Home » Archived » M2M (model-to-model transformation) » [ATL] launching a transformation programmatically using the UML2.1 metamodel
[ATL] launching a transformation programmatically using the UML2.1 metamodel [message #80143] Mon, 28 April 2008 13:39 Go to next message
Originally posted by: hdubourg.sodifrance.fr
I'd like to launch an ATL transformation from some Java code. The
transformation is KDM to UML 2.1. I've already written such a transformation
for the J2SE to KDM case which works fine.
I did test the transformation using the UML21.ecore file and the EMF
registry from within the Eclipse plugin. Both case worked fine.
However when calling the transformation from some piece of Java code,
nothing simply comes out. Here is what the code looks like:
final AtlEMFModelHandler modelHandler =
(AtlEMFModelHandler)AtlModelHandler.getDefault(AtlModelHandl er.AMH_EMF );
ASMModel mofMM = modelHandler.getMof();
//Get MModels
try{
kdmMM = modelHandler.loadModel( "kdm", mofMM, kdmMMurl.openStream());
umlMM = modelHandler.loadModel("uml2" , mofMM, umlMMurl.openStream());
}catch (IOException e){
e.printStackTrace();
//Get the kdm Model
kdmModel = modelHandler.loadModel("kdm", kdmMM , kdmModelurl.openStream());
//transform
final AtlLauncher launcher = AtlLauncher.getDefault();
final Map<String, ASMModel> models = new HashMap<String, ASMModel>();
final Map<?, ?> asmParams = Collections.EMPTY_MAP;
final List<?> superimpose = Collections.EMPTY_LIST;
final Map<?, ?> options = Collections.EMPTY_MAP;
final Map<?, ?> libs = Collections.EMPTY_MAP;
ASMModel outputInstance = modelHandler.newModel("OUT", null, umlMM);
models.put( "kdm", kdmMM );
models.put( "uml2", umlMM);
models.put( "IN", kdmModel );
models.put( "OUT", outputInstance);
launcher.launch( transformation, libs, models, asmParams, superimpose,
options );
//The save code...
When loading the UML metamodel from the ecore file, I got lots of Warning
like:
28 avr. 2008 15:28:38 org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel
addReferencedExtentsFor
ATTENTION: Resource for org.eclipse.emf.ecore.impl.EClassImpl@cdb06e
(eProxyURI:
platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore#//E ModelElement) is
null; cannot be referenced
I tried loading the UML metamodel from the EMF registry using:
umlMM =
modelHandler.loadModel("uml2",mofMM,"uri:http://www.eclipse.org/uml2/2.1.0/UML");
I then don't have any warning but still no result.
What am I doing wrong?
Thanks a lot
Hugues Dubourg
Re: [ATL] launching a transformation programmatically using the UML2.1 metamodel [message #80160 is a reply to message #80143] Mon, 28 April 2008 14:47 Go to previous messageGo to next message
Originally posted by: Hugo.Bruneliere.univ-nantes.fr
Hi Hugues,
Hugues Dubourg a écrit :
> Hello,
> //Get MModels
> try{
Have you already tried to do something like this (loading the UML2
metamodel from the EMF registry)?
umlMM = modelHandler.loadModel("uml2", mofMM,
URI.createURI("http://www.eclipse.org/uml2/2.1.0/UML"));
Do you know exactly from which line of your program comes your error?
Hugo
> //Get the kdm Model
> //transform
> options );
> //The save code...
> like:
> (eProxyURI:
> umlMM =
> Thanks a lot
> Hugues Dubourg
Hugo Bruneliere - R&D Engineer
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssiniere
44322 Nantes Cedex 3 - France
office +33 2 51 12 58 10 /\ cell.+33 6 07 42 45 30
EMail: Hugo.Bruneliere@univ-nantes.fr
http://www.sciences.univ-nantes.fr/lina/atl/
Re: [ATL] launching a transformation programmatically using the UML2.1 metamodel [message #80190 is a reply to message #80160] Mon, 28 April 2008 15:36 Go to previous messageGo to next message
Thanks for your swift response Hugo,
I tried to use the EMF registry indeed, but I specified the URI as a String
parameter:
>> umlMM =
I got no error message, but no result either.
I now have a null pointer exception whose trace is (sorry it's a bit long):
GRAVE: java.io.FileNotFoundException: http://www.eclipse.org/uml2/2.1.0/UML
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos ticWrappedException:
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadException(ResourceSetImpl.java:315)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:274)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:397)
at
org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel.loadASMEMFMo del(ASMEMFModel.java:331)
at
org.eclipse.m2m.atl.engine.AtlEMFModelHandler.loadModel(AtlE MFModelHandler.java:235)
at test.TestKDMtoUML.main(TestKDMtoUML.java:59)
Caused by: java.io.FileNotFoundException:
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(U nknown
Source)
at
org.eclipse.emf.ecore.resource.impl.URIHandlerImpl.createInp utStream(URIHandlerImpl.java:178)
at
org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterIm pl.createInputStream(ExtensibleURIConverterImpl.java:299)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1205)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:255)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:270)
.... 4 more
28 avr. 2008 17:21:39 org.eclipse.m2m.atl.engine.AtlEMFModelHandler
loadModel
GRAVE: null
at
org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel.adaptMetamod el(ASMEMFModel.java:368)
at
org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel.loadASMEMFMo del(ASMEMFModel.java:341)
at
I guess there must a problem matching the metamodel with the given URI. Do
you know where this issue could come from?
I keep debugging my Java code. If ever I make any further breakthrough, I
will let you know.
Hugues
"Hugo Bruneliere" <Hugo.Bruneliere@univ-nantes.fr> a
Re: [ATL] launching a transformation programmatically using the UML2.1 metamodel [message #80388 is a reply to message #80190] Tue, 29 April 2008 13:46 Go to previous messageGo to next message
Hi Hugues,
> parameter:
>>> umlMM =
Is the UML2 plugin (version 2.1) installed and loaded onto your Eclipse?
If another version is installed, you may try with the corresponding URI.
Hugo
> at
> at
> at
> at
> at
> Source)
> at
> at
> at
> at
> at
> ... 4 more
> loadModel
> GRAVE: null
> at
> at
> at
> will let you know.
> Hugues
> "Hugo Bruneliere" <Hugo.Bruneliere@univ-nantes.fr> a écrit dans le message
> de news: fv4o1a$hs4$1@build.eclipse.org...
>> Hi Hugues,
>>> Hello,
>>> transformation for the J2SE to KDM case which works fine.
>>> //Get MModels
>>> try{
>> Best regards,
>> Hugo
>>> //Get the kdm Model
>>> //transform
>>> options );
>>> //The save code...
>>> like:
>>> (eProxyURI:
>>> is null; cannot be referenced
>>> umlMM =
>>> Thanks a lot
>>> Hugues Dubourg
Re: [ATL] launching a transformation programmatically using the UML2.1 metamodel [message #80403 is a reply to message #80190] Tue, 29 April 2008 14:37 Go to previous messageGo to next message
Could it be the EMF registry that did not get instantiated?
If so, how can I instantiate it?
thanks
Hugues
"Hugues Dubourg" <hdubourg@sodifrance.fr> a
Re: [ATL] launching a transformation programmatically using the UML2.1 metamodel [message #80417 is a reply to message #80388] Tue, 29 April 2008 14:46 Go to previous messageGo to next message
Hi again,
I do have the UML2 plugin (version 2.1) installed and loaded.
I really can't figure out why the UML metamodel can't be loaded.
Hugues
Re: [ATL] launching a transformation programmatically using the UML2.1 metamodel [message #80555 is a reply to message #80143] Thu, 01 May 2008 19:41 Go to previous message
Victor Hugo is currently offline Victor HugoFriend
Hey man!
I`m trying to run a transformation over uml2 model but i get same erros.
I`m using emf4atl and my model in and model out are uml2.
I wanna know what atl api are you used for run the transformation. And
what types of in and out model are you using?
thanks a lot!
Previous Topic:[ATL] Generating output using two meta-models
Next Topic:[ATL] Processing GMF
Current Time: Tue Jun 18 15:55:30 GMT 2019
Powered by FUDForum. Page generated in 0.02052 seconds
