Names of the pins in instances of CallBehaviorAction [message #743426] |
Fri, 21 October 2011 13:13 |
Hello
I am bothering the forum again , hope you can help me. I have a model with two activities (mainActivity and secondaryActivity). secondaryActivity has two parameter nodes (instances of ActivityParameterNode) called "input" and "output". Now, when I instantiate the meta-class CallBehaviorAction in mainActivity and indicate Papyrus that such action should be assigned the behavior secondaryActivity Papyrus adds an action to mainActivity that calls secondaryActivity, but whose pins are called "inputParameter" and "outputParameter". What I want is that the pins of the instance of CallBehaviorAction in mainActivity have the same name as the corresponding parameter nodes in secondaryActivity ("input" and "output"). How can I achieve this in Papyrus without having to rename the pins manually? Is it possible to do this in Papyrus? As far as I remember, it was possible in Enterprise Architect.
Thanks in advance for your help. Kindest regards.
/T
/TB
FUDForum. Page generated in 0.03543 seconds
