Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo] (newbie): More than one EClass with the same name
[Teneo] (newbie): More than one EClass with the same name [message #80650] |
Mon, 23 April 2007 08:45  |
Originally posted by: gonzalinlinWITHOUT_THIS.tiscali.es
Hello Martin!
I've read an old post with the same issue, but it didn't help me.
I get this error (there's String (java.lang) and String (the generated one
in party.javalang):
Exception in thread "main" java.lang.IllegalArgumentException: There is more
than one EClass with the same name (String in EPackage javalang and
javalang. A different EClassResolver should be used.
When I try to create an instance of "Pdi" (Pdi is a class that extends
Party)...
final String dataStoreName = "SGDDataStore";
final HbDataStore dataStore =
(HbDataStore)HbHelper.INSTANCE.createRegisterDataStore(dataS toreName);
dataStore.setEPackages(new EPackage[] { PartyPackage.eINSTANCE,
PartyPackageImpl.eINSTANCE,
JavalangPackage.eINSTANCE, JavalangPackageImpl.eINSTANCE,
JavautilPackage.eINSTANCE,
JavautilPackageImpl.eINSTANCE, });
dataStore.initialize();
final SessionFactory sessionFactory = dataStore.getSessionFactory();
final Session session = sessionFactory.openSession();
session.beginTransaction();
Pdi pdi = PartyFactory.eINSTANCE.createPdi();
pdi.setAddress( "Campus, s/n"); // <----------------- (*)
session.save(pdi);
// (continues)
(*) ... Eclipse says: "the method setAddress (String) in the type Party is
not applicable for the arguments String.
There's a conflict between the String in (final String dataStoreName =
"SGDDataStore";) and the String in (pdi.setAddress( "Campus, s/n"); ).
Can you help me? Thanks in advance,
Gonzalo
Re: [Teneo] (newbie): More than one EClass with the same name [message #80667 is a reply to message #80650] |
Mon, 23 April 2007 08:54   |
Hi Gonzalo,
To get rid of the first exception you should set this property:
PersistenceOptions.QUALIFY_ENTITY_NAME
to: PersistenceOptions.QUALIFY_ENTITY_NAME_NSPREFIX
to set this you can call the setPersistenceProperties on the hibernatedatastore.
(note if you set this in a property file then you need to check what the String constant
PersistenceOptions.QUALIFY_ENTITY_NAME_NSPREFIX is and set this string constant in the prop file,
the same for the other constant).
For the other compiletime error, you should maybe do something like this:
party.javalang.String myGreatString = PartyFactory.eINSTANCE.createString();
myGreatString.setValue("Campus, s/n"); // I am not sure if there is a value member/feature in the
party.javaLang.String class, but there is probably something there
pdi.setAddress(myGreatString); // <----------------- (*)
Btw, it would maybe be easier not to use exact java reserved (primitive type) names for your eclass
names or efeature names, but this ofcourse depends on the case you want to solve.
gr. Martin
Gonzalo wrote:
> Hello Martin!
> in party.javalang):
> Party)...
> public static void main(String[] args) {
> session.save(pdi);
> // (continues)
> Gonzalo
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] (newbie): More than one EClass with the same name [message #80682 is a reply to message #80667] |
Mon, 23 April 2007 10:16   |
Hello again.
Martin: I keep getting the same error, but eith other classes:
than one EClass with the same identifying String (party.Persona in EPackage
party and party. A different EClassResolver should be used.
My code is (I've set the Property):
final Properties persistenceProps = new Properties();
persistenceProps.setProperty(PersistenceOptions.QUALIFY_ENTI TY_NAME,
PersistenceOptions.QUALIFY_ENTITY_NAME_NSPREFIX);
JavautilPackageImpl.eINSTANCE });
dataStore.setPersistenceProperties(persistenceProps);
The error points to this line (dataStore.initialize() ).
Any hint? Thank you again!
Gonzalo
"Martin Taal" <mtaal@elver.org> escribi
Re: [Teneo] (newbie): More than one EClass with the same name [message #80689 is a reply to message #80682] |
Mon, 23 April 2007 10:26   |
Hi Gonzalo,
Can you post/send me the full stack trace and the ecore file? And if you are able to get the
hibernate.hbm (call dataStore.getMappingXML() (call this for example in an exception catch block
after initialize).
gr. Martin
Gonzalo wrote:
> Hello again.
> Gonzalo
> "Martin Taal" <mtaal@elver.org> escribió en el mensaje
> news:f0hs7v$ccq$1@build.eclipse.org...
>> Hi Gonzalo,
>> hibernatedatastore.
>> String constant PersistenceOptions.QUALIFY_ENTITY_NAME_NSPREFIX is and set
>> this string constant in the prop file, the same for the other constant).
>> value member/feature in the party.javaLang.String class, but there is
>> type) names for your eclass names or efeature names, but this ofcourse
>> gr. Martin
>> Gonzalo wrote:
>>> Hello Martin!
>>> one in party.javalang):
>>> more than one EClass with the same name (String in EPackage javalang and
>>> Party)...
>>> session.save(pdi);
>>> // (continues)
>>> is not applicable for the arguments String.
>>> Gonzalo
>> The Netherlands
The Netherlands
Re: [Teneo] (newbie): More than one EClass with the same name [message #80776 is a reply to message #80705] |
Mon, 23 April 2007 19:34   |
Hi Gonzalo,
It worked fine with me, then I looked at your initialization code and the following needs to be
changed. When you call setEPackages in your code, each EPackage is present twice:
PartyPackage.eINSTANCE and PartyPackageImpl.eINSTANCE. These refer to the same EPackage instance, so
only the PartyPackage.eINSTANCE is enough (the same for the other two EPackages javalang javautil).
gr. Martin
Gonzalo wrote:
> Hello Martin, I attach the files.
> I tried
> System.err.println(dataStore.getMappingXML());
> after dataStore.initialize(), but the error is the same.
> Thank you!
> news:f0i1kh$nvt$1@build.eclipse.org...
>> Hi Gonzalo,
>> are able to get the
>> after initialize).
>> gr. Martin
>> Gonzalo wrote:
>>> Hello again.
>>> more
>>> EPackage
>>> Gonzalo
>>>> Hi Gonzalo,
>>>> hibernatedatastore.
>>>> set
>>>> this:
>>>> gr. Martin
>>>> Gonzalo wrote:
>>>>> Hello Martin!
>>>>> and
>>>>> Party)...
>>>>> session.save(pdi);
>>>>> // (continues)
>>>>> Gonzalo
>>>> The Netherlands
>> The Netherlands
> 0 [main] INFO org.eclipse.emf.teneo.hibernate.HbHelper - Creating emf data store and registering it under name: SGDDataStore
> 63 [main] DEBUG org.eclipse.emf.teneo.hibernate.HbDataStore - Initializing protocol/extension for hibernate
> 79 [main] INFO org.eclipse.emf.teneo.hibernate.HbHelper - Returning created emf data store, initialize this newly created data store!
> 485 [main] DEBUG org.eclipse.emf.teneo.PersistenceOptions - Properties of PersistenceOptions:
> 485 [main] DEBUG org.eclipse.emf.teneo.PersistenceOptions - teneo.mapping.set_proxy: false
> 485 [main] DEBUG org.eclipse.emf.teneo.PersistenceOptions - teneo.mapping.ignore_eannotations: false
> 485 [main] DEBUG org.eclipse.emf.teneo.PersistenceOptions - teneo.mapping.always_version: true
> 485 [main] DEBUG org.eclipse.emf.teneo.PersistenceOptions - teneo.mapping.always_map_list_as_bag: false
> 485 [main] DEBUG org.eclipse.emf.teneo.PersistenceOptions - teneo.mapping.optimistic_locking: true
> 485 [main] DEBUG org.eclipse.emf.teneo.PersistenceOptions - teneo.mapping.emap_as_true_map: true
> 485 [main] DEBUG org.eclipse.emf.teneo.PersistenceOptions - teneo.naming.id_feature_as_primary_key: true
> 485 [main] DEBUG org.eclipse.emf.teneo.PersistenceOptions - teneo.naming.default_id_column: e_id
> 485 [main] DEBUG org.eclipse.emf.teneo.PersistenceOptions - teneo.mapping.also_map_as_class: true
> 485 [main] DEBUG org.eclipse.emf.teneo.PersistenceOptions - teneo.mapping.default_cache_strategy: NONE
> 485 [main] DEBUG org.eclipse.emf.teneo.PersistenceOptions - teneo.naming.version_column: e_version
> 485 [main] DEBUG org.eclipse.emf.teneo.PersistenceOptions - teneo.mapping.fetch_containment_eagerly: false
> 485 [main] DEBUG org.eclipse.emf.teneo.PersistenceOptions - teneo.mapping.join_table_for_non_contained_associations: false
> 485 [main] DEBUG org.eclipse.emf.teneo.PersistenceOptions - teneo.naming.java_class_entity_names: false
> 485 [main] DEBUG org.eclipse.emf.teneo.PersistenceOptions - teneo.naming.max_sql_name_length: -1
> 485 [main] DEBUG org.eclipse.emf.teneo.PersistenceOptions - teneo.naming.strategy: lowercase
> 485 [main] DEBUG org.eclipse.emf.teneo.PersistenceOptions - teneo.naming.qualify_entity_name: nsprefix
> 485 [main] DEBUG org.eclipse.emf.teneo.PersistenceOptions - teneo.naming.default_id_feature: e_id
> 485 [main] DEBUG org.eclipse.emf.teneo.PersistenceOptions - teneo.mapping.disable_econtainer: false
> 485 [main] DEBUG org.eclipse.emf.teneo.PersistenceOptions - teneo.mapping.default_temporal: TIMESTAMP
> 485 [main] DEBUG org.eclipse.emf.teneo.PersistenceOptions - teneo.mapping.join_table_naming_strategy: ejb3
> 485 [main] DEBUG org.eclipse.emf.teneo.PersistenceOptions - teneo.mapping.idbag_id_column_name: ID
> 485 [main] DEBUG org.eclipse.emf.teneo.PersistenceOptions - teneo.mapping.map_all_lists_as_idbag: false
> 485 [main] DEBUG org.eclipse.emf.teneo.PersistenceOptions - teneo.mapping.cascade_all_on_containment: true
> 485 [main] DEBUG org.eclipse.emf.teneo.PersistenceOptions - teneo.mapping.set_entity_automatically: true
> 485 [main] DEBUG org.eclipse.emf.teneo.PersistenceOptions - teneo.mapping.hibernate_mapping_file: false
> 485 [main] DEBUG org.eclipse.emf.teneo.PersistenceOptions - teneo.runtime.update_schema: true
> 485 [main] DEBUG org.eclipse.emf.teneo.hibernate.HbSessionDataStore - Initializing Hb Session DataStore
> 485 [main] DEBUG org.eclipse.emf.teneo.hibernate.HbSessionDataStore - >>>>> Creating HB Configuration
> 532 [main] INFO org.hibernate.cfg.Environment - Hibernate 3.2.3
> 547 [main] INFO org.hibernate.cfg.Environment - loaded properties from resource hibernate.properties: {hibernate.connection.username=root, hibernate.connection.password=****, hibernate.dialect=org.hibernate.dialect.MySQLInnoDBDialect, hibernate.connection.url=jdbc:mysql://127.0.0.1:3306/sgd23, hibernate.bytecode.use_reflection_optimizer=false, hibernate.connection.driver_class=com.mysql.jdbc.Driver}
> 547 [main] INFO org.hibernate.cfg.Environment - Bytecode provider name : cglib
> 563 [main] INFO org.hibernate.cfg.Environment - using JDK 1.4 java.sql.Timestamp handling
> 672 [main] DEBUG org.eclipse.emf.teneo.hibernate.HbDataStore - Generating mapping file from in-mem ecore
> 704 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder - Creating pamodel for the following epackages
> 704 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder - party
> 907 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder - party
> 907 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder - javalang
> 907 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder - javautil
> 907 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder - Create base pannotated model
> 907 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder - Deprecated eannotations with http://annotations.elver.org or http://ejb.elver.org are ignored.
> 907 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder - Parse annotations
> 907 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing package party
> 907 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing party
> 907 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Number of parsed typename annotations 0
> 907 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing Party
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing eclass Party
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing direccion
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Number of parsed typename annotations 0
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing localidad
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing codPostal
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing provincia
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing telefono1
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing extension
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing telefono2
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing correoE
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing fax
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing web
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing Empresa
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing eclass Empresa
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing cif
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing denominacion
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing nombreComercial
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing cnae
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing contactoEmpresa
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing ContactoEmpresa
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing eclass ContactoEmpresa
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing cargo
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing dptoEmpresa
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing empresa
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing Persona
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing eclass Persona
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing nif
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing apellido1
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing apellido2
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing fechaNac
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing Pdi
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing eclass Pdi
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing catAcademica
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing areaConocimiento
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing centro
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing codCtaCliente
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing remuneracion
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing horasSemanales
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing package javalang
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing javalang
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing Object
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing eclass Object
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing String
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing eclass String
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing package javautil
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing javautil
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing Collection
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing eclass Collection
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing Iterator
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing eclass Iterator
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing Date
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Processing eclass Date
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder - Copying annotations on edatatypes over eattribute annotations!
> 922 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder - Add default annotations
> 938 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Option: Default inheritance setting: SINGLE_TABLE
> 938 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Option: Automatically adding entity annotation: true
> 938 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Option: Eagerly load all containment relations: false
> 938 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Option set cascade all on containment: true
> 938 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Option default id feature name: e_id
> 938 [main] DEBUG org.eclipse.emf.teneo.ecore.EClassNameStrategyUtils - Creating org.eclipse.emf.teneo.ecore.QualifyingEClassNameStrategy as case strategy
> 938 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Qualify EClass name option: org.eclipse.emf.teneo.ecore.QualifyingEClassNameStrategy
> 938 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - ID Feature as primary key true
> 938 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - optionEMapAsTrueMap true
> 938 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - optionAlsoMapAsClass true
> 938 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Maximum column length: -1
> 938 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - JoinTableForNonContainedAssociations false
> 938 [main] DEBUG org.eclipse.emf.teneo.util.SQLCaseStrategyImpl - Creating org.eclipse.emf.teneo.util.SQLCaseStrategyImpl$LowerCase as case strategy
> 938 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - SQLCaseStrategy org.eclipse.emf.teneo.util.SQLCaseStrategyImpl$LowerCase
> 938 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - JoinTableNamingStrategy ejb3
> 938 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - optionMapListAsBag false
> 938 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - optionMapListAsIdBag false
> 938 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Class names are to be fully classified, registering all the epackages
> 954 [main] DEBUG org.eclipse.emf.teneo.ERuntime - Determining concrete classes for package party
> 969 [main] DEBUG org.eclipse.emf.teneo.ERuntime - Determining concrete classes for package javalang
> 969 [main] DEBUG org.eclipse.emf.teneo.ERuntime - Determining concrete classes for package javautil
> 969 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - >>>> Adding default annotations for EPackage party
> 969 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Processing EDataTypes
> 969 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Processing EClasses
> 969 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Creating mapping for eclass Party
> 969 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Adding default annotations for EClass: Party
> 969 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Setting the superentity of the eclass
> 985 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - EReference + direccion/Party does not have a manytoone annotation, adding one
> 1000 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - EReference + localidad/Party does not have a manytoone annotation, adding one
> 1000 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - EReference + codPostal/Party does not have a manytoone annotation, adding one
> 1000 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - EReference + provincia/Party does not have a manytoone annotation, adding one
> 1000 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - EReference + telefono1/Party does not have a manytoone annotation, adding one
> 1000 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - EReference + extension/Party does not have a manytoone annotation, adding one
> 1000 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - EReference + telefono2/Party does not have a manytoone annotation, adding one
> 1000 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - EReference + correoE/Party does not have a manytoone annotation, adding one
> 1000 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - EReference + fax/Party does not have a manytoone annotation, adding one
> 1000 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - EReference + web/Party does not have a manytoone annotation, adding one
> 1000 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Creating mapping for eclass Empresa
> 1000 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Adding default annotations for EClass: Empresa
> 1000 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Setting the superentity of the eclass
> 1000 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - EReference + cif/Empresa does not have a manytoone annotation, adding one
> 1000 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - EReference + denominacion/Empresa does not have a manytoone annotation, adding one
> 1000 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - EReference + nombreComercial/Empresa does not have a manytoone annotation, adding one
> 1000 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - EReference + cnae/Empresa does not have a manytoone annotation, adding one
> 1032 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - EReference + contactoEmpresa/Empresa does not have a onetomany annotation, adding one
> 1032 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Setting indexed and unique from ereference because otm was not set manually!
> 1032 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Setting unique because is bidirectional (has eopposite) otm
> 1032 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Creating mapping for eclass ContactoEmpresa
> 1032 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Creating mapping for eclass Persona
> 1032 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Adding default annotations for EClass: Persona
> 1032 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Setting the superentity of the eclass
> 1032 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - EReference + nif/Persona does not have a manytoone annotation, adding one
> 1032 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - EReference + nombre/Persona does not have a manytoone annotation, adding one
> 1032 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - EReference + apellido1/Persona does not have a manytoone annotation, adding one
> 1032 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - EReference + apellido2/Persona does not have a manytoone annotation, adding one
> 1032 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - EReference + fechaNac/Persona does not have a manytoone annotation, adding one
> 1032 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Adding default annotations for EClass: ContactoEmpresa
> 1032 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - EReference + cargo/ContactoEmpresa does not have a manytoone annotation, adding one
> 1032 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - EReference + dptoEmpresa/ContactoEmpresa does not have a manytoone annotation, adding one
> 1032 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - EReference + empresa/ContactoEmpresa does not have a manytoone annotation, adding one
> 1032 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Creating mapping for eclass Pdi
> 1032 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Adding default annotations for EClass: Pdi
> 1032 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - EReference + catAcademica/Pdi does not have a manytoone annotation, adding one
> 1032 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - EReference + areaConocimiento/Pdi does not have a manytoone annotation, adding one
> 1047 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - EReference + dpto/Pdi does not have a manytoone annotation, adding one
> 1047 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - EReference + centro/Pdi does not have a manytoone annotation, adding one
> 1047 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - EReference + codCtaCliente/Pdi does not have a manytoone annotation, adding one
> 1047 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Adding default annotations for EAttribute remuneracion
> 1047 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - EReference + horasSemanales/Pdi does not have a manytoone annotation, adding one
> 1047 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - >>>> Adding default annotations for EPackage javalang
> 1047 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Processing EDataTypes
> 1047 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Processing EClasses
> 1047 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Creating mapping for eclass Object
> 1047 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Adding default annotations for EClass: Object
> 1047 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Setting the superentity of the eclass
> 1047 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Creating mapping for eclass String
> 1047 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Adding default annotations for EClass: String
> 1047 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - >>>> Adding default annotations for EPackage javautil
> 1047 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Creating mapping for eclass Collection
> 1047 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Adding default annotations for EClass: Collection
> 1047 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Creating mapping for eclass Iterator
> 1047 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Adding default annotations for EClass: Iterator
> 1047 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Creating mapping for eclass Date
> 1047 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Adding default annotations for EClass: Date
> 1047 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder - Returning created pamodel
> 1094 [main] DEBUG org.eclipse.emf.teneo.ecore.EClassNameStrategyUtils - Creating org.eclipse.emf.teneo.ecore.QualifyingEClassNameStrategy as case strategy
> 1094 [main] DEBUG org.eclipse.emf.teneo.util.SQLCaseStrategyImpl - Creating org.eclipse.emf.teneo.util.SQLCaseStrategyImpl$LowerCase as case strategy
> 1110 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.HibernateMappingGener ator - Geneting Hibernate mapping for org.eclipse.emf.teneo.annotations.pamodel.impl.PAnnotatedMod elImpl @42552c
> 1110 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.HibernateMappingGener ator - Setting auto-import=false because eclassnamingstrategy is not the defaulteclassnamestrategy
> 1110 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.EntityMapper - Mapping Entity EClass/Party
> 1110 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.EntityMapper - Creating entity tag class
> 1110 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.EntityMapper - DValue party.Party
> 1110 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.EntityMapper - Table `party_party`
> 1125 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper - Process many-to-one EReference/direccion
> 1125 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper - Target party.javalang.String
> 1125 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - addManyToOne direccion/party.javalang.String
> 1125 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - addJoinColumns many-to-one/ no of joincolumns1
> 1125 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - JoinColumn string_direccion_e_id
> 1125 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper - Process many-to-one EReference/localidad
> 1125 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - addManyToOne localidad/party.javalang.String
> 1125 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - JoinColumn string_localidad_e_id
> 1125 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper - Process many-to-one EReference/codPostal
> 1125 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - addManyToOne codPostal/party.javalang.String
> 1125 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - JoinColumn string_codpostal_e_id
> 1125 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper - Process many-to-one EReference/provincia
> 1125 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - addManyToOne provincia/party.javalang.String
> 1125 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - JoinColumn string_provincia_e_id
> 1125 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper - Process many-to-one EReference/telefono1
> 1125 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - addManyToOne telefono1/party.javalang.String
> 1125 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - JoinColumn string_telefono1_e_id
> 1125 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper - Process many-to-one EReference/extension
> 1125 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - addManyToOne extension/party.javalang.String
> 1125 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - JoinColumn string_extension_e_id
> 1125 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper - Process many-to-one EReference/telefono2
> 1125 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - addManyToOne telefono2/party.javalang.String
> 1125 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - JoinColumn string_telefono2_e_id
> 1125 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper - Process many-to-one EReference/correoE
> 1125 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - addManyToOne correoE/party.javalang.String
> 1125 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - JoinColumn string_correoe_e_id
> 1125 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper - Process many-to-one EReference/fax
> 1125 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - addManyToOne fax/party.javalang.String
> 1125 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - JoinColumn string_fax_e_id
> 1125 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper - Process many-to-one EReference/web
> 1125 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - addManyToOne web/party.javalang.String
> 1125 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - JoinColumn string_web_e_id
> 1125 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.EntityMapper - Mapping Entity EClass/Empresa
> 1125 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.EntityMapper - Creating entity tag subclass
> 1125 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.EntityMapper - Extends party.Party
> 1125 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.EntityMapper - DValue party.Empresa
> 1141 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.AbstractProcessingC ontext - Determining inherited features which are mapped locally for Empresa
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper - Process many-to-one EReference/cif
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper - Target party.javalang.String
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - addManyToOne cif/party.javalang.String
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - addJoinColumns many-to-one/ no of joincolumns1
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - JoinColumn string_cif_e_id
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper - Process many-to-one EReference/denominacion
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - addManyToOne denominacion/party.javalang.String
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - JoinColumn string_denominacion_e_id
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper - Process many-to-one EReference/nombreComercial
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - addManyToOne nombreComercial/party.javalang.String
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - JoinColumn string_nombrecomercial_e_id
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper - Process many-to-one EReference/cnae
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - addManyToOne cnae/party.javalang.String
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - JoinColumn string_cnae_e_id
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.OneToManyMapper - Generating one to many bidirectional inverse mapping for EReference/contactoEmpresa
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - Adding key columns
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - Column contactoempresa_empresa_e_id
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.EntityMapper - Mapping Entity EClass/Persona
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.EntityMapper - Creating entity tag subclass
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.EntityMapper - Extends party.Party
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.EntityMapper - DValue party.Persona
> 1141 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.AbstractProcessingC ontext - Determining inherited features which are mapped locally for Persona
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper - Process many-to-one EReference/nif
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - addManyToOne nif/party.javalang.String
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - JoinColumn string_nif_e_id
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - addManyToOne nombre/party.javalang.String
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - JoinColumn string_nombre_e_id
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper - Process many-to-one EReference/apellido1
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - addManyToOne apellido1/party.javalang.String
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - JoinColumn string_apellido1_e_id
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper - Process many-to-one EReference/apellido2
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - addManyToOne apellido2/party.javalang.String
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - JoinColumn string_apellido2_e_id
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper - Process many-to-one EReference/fechaNac
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper - Target party.javautil.Date
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - addManyToOne fechaNac/party.javautil.Date
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - JoinColumn date_fechanac_e_id
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.EntityMapper - Mapping Entity EClass/ContactoEmpresa
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.EntityMapper - Extends party.Persona
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.EntityMapper - DValue party.ContactoEmpresa
> 1141 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.AbstractProcessingC ontext - Determining inherited features which are mapped locally for ContactoEmpresa
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper - Process many-to-one EReference/cargo
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - addManyToOne cargo/party.javalang.String
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - JoinColumn string_cargo_e_id
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper - Process many-to-one EReference/dptoEmpresa
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - addManyToOne dptoEmpresa/party.javalang.String
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - JoinColumn string_dptoempresa_e_id
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper - Process many-to-one EReference/empresa
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper - Target party.Empresa
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - addManyToOne empresa/party.Empresa
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - JoinColumn contactoempresa_empresa_e_id
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.EntityMapper - Mapping Entity EClass/Pdi
> 1141 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.EntityMapper - DValue party.Pdi
> 1141 [main] DEBUG org.eclipse.emf.teneo.annotations.mapper.AbstractProcessingC ontext - Determining inherited features which are mapped locally for Pdi
> 1157 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper - Process many-to-one EReference/catAcademica
> 1157 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper - Target party.javalang.String
> 1157 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - addManyToOne catAcademica/party.javalang.String
> 1157 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - addJoinColumns many-to-one/ no of joincolumns1
> 1157 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - JoinColumn string_catacademica_e_id
> 1157 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper - Process many-to-one EReference/areaConocimiento
> 1157 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - addManyToOne areaConocimiento/party.javalang.String
> 1157 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - JoinColumn string_areaconocimiento_e_id
> 1157 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper - Process many-to-one EReference/dpto
> 1157 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - addManyToOne dpto/party.javalang.String
> 1157 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - JoinColumn string_dpto_e_id
> 1157 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper - Process many-to-one EReference/centro
> 1157 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - addManyToOne centro/party.javalang.String
> 1157 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - JoinColumn string_centro_e_id
> 1157 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper - Process many-to-one EReference/codCtaCliente
> 1157 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - addManyToOne codCtaCliente/party.javalang.String
> 1157 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMa pper - JoinColumn string_codctacliente_e_id
Re: [Teneo] (newbie): More than one EClass with the same name [message #80843 is a reply to message #80776] |
Tue, 24 April 2007 08:24   |
Thank you, Martin! It works :)
I keep getting errors with the types: String vs. Party.javalang.String. I
don't know why I get these packages (party.javalang, party.javautil)... in
the Library example they don't exist and there isn't this problem! The only
difference is that start from an UML diagram (Omondo Eclipse UML plugin) and
not annotated Java.
The first solution you proposed me...
JavalangFactory.eINSTANCE.createString();
//the
.... I think it is complicated for every "String" attribute I could get.
Moreover, there's nothing like "JavalangFactory.eINSTANCE.createString()"
and Party.javalang.String only extends EObject... (i attach the String.java
generated).
So, for the second solution ("Btw, it would maybe be easier not to use exact
java reserved (primitive type) names for your eclass names or efeature
names"), I don't know if I must change "party.javalang.String" for "String"
everywhere in my code. The same for every "party.javalang.String" in the
"hibernate.hbm" generated by Teneo. Is this the best way?
Thanks in advance, Martin.
With regards,
Gonzalo
Attachment: String.java
(Size: 0.39KB, Downloaded 107 times)
Re: [Teneo] (newbie): More than one EClass with the same name [message #80844 is a reply to message #80843] |
Tue, 24 April 2007 08:34   |
Hi Gonzalo,
I think you should not go in that direction (manually changing the hbm or your generated code).
It seems that the Omondo Uml to ecore mapping creates these types. Although I do not know your case
and I do not know Omondo it seems to me that this is not what you want, the ecore should use the
primitive String type. I don't use Omondo so I can't help you there. I think you should recheck with
the Omondo people to see why the ecore was created like this.
You could also just create the ecore manually and work from there (use the library.ecore as an example).
gr. Martin
> not annotated Java.
> //the
> generated).
> With regards,
> Gonzalo
> news:f0j1o1$22s$1@build.eclipse.org...
>> Hi Gonzalo,
>> twice:
>> gr. Martin
>>> I tried
>>> Thank you!
>>>> Hi Gonzalo,
>>>> are able to get the
>>>> an
>>>> after initialize).
>>>> gr. Martin
>>>> Gonzalo wrote:
>>>>> Hello again.
>>>>> more
>>>>> EPackage
>>>>> Gonzalo
>>>>>> Hi Gonzalo,
>>>>>> hibernatedatastore.
>>>>>> the
>>>>>> set
>>>>>> constant).
>>>>>> this:
>>>>>> (primitive
>>>>>> gr. Martin
>>>>>> Gonzalo wrote:
>>>>>>> Hello Martin!
>>>>>>> generated
>>>>>>> is
>>>>>>> and
>>>>>>> extends
>>>>>>> Party)...
>>>>>>> session.save(pdi);
>>>>>>> // (continues)
>>>>>>> Party
>>>>>>> s/n"); ).
>>>>>>> Gonzalo
>>>>>> The Netherlands
>>>> The Netherlands
>>> : cglib
>>> 704 [main] DEBUG
>>> 704 [main] DEBUG
>>> party
>>> 907 [main] DEBUG
>>> party
>>> 907 [main] DEBUG
>>> javalang
>>> 907 [main] DEBUG
>>> javalang
>>> 907 [main] DEBUG
>>> javautil
>>> 907 [main] DEBUG
>>> javautil
>>> 907 [main] DEBUG
>>> 907 [main] DEBUG
>>> 907 [main] DEBUG
>>> Parse annotations
>>> 907 [main] DEBUG
>>> 907 [main] DEBUG
>>> Processing party
>>> 907 [main] DEBUG
>>> 907 [main] DEBUG
>>> Processing Party
>>> 907 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing correoE
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing fax
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing web
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing Empresa
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing cif
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing cnae
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing cargo
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing empresa
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing Persona
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing nif
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing nombre
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing fechaNac
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing Pdi
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing dpto
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing centro
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing javalang
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing Object
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing String
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing javautil
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing Iterator
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing Date
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> default annotations
>>> 938 [main] DEBUG
>>> 938 [main] DEBUG
>>> 938 [main] DEBUG
>>> 938 [main] DEBUG
>>> 938 [main] DEBUG
>>> strategy
>>> 938 [main] DEBUG
>>> EClass name option:
>>> 938 [main] DEBUG
>>> as primary key true
>>> 938 [main] DEBUG
>>> 938 [main] DEBUG
>>> 938 [main] DEBUG
>>> column length: -1
>>> 938 [main] DEBUG
>>> strategy
>>> 938 [main] DEBUG
>>> 938 [main] DEBUG
>>> 938 [main] DEBUG
>>> 938 [main] DEBUG
>>> 938 [main] DEBUG
>>> 969 [main] DEBUG
>>> 969 [main] DEBUG
>>> EDataTypes
>>> 969 [main] DEBUG
>>> EClasses
>>> 969 [main] DEBUG
>>> 969 [main] DEBUG
>>> 969 [main] DEBUG
>>> 985 [main] DEBUG
>>> 1000 [main] DEBUG
>>> 1000 [main] DEBUG
>>> 1000 [main] DEBUG
>>> 1000 [main] DEBUG
>>> 1000 [main] DEBUG
>>> 1000 [main] DEBUG
>>> 1000 [main] DEBUG
>>> 1000 [main] DEBUG
>>> 1000 [main] DEBUG
>>> 1000 [main] DEBUG
>>> 1000 [main] DEBUG
>>> 1000 [main] DEBUG
>>> 1000 [main] DEBUG
>>> 1000 [main] DEBUG
>>> 1000 [main] DEBUG
>>> 1000 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> one
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> EDataTypes
>>> 1047 [main] DEBUG
>>> EClasses
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> EDataTypes
>>> 1047 [main] DEBUG
>>> EClasses
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> strategy
>>> strategy
>>> 1110 [main] DEBUG
>>> 1110 [main] DEBUG
>>> DValue party.Party
>>> Table `party_party`
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
Re: [Teneo] (newbie): More than one EClass with the same name [message #604919 is a reply to message #80650] |
Hi Gonzalo,
gr. Martin
Gonzalo wrote:
> Hello Martin!
> in party.javalang):
> Party)...
> session.save(pdi);
> // (continues)
> Gonzalo
The Netherlands
Re: [Teneo] (newbie): More than one EClass with the same name [message #604926 is a reply to message #80682] |
Hi Gonzalo,
after initialize).
gr. Martin
Gonzalo wrote:
> Hello again.
> Gonzalo
>> Hi Gonzalo,
>> hibernatedatastore.
>> gr. Martin
>> Gonzalo wrote:
>>> Hello Martin!
>>> Party)...
>>> session.save(pdi);
>>> // (continues)
>>> Gonzalo
>> The Netherlands
The Netherlands
Re: [Teneo] (newbie): More than one EClass with the same name [message #604943 is a reply to message #80705] |
Hi Gonzalo,
gr. Martin
> I tried
> Thank you!
>> Hi Gonzalo,
>> are able to get the
>> after initialize).
>> gr. Martin
>> Gonzalo wrote:
>>> Hello again.
>>> more
>>> EPackage
>>> Gonzalo
>>>> Hi Gonzalo,
>>>> hibernatedatastore.
>>>> set
>>>> this:
>>>> gr. Martin
>>>> Gonzalo wrote:
>>>>> Hello Martin!
>>>>> and
>>>>> Party)...
>>>>> session.save(pdi);
>>>>> // (continues)
>>>>> Gonzalo
>>>> The Netherlands
>> The Netherlands
Re: [Teneo] (newbie): More than one EClass with the same name [message #604963 is a reply to message #80776] |
Gonzalo Messages: 27 Registered: July 2009 |
not annotated Java.
//the
generated).
With regards,
Gonzalo
(Size: 0.39KB, Downloaded 67 times)
Re: [Teneo] (newbie): More than one EClass with the same name [message #604968 is a reply to message #80843] |
Hi Gonzalo,
gr. Martin
> not annotated Java.
> //the
> generated).
> With regards,
> Gonzalo
>> Hi Gonzalo,
>> twice:
>> gr. Martin
>>> I tried
>>> Thank you!
>>>> Hi Gonzalo,
>>>> are able to get the
>>>> an
>>>> after initialize).
>>>> gr. Martin
>>>> Gonzalo wrote:
>>>>> Hello again.
>>>>> more
>>>>> EPackage
>>>>> Gonzalo
>>>>>> Hi Gonzalo,
>>>>>> hibernatedatastore.
>>>>>> the
>>>>>> set
>>>>>> constant).
>>>>>> this:
>>>>>> (primitive
>>>>>> gr. Martin
>>>>>> Gonzalo wrote:
>>>>>>> Hello Martin!
>>>>>>> generated
>>>>>>> is
>>>>>>> and
>>>>>>> extends
>>>>>>> Party)...
>>>>>>> session.save(pdi);
>>>>>>> // (continues)
>>>>>>> Party
>>>>>>> s/n"); ).
>>>>>>> Gonzalo
>>>>>> The Netherlands
>>>> The Netherlands
>>> : cglib
>>> 704 [main] DEBUG
>>> 704 [main] DEBUG
>>> party
>>> 907 [main] DEBUG
>>> party
>>> 907 [main] DEBUG
>>> javalang
>>> 907 [main] DEBUG
>>> javalang
>>> 907 [main] DEBUG
>>> javautil
>>> 907 [main] DEBUG
>>> javautil
>>> 907 [main] DEBUG
>>> 907 [main] DEBUG
>>> 907 [main] DEBUG
>>> Parse annotations
>>> 907 [main] DEBUG
>>> 907 [main] DEBUG
>>> Processing party
>>> 907 [main] DEBUG
>>> 907 [main] DEBUG
>>> Processing Party
>>> 907 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing correoE
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing fax
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing web
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing Empresa
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing cif
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing cnae
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing cargo
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing empresa
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing Persona
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing nif
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing nombre
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing fechaNac
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing Pdi
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing dpto
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing centro
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing javalang
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing Object
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing String
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing javautil
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing Iterator
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> Processing Date
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> 922 [main] DEBUG
>>> default annotations
>>> 938 [main] DEBUG
>>> 938 [main] DEBUG
>>> 938 [main] DEBUG
>>> 938 [main] DEBUG
>>> 938 [main] DEBUG
>>> strategy
>>> 938 [main] DEBUG
>>> EClass name option:
>>> 938 [main] DEBUG
>>> as primary key true
>>> 938 [main] DEBUG
>>> 938 [main] DEBUG
>>> 938 [main] DEBUG
>>> column length: -1
>>> 938 [main] DEBUG
>>> strategy
>>> 938 [main] DEBUG
>>> 938 [main] DEBUG
>>> 938 [main] DEBUG
>>> 938 [main] DEBUG
>>> 938 [main] DEBUG
>>> 969 [main] DEBUG
>>> 969 [main] DEBUG
>>> EDataTypes
>>> 969 [main] DEBUG
>>> EClasses
>>> 969 [main] DEBUG
>>> 969 [main] DEBUG
>>> 969 [main] DEBUG
>>> 985 [main] DEBUG
>>> 1000 [main] DEBUG
>>> 1000 [main] DEBUG
>>> 1000 [main] DEBUG
>>> 1000 [main] DEBUG
>>> 1000 [main] DEBUG
>>> 1000 [main] DEBUG
>>> 1000 [main] DEBUG
>>> 1000 [main] DEBUG
>>> 1000 [main] DEBUG
>>> 1000 [main] DEBUG
>>> 1000 [main] DEBUG
>>> 1000 [main] DEBUG
>>> 1000 [main] DEBUG
>>> 1000 [main] DEBUG
>>> 1000 [main] DEBUG
>>> 1000 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> one
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1032 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> EDataTypes
>>> 1047 [main] DEBUG
>>> EClasses
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> EDataTypes
>>> 1047 [main] DEBUG
>>> EClasses
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> 1047 [main] DEBUG
>>> strategy
>>> strategy
>>> 1110 [main] DEBUG
>>> 1110 [main] DEBUG
>>> DValue party.Party
>>> Table `party_party`
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
>>> 1125 [main] DEBUG
Current Time: Thu Feb 25 20:26:18 GMT 2021
Powered by FUDForum. Page generated in 0.03737 seconds
