Home » Language IDEs » ServerTools (WTP) » specify transitive dependency in eclipse?(how to do i avoid configuation duplication?)
icon5.gif  specify transitive dependency in eclipse? [message #741370] Wed, 19 October 2011 13:18 Go to next message
elhanan Maayan is currently offline elhanan MaayanFriend
hi..
let's say i have a web project which depends on a java project which depends on a jar in it's class path.
if i try to use a class from java project that uses the jar, i will get a ClassNotFoundsException, is there anyway to have eclipse include that jar in the web class path? without actually inserting in the lib folder? i've tried everything, including specify order and export and use deployment assembly..
the only thing i can think of is include the jar in the server class path launcher..(which does work).
Re: specify transitive dependency in eclipse? [message #741393 is a reply to message #741370] Wed, 19 October 2011 13:37 Go to previous message
Russell Bateman is currently offline Russell BatemanFriend
On 19-Oct-11 07:18, elhanan wrote:
> hi..
You should be able to consume that other project as a Web App Library.
Do this:
1) Right-click your (Dynamic Web) project.
2) Choose Build Path -> Configure Build Path...
3) Click the Libraries tab.
4) Click Add Library...
5) Select Web App Libraries and click Next.
6) Select the project whose libraries (JARs) you wish to consume.
It should be obvious from there.
Hope this answers your question.
Previous Topic:Re: Easy SOAP client code in java?
Next Topic:Can't run tomcat 7 on eclipse helios 3.6
Current Time: Tue Mar 02 06:07:38 GMT 2021
Powered by FUDForum. Page generated in 0.02101 seconds
