Can't run tomcat 7 on eclipse helios 3.6 [message #741563] |
Wed, 19 October 2011 16:47 |
Mahmoud Saleh Messages: 23 Registered: September 2011 |
Junior Member |
i have eclipse helios 3.6.1 with WTP 3.1.2
and i downloaded Tomcat 7.0.22 and added it to servers
but when i tried to run my application (BTW my application uses servlet-api 3.0.1,jsp-api 2.2.1,el-api 2.2.2, JSF 2.1, Maven 2 as build tool) on server, i got the following exception:
WARNING: Unable to load class [Testing.MyTest] to check against the @HandlesTypes annotation of one or more ServletContentInitializers.
java.lang.ClassNotFoundException: Testing.MyTest
at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1678)
at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1523)
at org.apache.catalina.startup.ContextConfig.checkHandlesTypes(ContextConfig.java:2006)
at org.apache.catalina.startup.ContextConfig.processAnnotationsStream(ContextConfig.java:1969)
at org.apache.catalina.startup.ContextConfig.processAnnotationsJndi(ContextConfig.java:1914)
at org.apache.catalina.startup.ContextConfig.processAnnotationsJndi(ContextConfig.java:1905)
at org.apache.catalina.startup.ContextConfig.processAnnotationsUrl(ContextConfig.java:1828)
at org.apache.catalina.startup.ContextConfig.webConfig(ContextConfig.java:1295)
at org.apache.catalina.startup.ContextConfig.configureStart(ContextConfig.java:896)
at org.apache.catalina.startup.ContextConfig.lifecycleEvent(ContextConfig.java:322)
at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:119)
at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:90)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5103)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:148)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:812)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:787)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:607)
at org.apache.catalina.startup.HostConfig.deployDescriptor(HostConfig.java:633)
at org.apache.catalina.startup.HostConfig.deployDescriptors(HostConfig.java:558)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:468)
at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1329)
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:311)
at org.apache.catalina.util.LifecycleBase.setStateInternal(LifecycleBase.java:389)
at org.apache.catalina.util.LifecycleBase.setState(LifecycleBase.java:334)
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:1041)
at org.apache.catalina.core.StandardHost.startInternal(StandardHost.java:774)
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:1033)
at org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:291)
at org.apache.catalina.core.StandardService.startInternal(StandardService.java:443)
at org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:727)
at org.apache.catalina.startup.Catalina.start(Catalina.java:621)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:322)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:450)
Oct 19, 2011 6:32:12 PM org.apache.catalina.startup.ContextConfig checkHandlesTypes
WARNING: Unable to load class [com.sun.jmx.mbeanserver.MBeanInstantiatorImpl] to check against the @HandlesTypes annotation of one or more ServletContentInitializers.
java.lang.IncompatibleClassChangeError: Implementing class
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClassCond(ClassLoader.java:632)
at java.lang.ClassLoader.defineClass(ClassLoader.java:616)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:141)
at org.apache.catalina.loader.WebappClassLoader.findClassInternal(WebappClassLoader.java:2820)
at org.apache.catalina.loader.WebappClassLoader.findClass(WebappClassLoader.java:1150)
at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1645)
at org.apache.catalina.startup.ContextConfig.processAnnotationsJar(ContextConfig.java:1858)
at org.apache.catalina.startup.ContextConfig.processAnnotationsUrl(ContextConfig.java:1826)
at org.apache.catalina.startup.ContextConfig.processAnnotations(ContextConfig.java:1812)
at org.apache.catalina.startup.ContextConfig.webConfig(ContextConfig.java:1306)
WARNING: Unable to load class [com.sun.jmx.mbeanserver.RepositorySupport] to check against the @HandlesTypes annotation of one or more ServletContentInitializers.
so any ideas why i get this exception ?
[Updated on: Wed, 19 October 2011 16:48] Report message to a moderator
Re: Can't run tomcat 7 on eclipse helios 3.6 [message #741647 is a reply to message #741563] |
Wed, 19 October 2011 19:00 |
Larry Isaacs Messages: 1354 Registered: July 2009 |
WTP 3.1.x works with Eclipse 3.5.x. You will need WTP 3.2.x to work
with Eclipse 3.6.x. It's hard to predict what will or won't work
correctly with Eclipse 3.6.x and WTP 3.1.x.
My response to your earlier post gives the URL you need to use for WTP's
Helios update site.
Larry
> and i downloaded **Tomcat 7.0.22** and added it to servers
> **servlet-api 3.0.1**,**jsp-api 2.2.1**,**el-api 2.2.2**, **JSF 2.1**,
> **Maven 2** as build tool) on server, i got the following exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> checkHandlesTypes
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> checkHandlesTypes
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
FUDForum. Page generated in 0.13469 seconds
