Home » Archived » M2M (model-to-model transformation) » error lauch atl transformation programmatic - could not find model UML
error lauch atl transformation programmatic - could not find model UML [message #80613] Sat, 03 May 2008 21:05 Go to next message
Victor Hugo is currently offline Victor HugoFriend
Hi people,
i need help again..
i`m trying to run atl transformation programmatic but i get an error..
someone know where i can found an atl transformation over uml2 models? An
transformation that uses uml2 metamodel, uml2 model in, uml2 model out..
this will be great help!
HERE YOU CAN SEE MY PROPERTIES FILE:
properties
--in
IN=file:/C:/dev/MESTRADO/workspace/CrossMDAMarcelo/modelsTes t/HealthWatchers.uml2
UML2=file:/C:/dev/MESTRADO/workspace/CrossMDAMarcelo/metamod el/Superstructure.uml
EMF --in
PROFILE=file:/C:/dev/MESTRADO/workspace/CrossMDAMarcelo/mode lsTest/crossmda_profile-1.1.uml2
EMF --in
ASPECTS=file:/C:/dev/MESTRADO/workspace/CrossMDAMarcelo/mode lsTest/model_aspects.uml2
EMF
--out OUT=file:/C:\dev\MESTRADO\workspace\CrossMDAMarcelo\z_Lixo\m .xmi
EMF
--lib
MergeHelpers=file:/C:/dev/MESTRADO/workspace/CrossMDAMarcelo /lib/MergeHelpers.asm
--lib
CrossMDAHelpers=file:/C:/dev/MESTRADO/workspace/CrossMDAMarc elo/lib/CrossMDAHelpers.asm
HERE YOU CAN SEE THE OUT PRINTED AFTER LOAD MODELS:
modelId: UML2
uri =>
file:/C:/dev/MESTRADO/workspace/CrossMDAMarcelo/metamodel/Su perstructure.uml
modelId: IN
uri =>
file:/C:/dev/MESTRADO/workspace/CrossMDAMarcelo/modelsTest/H ealthWatchers.uml2
modelId: PROFILE
uri =>
file:/C:/dev/MESTRADO/workspace/CrossMDAMarcelo/modelsTest/c rossmda_profile-1.1.uml2
modelId: ASPECTS
uri =>
file:/C:/dev/MESTRADO/workspace/CrossMDAMarcelo/modelsTest/m odel_aspects.uml2
file:/C:/dev/MESTRADO/workspace/CrossMDAMarcelo/lib/MergeHel pers.asm
file:/C:/dev/MESTRADO/workspace/CrossMDAMarcelo/lib/CrossMDA Helpers.asm
HERE YOU CAN SEE THE TYPE O EACH MODEL:
PROFILE : UML2
ASPECTS : UML2
IN : UML2
UML2 : MOF
OUT : UML2
AND FINALLY, HERE YOU CAN SEE THE CONSOLE AFTER CALL
myLauncher.launch(trans, libs, models, params);
WARNING: could not find model UML.
****** BEGIN Stack Trace
exception:
at
org.atl.engine.repositories.emf4atl.ASMEMFModel.getExtent(AS MEMFModel.java:414)
at
org.atl.engine.repositories.emf4atl.ASMEMFModel.initClassifi ersInAllExtents(ASMEMFModel.java:88)
at
org.atl.engine.repositories.emf4atl.ASMEMFModel.getClassifie r(ASMEMFModel.java:68)
at
org.atl.engine.repositories.emf4atl.ASMEMFModel.findModelEle ment(ASMEMFModel.java:136)
at org.atl.engine.vm.ASMOperation.realExec(ASMOperation.java:26 5)
at org.atl.engine.vm.ASMOperation.exec(ASMOperation.java:155)
at org.atl.engine.vm.nativelib.ASMOclAny.invoke(ASMOclAny.java: 60)
at org.atl.engine.vm.nativelib.ASMOclAny.invoke(ASMOclAny.java: 50)
at org.atl.engine.vm.ASMOperation.realExec(ASMOperation.java:21 4)
at org.atl.engine.vm.ASMInterpreter.<init>(ASMInterpreter.java:276)
at org.atl.eclipse.engine.AtlLauncher.launch(AtlLauncher.java:1 23)
at org.atl.eclipse.engine.AtlLauncher.launch(AtlLauncher.java:8 3)
at org.atl.eclipse.engine.AtlLauncher.launch(AtlLauncher.java:5 8)
at org.atl.eclipse.engine.AtlLauncher.launch(AtlLauncher.java:5 4)
at org.atl.eclipse.engine.AtlLauncher.launch(AtlLauncher.java:5 0)
at
br.ufrj.nce.crossmda.transformation.engine.implementation.AT LExecute.run(ATLExecute.java:431)
at
br.ufrj.nce.crossmda.modelgenerate.PSMGenerateImpl.execute(P SMGenerateImpl.java:121)
at
br.ufrj.nce.crossmda.gui.AspectIntegrationEMF.gerarPSM(Aspec tIntegrationEMF.java:649)
at
br.ufrj.nce.crossmda.gui.AspectIntegrationEMF.access$42(Aspe ctIntegrationEMF.java:604)
at
br.ufrj.nce.crossmda.gui.AspectIntegrationEMF$28$1.run(Aspec tIntegrationEMF.java:2727)
A.main() : ??#22 null
local variables = {self=M : ASMModule}
local stack = []
A.__matcher__() : ??#1 null
local stack = []
A.__matchMergeClass() : ??#2 null
local stack = []
****** END Stack Trace
best regards :)
Re: error lauch atl transformation programmatic - could not find model UML [message #80764 is a reply to message #80613] Tue, 06 May 2008 09:38 Go to previous message
William Piers is currently offline William PiersFriend
The warning indicates : "could not find model UML"
In yout launch command, you specify the "UML2" metamodel. Could you
please check the naming in the transformation ? It must be UML2 to work.
William
Victor Hugo a écrit :
> Hi people,
> i need help again..
> An transformation that uses uml2 metamodel, uml2 model in, uml2 model
> out.. this will be great help!
> properties
> --in
> EMF --in
> EMF --in
> EMF --out
> EMF --lib
> --lib
> modelId: UML2
> uri =>
> modelId: IN
> uri =>
> modelId: PROFILE
> uri =>
> modelId: ASPECTS
> uri =>
> PROFILE : UML2
> ASPECTS : UML2
> IN : UML2
> UML2 : MOF
> OUT : UML2
> exception: java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> local stack = []
> local stack = []
> local stack = []
> best regards :)
Previous Topic:[ATL] Problem with matched rule and multiple source models
Next Topic:[ATL] Copying one model with reference to another => ClassCastException
Current Time: Sun May 24 23:34:32 GMT 2020
Powered by FUDForum. Page generated in 0.02086 seconds
