Home » Eclipse Projects » Virgo » Uses Violation: Conflicting Packages from Kernel and User Region
Re: Uses Violation: Conflicting Packages from Kernel and User Region [message #739293 is a reply to message #739252] |
Mon, 17 October 2011 10:03 |
Glyn Normington Messages: 1222 Registered: July 2009 |
Certain packages are shared from the kernel to the user region in VTS. Take a look at the user region properties file in the config directory which contains the following property:
packageImports =\
org.eclipse.virgo.kernel.artifact.*;version="0",\
org.eclipse.virgo.kernel.core;version="0",\
org.eclipse.virgo.kernel.deployer.core;version="0",\
org.eclipse.virgo.kernel.deployer.core.event;version="0",\
org.eclipse.virgo.kernel.deployer.config;version="0",\
org.eclipse.virgo.kernel.install.*;version="0",\
org.eclipse.virgo.kernel.osgi.*;version="0",\
org.eclipse.virgo.kernel.model;version="0",\
org.eclipse.virgo.kernel.model.management;version="0",\
org.eclipse.virgo.kernel.module;version="0",\
org.eclipse.virgo.kernel.serviceability;version="0",\
org.eclipse.virgo.kernel.serviceability.*;version="0",\
org.eclipse.virgo.kernel.services.work;version="0",\
org.eclipse.virgo.kernel.shell;version="0",\
org.eclipse.virgo.kernel.shell.*;version="0",\
org.eclipse.virgo.kernel.shim.*;version="0",\
org.eclipse.virgo.medic.*;version="0",\
org.eclipse.virgo.repository;version="0",\
org.eclipse.virgo.repository.*;version="0",\
org.eclipse.virgo.util.*;version="0",\
org.apache.commons.logging;version="[1.0.0,2.0.0)",\
org.apache.commons.logging.impl;version="[1.0.0,2.0.0)",\
org.aspectj.*;version="[1.6.5.RELEASE,2.0.0)",\
org.osgi.service.event;version="0",\
org.osgi.service.log;version="0",\
org.eclipse.equinox.region;version="1",\
ch.qos.logback.*;version="[0.9.24,1.0.0)",\
org.slf4j;version="[1.6.1,2)",\
org.slf4j.helpers;version="[1.6.1,2)",\
org.slf4j.spi;version="[1.6.1,2)"
Hope that helps to get you started. See the FAQ for general guidance on debugging uses constraint violations.
Current Time: Thu Apr 25 06:54:14 GMT 2024
Powered by FUDForum. Page generated in 0.03491 seconds
