Code completion beyond 1 level [message #80084] |
Sat, 13 September 2008 10:23 |
Originally posted by: nomail.nomail.it
I don't know if this is a real limitation or something I haven't optionally
set. However the problem can be easily explaind with an example.(hope the
indentation will work).
I am very interested in having the code completion in that code working! The
reason is that some strategies for big applications rely just on this.
Imagine classes that map a DB. One can use something like PDO::FETCH_OBJ,
but the best is statically type fields in classes then using
PDO::FETCH_CLASS. In the second way, you don't have the need to skip from
code e DB (or documentation) to remember fields (so attributes) of the DB
(so DataClass). But all vanish if the code below is not working. To me,
having DB mapped without code completion is almost useless in view of coding
facilities.
Hi all!
Rik.
<?php
class class2
public $attr1,$attr2,$attr3;
class class1
public $o1;
public function __construct()
$o1=new class2;
public function assign()
//Here code completion work only for $this-> not $this->o1->
$this->o1->attr1='value attr1';
$o=new class1;
$o->assign();
//Same as above: only work for first level ($o-> not $o->o1->)
echo $o->o1->attr1;
Re: Code completion beyond 1 level [message #80136 is a reply to message #80084] |
Sun, 14 September 2008 08:08 |
Originally posted by: michael.zend.com
What version of PDT are you using?
This problem is solved PDT 2.0 nightlies.
"Rik" <nomail@nomail.it> wrote in message
news:gag488$2ao$1@build.eclipse.org...
> The reason is that some strategies for big applications rely just on this.
> coding facilities.
> Hi all!
> Rik.
> <?php
> class class2
> class class1
> public $o1;
> $o1=new class2;
> $o=new class1;
> $o->assign();
> echo $o->o1->attr1;
Re: Code completion beyond 1 level [message #80151 is a reply to message #80136] |
Sun, 14 September 2008 10:07 |
Monstruously great!
Gonna try!!!!!! :-)
Thanks.
Rik.
"Michael Spector" <michael@zend.com> ha scritto nel messaggio
news:gaignf$vst$1@build.eclipse.org...
>>optionally set. However the problem can be easily explaind with an
>>example.(hope the indentation will work).
>> this. Imagine classes that map a DB. One can use something like
>> PDO::FETCH_OBJ, but the best is statically type fields in classes then
>> using PDO::FETCH_CLASS. In the second way, you don't have the need to
>> skip from code e DB (or documentation) to remember fields (so attributes)
>> of the DB (so DataClass). But all vanish if the code below is not
>> working. To me, having DB mapped without code completion is almost
>> useless in view of coding facilities.
>> Hi all!
>> Rik.
>> <?php
>> class class2
>> class class1
>> public $o1;
>> $o1=new class2;
>> $o=new class1;
>> $o->assign();
>> echo $o->o1->attr1;
Re: Code completion beyond 1 level [message #80166 is a reply to message #80136] |
Sun, 14 September 2008 16:21 |
I confirm: It works! :-)
It's a little tricky to install the 2.0 but finally the result worth the
effort!
Rik
>> Hi all!
>> Rik.
>> <?php
>> class class2
>> class class1
>> public $o1;
>> $o1=new class2;
>> $o=new class1;
>> $o->assign();
>> echo $o->o1->attr1;
FUDForum. Page generated in 0.02976 seconds
