Home » Modeling » EMF » CDO failover configuration
CDO failover configuration [message #740167] Tue, 18 October 2011 08:22 Go to next message
Dmitry  is currently offline Dmitry Friend
Hi everybody.
I want to raise two CDO servers in failover configuration. Where can I find any instructions on that? Google doesn't know...
Re: CDO failover configuration [message #740176 is a reply to message #740167] Tue, 18 October 2011 08:29 Go to previous messageGo to next message
Eike Stepper is currently offline Eike StepperFriend
Am 18.10.2011 10:22, schrieb Dmitry:
> Hi everybody. I want to raise two CDO servers in failover configuration. Where can I find any instructions on that?
There's a standalone example for monitored fail-over clusters in the org.eclipse.emf.cdo.examples plugin.
Please have a look at org.eclipse.emf.cdo.examples.server.FailoverExample.Monitored
Does that help?
Cheers
/Eike
http://www.esc-net.de
Re: CDO failover configuration [message #1782664 is a reply to message #740176] Tue, 27 February 2018 13:27 Go to previous messageGo to next message
Pavel Vlasov is currently offline Pavel VlasovFriend
In Oxygen CDO SDK there is "org.eclipse.emf.cdo.examples.clone" and "org.eclipse.emf.cdo.examples.master". There is no reference to fail-over in these projects. I've found the fail-over example on GitHub - https://github.com/eclipse/cdo/tree/master/plugins/org.eclipse.emf.cdo.examples/src/org/eclipse/emf/cdo/examples/server.
Can you please let me know:
- Is the fail-over approach still viable? Online references which I found date back to circa 2011, including the previous post in this topic.
- Where can I find instructions how to set-up a fail-over server, similar to the "CDO Server Operator's guide"?
- Is the example still working?
- How mature is the fail-over feature? I.e. would it justify the effort investment to set it up to survive individual server patching/restart or it'd be easier just to live with several minutes of unavailability per month?
Thank you, Pavel.
Re: CDO failover configuration [message #1796050 is a reply to message #1782664] Thu, 04 October 2018 12:58 Go to previous messageGo to next message
Robert Schulk is currently offline Robert SchulkFriend
Hi, I would also like to know this. The feature sounds great, but I am not sure if we should implement it.
Re: CDO failover configuration [message #1796775 is a reply to message #1796050] Thu, 18 October 2018 17:47 Go to previous message
Fail-over requires branching; and branching requires auditing; and auditing means that the database never shrinks. Fail-over is a quite expensive feature if you don't need auditing for other reasons, anyway.
Apart from that, fail-over scenarios are currently not in our automated tests, nor is fail-over deployed in many real-live environments (I think). It used to be mature, but I can currently make no guarantees. Please let me know if you want me to investigate deeper or fix problems...
Previous Topic:[CDO] How does CDOResourceNode.setFolder(...) work?
Next Topic:[CDO] readerPoolCapacity/writerPoolCapacity = 0 ok?
Current Time: Fri Mar 05 08:14:51 GMT 2021
Powered by FUDForum. Page generated in 0.01665 seconds
