Problem with simple transformation [message #81398] |
Thu, 15 May 2008 17:27 |
Originally posted by: jobamo.gmail.com
Hi!
I'm writing my first ATL's transformation for a project degree.
I have this problem: I'm trying to execute this transformation:
-- @atlcompiler atl2006
module ecore2maude; -- Module Template
create OUT : Maude from IN : Ecore;
rule clase2sort {
from
c : Ecore!EClass
to
s : Maude!Sort(
name <- c.name
and it produces an error:
GRAVE: ****** BEGIN Stack Trace
GRAVE: message: ERROR: could not find operation allInstancesFrom on
Ecore!EClass having supertypes: [Ecore!EClassifier, OclType, OclAny]
(including Java operations)
GRAVE: A.main() : ??#22 null
GRAVE: local variables = {self=ecore2maude : ASMModule}
GRAVE: local stack = []
GRAVE: A.__matcher__() : ??#1 null
GRAVE: A.__matchclase2sort() : ??#4 null
GRAVE: ****** END Stack Trace
INFO: Execution terminated due to error (see launch configuration to allow
continuation after errors).
GRAVE: ERROR: could not find operation allInstancesFrom on Ecore!EClass
having supertypes: [Ecore!EClassifier, OclType, OclAny] (including Java
operations)
java.lang.RuntimeException: ERROR: could not find operation
allInstancesFrom on Ecore!EClass having supertypes: [Ecore!EClassifier,
OclType, OclAny] (including Java operations)
at
org.eclipse.m2m.atl.engine.vm.SimpleDebugger.error(SimpleDeb ugger.java:185)
at
org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:85)
at
org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:81)
at
org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModelElement.invok e(ASMEMFModelElement.java:671)
at
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:230)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.exec(ASMOperation .java:161)
at
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:133)
at
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:91)
at
at
at
at
at
org.eclipse.m2m.atl.engine.vm.ASMInterpreter.<init>(ASMInterpreter.java:289)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:155)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:105)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:81)
at
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:351)
at
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:453)
at
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.launch(AtlReg ularVM.java:425)
at
org.eclipse.m2m.atl.adt.launching.AtlLaunchConfigurationDele gate.launch(AtlLaunchConfigurationDelegate.java:35)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:766)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:608)
at
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:899)
at
org.eclipse.debug.internal.ui.DebugUIPlugin$7.run(DebugUIPlu gin.java:1102)
I'm trying to do:
rule clase2sort {
from
c : Ecore!EClassifier(c.oclIsTypeOf(Ecore!EClass))
to
s : Maude!Sort(
name <- c.name
and it works!!
Where is the problem?
Anybody can help me??
Thanks!!
Re: [ATL] Problem with simple transformation [message #82066 is a reply to message #81959] |
Thu, 22 May 2008 16:45 |
Hi Netuh,
I have installed only an "ATL Ready-To-Use Bundle" (ATL Bundle 2.0
Standard Version). Do I need to install something else?
And I think that the metamodel works because it is tested with others
examples.
Thanks for try to help me
FUDForum. Page generated in 0.02891 seconds
