Re: Eclipse Testing Framework [message #98098 is a reply to message #79963] |
Mon, 07 May 2007 11:49 |
Paul Slauenwhite Messages: 975 Registered: July 2009 |
Darren,
Please post your question to the Eclipse project (eclipse.platform)
newsgroup since the Eclipse Testing Framework is part of the Eclipse
Platform.
Paul
"Darren Hurt" <darren.hurt@coexis.com> wrote in message
news:eb73nr$a4j$1@utils.eclipse.org...
> This may not be the correct place to post this, as it refers to the
> for testing plug-ins rather than TPTP.
> However, I thought I'd give it a try.
> I am trying to use the Eclipse Testing Framework to run tests on a plug-in
> I
> have written.
> I am using Eclipse 3.1.1.
> I have taken the proper versions of the various plug-ins and feature
> The relevent features and plug-ins have the following structure in my
> eclipse
> eclipse
> features
> org.eclipse.test_3.1.0
> plugins
> org.eclipse.test
> org.eclipse.test.performance.win32_3.1.0
> org.eclipse.test.performance_3.1.0
> org.eclipse.test.source_3.1.0
> myplugin
> myplugin.tests
> (they are all 3.1.0 versions, but the foldername for org.eclipse.test does
> not include the version due to the ugly reference to the library.xml in
> the
> tests.xml files).
> My tests are contained in a seperate plug-in of their own (myplugin.tests)
> that depends on the plug-in of mine that they are testing (myplugin).
> My plug-in has its own tests.xml file (see bottom of this message).
> I have tried invoking my tests in two seperate ways (as indicated in the
> testframework.html document)
> java -jar startup.jar -application org.eclipse.test.uitestapplication -dev
> bin -testlistener org.eclipse.test.XMLTestListener -testpluginname
> myplugin.tests-classname myplugin.AllTests
> org.eclipse.ant.core.antRunner -buildfile
> plugins\mypluins.tests\test.xml -Declipse-home=%ECLIPSE_HOME%.
> I get strange results with both approaches.
> With the first approach I get class not found exceptions that are
> different
> each time I try to run it.
> With the second approach I get a stack trace as below.
> My plugin does have the correct classpath and runs ok.
> Also, I'm pretty sure my test plug-in has the correct dependencies (it
> only
> depends on the org.junit plug-in and the plug-in i'm testing).
> Does anyone have any idea what I am doing wrong, and more to the point,
> what
> I need to do to make this work?
> [java] org.osgi.framework.BundleException: The activator
> org.eclipse.ui.internal.WorkbenchPlugin for bundle
> org.eclipse.ui.workbench
> is invalid
> [java] at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:149)
> [java] at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:965)
> [java] at
> org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:313)
> [java] at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:264)
> [java] at
> org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:116)
> [java] at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:337)
> [java] at
> org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
> [java] at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:386)
> [java] at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:350)
> [java] at
> org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:78)
> [java] at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
> [java] at
> java.lang.ClassLoader.loadClassInternal(ClassLoader.java:302 )
> [java] at java.lang.ClassLoader.defineClass0(Native Method)
> [java] at java.lang.ClassLoader.defineClass(ClassLoader.java:537)
> [java] at
> org.eclipse.osgi.framework.adaptor.core.DefaultClassLoader.d efineClass(DefaultClassLoader.java:370)
> [java] at
> org.eclipse.core.runtime.adaptor.EclipseClassLoader.defineCl ass(EclipseClassLoader.java:233)
> [java] at
> org.eclipse.osgi.framework.adaptor.core.DefaultClassLoader.f indClassImpl(DefaultClassLoader.java:343)
> [java] at
> org.eclipse.osgi.framework.adaptor.core.DefaultClassLoader.f indClass(DefaultClassLoader.java:235)
> [java] at
> org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. findLocalClass(AbstractClassLoader.java:183)
> [java] at
> org.eclipse.core.runtime.adaptor.EclipseClassLoader.basicFin dLocalClass(EclipseClassLoader.java:141)
> [java] at
> org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:122)
> [java] at
> [java] at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:389)
> [java] at
> [java] at
> [java] at
> org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:275)
> [java] at
> org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
> [java] at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1248)
> [java] at
> org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:152)
> [java] at
> org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:142)
> [java] at
> org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:129)
> [java] at
> org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 48)
> [java] at
> org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:222)
> [java] at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
> [java] at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
> [java] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native
> Method)
> [java] at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
> [java] at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
> [java] at java.lang.reflect.Method.invoke(Method.java:324)
> [java] at
> org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
> [java] at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
> [java] at org.eclipse.core.launcher.Main.run(Main.java:973)
> [java] at org.eclipse.core.launcher.Main.main(Main.java:948)
> [java] Caused by: java.lang.NoClassDefFoundError:
> org/eclipse/swt/SWTError
> [java] at java.lang.Class.getDeclaredConstructors0(Native Method)
> [java] at
> java.lang.Class.privateGetDeclaredConstructors(Class.java:16 10)
> [java] at java.lang.Class.getConstructor0(Class.java:1922)
> [java] at java.lang.Class.newInstance0(Class.java:278)
> [java] at java.lang.Class.newInstance(Class.java:261)
> [java] at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:144)
> [java] ... 43 more
> [java] Root exception:
> [java] java.lang.NoClassDefFoundError: org/eclipse/swt/SWTError
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> Method)
> [java] at
> [java] at
> [java] at
> [java] !ENTRY org.eclipse.osgi 2006-08-04 17:18:37.549
> [java] !MESSAGE Application error
> [java] !STACK 1
> [java] org.eclipse.core.runtime.CoreException[1]:
> java.lang.NoClassDefFoundError: org/eclipse/ui/testing/ITestHarness
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> Method)
> [java] at
> [java] at
> [java] at
> [java] !ENTRY org.eclipse.osgi 2006-08-04 17:18:37.674
> [java] !MESSAGE Bundle
> update@plugins/org.eclipse.core.resources.win32_3.1.0.jar [52] was not
> resolved.
> [java] !ENTRY org.eclipse.osgi 2006-08-04 17:18:37.706
> update@plugins/org.eclipse.swt.win32.win32.x86_3.1.1.jar [214] was not
> resolved.
> [java] !MESSAGE Bundle update@plugins/org.eclipse.ui.win32_3.1.0.jar
> [234] was not resolved.
> [java] !ENTRY org.eclipse.osgi 2006-08-04 17:18:37.721
> update@plugins/org.eclipse.update.core.win32_3.1.0.jar [240] was not
> resolved.
> [java] Java Result: 13
> cleanup:
> run:
> <project name="testsuite" default="run" basedir=".">
> <property name="eclipse-home" value="${basedir}/../../" />
> <property name="plugin-name" value="myplugin.tests"/>
> <property name="library-file"
> value="${eclipse-home}/plugins/org.eclipse.test/library.xml "/>
> <target name="init">
> <tstamp/>
> <delete>
> <fileset dir="${eclipse-home}" includes="org*.xml"/>
> </delete>
> </target>
> <target name="suite">
> <property name="myfolder" value="${eclipse-home}/myfolder"/>
> <delete dir="${myfolder}" quiet="true"/>
> <ant target="ui-test" antfile="${library-file}" dir="${eclipse-home}">
> <property name="data-dir" value="${myfolder}"/>
> <property name="plugin-name" value="${plugin-name}"/>
> <property name="classname" value="myplugin.tests.AllTests"/>
> </ant>
> </target>
> <target name="cleanup">
> </target>
> <target name="run" depends="init,suite,cleanup">
> <ant target="collect" antfile="${library-file}" dir="${eclipse-home}">
> <property name="includes" value="org*.xml"/>
> <property name="output-file" value="${plugin-name}.xml"/>
> </ant>
> </target>
> <!-- This target runs the performance test suites. -->
> <target name="performance">
> </target>
> </project>
FUDForum. Page generated in 0.03217 seconds
