Re: BIRT 2.5.1 cuts off font at auto text when generating a PDF [message #740550 is a reply to message #740155] |
Tue, 18 October 2011 16:22 |
Can you reproduce this in a report with sample data so we can run and
test it?
Jason
On 10/18/2011 4:09 AM, oppressor wrote:
> I'm using BIRT 2.5.1 an added a grid on the master page where I want the page numbers to be shown.
> When generating the report as an PDF the auto text for "page n of m" cuts off the number on the "of m"-side when the font is set to sans serif or helvetica.
> Setting the font to times or serif oder whateverfont the number is perfectly shown.
> Also when using Arial as font, the number is perfectly shown.
> I already tried to adjust the grid, padding, font size. Nothing worked.
> Any idea?
Re: BIRT 2.5.1 cuts off font at auto text when generating a PDF [message #742556 is a reply to message #742296] |
Thu, 20 October 2011 15:47 |
Do you mind opening a bugzilla entry for this?
Jason
On 10/20/2011 7:15 AM, oppressor wrote:
> Interesting detail: on a ubuntu machine of a employee of mine, the
> report with the sans serif font family is drawn perfectly in the pdf
> file. I'm running a Windows 7 64-Bit machine. Due to the fact that the
> report will finally get generated on a linux server the problem is
> solved for me by now...but its still interesting.
> Does linux use a variant of the helvetica font type? On both systems the
> helvetica font is embedded in the pdf file when the sans serif font
> family is chosen...
FUDForum. Page generated in 0.03411 seconds
