin
> First problem:
> Second Problem:
> in xml mapping:
> </property>
> length="2"/>
> </property>
> from log:
> you wrote:
>> Hi,
>> information.
>> gr. Martin
The Netherlands
Re: [Teneo+hibernate] [message #81766 is a reply to message #81705] |
Wed, 02 May 2007 15:06 |
Member |
I'm try to use PersistenceOptions.INHERITANCE_MAPPING and it solve my
problem with columnb types; (Same parent class has two children class with
identical filednames.)
I have another problem:
Hibernate: insert into goodsDescription (`processinggoodstype_go_id`,
`processinggoodstype_g_idx`, elt) values (?, ?, ?)
10781 [main] WARN org.hibernate.util.JDBCExceptionReporter - SQL Error:
1364, SQLState: HY000
10781 [main] ERROR org.hibernate.util.JDBCExceptionReporter - Field
'goodsitembasetype_good_id' doesn't have a default value
List of varchar(250) (goodsDescription) is used in some comlex types;
In sql:
create table goodsDescription (
`goodsitembasetype_good_id` bigint not null,
elt varchar(255),
`goodsitembasetype_goo_idx` integer not null,
`goodsbasetype_goodsdes_id` bigint not null,
`goodsbasetype_goodsde_idx` integer not null,
`goodsgroupdescriptiont_id` bigint not null,
`goodsgroupdescription_idx` integer not null,
`processinggoodstype_go_id` bigint not null,
`processinggoodstype_g_idx` integer not null,
primary key (`processinggoodstype_go_id`,
`processinggoodstype_g_idx`)
What me to do?
Most probably that this is Hibernate mistake, but
I don't understand how fix it...
May be i send you my project?
Re: [Teneo+hibernate] [message #81780 is a reply to message #81766] |
Wed, 02 May 2007 15:15 |
Can you just send me the ecore and the hbm files? This should be enough for me to look at.
gr. Martin
> In sql:
> elt varchar(255),
> What me to do?
The Netherlands
Re: [Teneo+hibernate] [message #605185 is a reply to message #81661] |
gr. Martin
wolf_roma wrote:
> Hello.
> database MySQL.
> Wrong column types.
> First Problem:
> in XSD:
> <xs:annotation>
> </xs:annotation>
> </xs:restriction>
> </xs:simpleType>
> precision="2"/>
> </property>
> Second Problem:
> in XSD:
> <xs:annotation>
> </xs:annotation>
> </xs:restriction>
> </xs:simpleType>
> every column;
> in xml mapping:
> length="2"/>
> </property>
The Netherlands
Re: [Teneo+hibernate] [message #605189 is a reply to message #81676] |
Member |
First problem:
Second Problem:
in xml mapping:
</property>
length="2"/>
</property>
from log:
you wrote:
> information.
> gr. Martin
Re: [Teneo+hibernate] [message #605191 is a reply to message #81690] |
here.
gr. Martin
> First problem:
> Second Problem:
> in xml mapping:
> </property>
> length="2"/>
> </property>
> from log:
> you wrote:
>> Hi,
>> information.
>> gr. Martin
The Netherlands
Re: [Teneo+hibernate] [message #605203 is a reply to message #81705] |
Member |
In sql:
elt varchar(255),
What me to do?
Re: [Teneo+hibernate] [message #605206 is a reply to message #81766] |
gr. Martin
> In sql:
> elt varchar(255),
> What me to do?
The Netherlands
Current Time: Fri Apr 19 04:56:43 GMT 2024
Powered by FUDForum. Page generated in 0.03999 seconds
