Re: Download and Install BPMN [message #7270 is a reply to message #7248] |
Wed, 04 February 2009 06:50 |
Originally posted by: atoulme.intalio.com
sanjay wrote:
> Thanks. I was able to install BPMN. Is there a tutorial out there which
> I could use to learn BPMN?
> Sanjay
I'm doing a webinar next week. Otherwise to get intimate with BPMN, you
should use Google. There is plenty of information online.
Antoine
Re: Download and Install BPMN [message #8043 is a reply to message #7979] |
Wed, 04 February 2009 17:45 |
Felix wrote:
>> you should use Google. There is plenty of information online.
> That sounds great. I would like to join this webinar. Is it for free? Or
> could I download it somewhere later?
It's free and you can watch it later. Thanks for your interest. I still
need to prepare it...
> ciao Felix
Re: Download and Install BPMN [message #8353 is a reply to message #8321] |
Thu, 12 February 2009 22:35 |
It looks like a SCA Tools related error. Do you have SCA installed ? Are
you running the BPMN editor or the SCA editor ?
Antoine
sanjay wrote:
> I'm trying to run BPMN sample - Restaurent. I get following error when I
> try to run :
> Exception in thread "main" java.lang.Error: Unresolved compilation
> problems: SCADomain cannot be resolved to a type
> How do I fix this? Do I have to configure additional libs? Any pointers
> to get me started on running samples would help.
> Sanjay
Re: Download and Install BPMN [message #8446 is a reply to message #8385] |
Fri, 13 February 2009 09:37 |
That should be it. See Jonathan's message, it should help.
sanjay wrote:
> Hi Antoine,
> I am new to BPMN world and trying to run my first hello world BPMN.
> I installed eclipse sdk 3.4.1 and configured:
> http://download.eclipse.org/stp/updates/releases/1.0.1.20080 9261307/site.xml
> If you could provide me instructions on how to get started with my first
> hello world that would be great. I have been googling but unable to get
> much success.
> Thanks for all of your help.
> Sanjay
Re: Download and Install BPMN [message #8477 is a reply to message #8446] |
Fri, 13 February 2009 09:38 |
Edit: I meant Stephane. Need more caffeine here...
> sanjay wrote:
>> Hi Antoine,
>> much success.
>> Sanjay
Re: Download and Install BPMN [message #524479 is a reply to message #518155] |
Thu, 01 April 2010 06:30 |
On 3/3/10 2:11 AM, Xiaofeng Liu wrote:
> 9261307/site.xml
> it seems the website has some problem.
> I tried to install with copying the plugin into plugin directory, but
> failed. Do you know some other way that I can Install this plugin?
> Thank you very much!
You can use the Helios update site for the latest bits.
Re: Download and Install BPMN [message #547243 is a reply to message #7154] |
Fri, 16 July 2010 05:58 |
Verena Messages: 17 Registered: July 2009 |
I'm running Helios(J2ee-version) under Linux, but I guess that should not be a problem.
The other thing I did in a different way than you, was the installation. I did not use the explicit update site but the normal Helios update site. The BPMN feature is also listed there, so you need not to add a new URL to the software update. Maybe you could try uninstalling the Plugin and install it via:
Helios - http://download.eclipse.org/releases/helios
Now I remember, that I had the same problem several version before, but I can't remember what I did. I probably switched to another version.
Try the galileo version...
[Updated on: Fri, 16 July 2010 05:59] Report message to a moderator
FUDForum. Page generated in 0.04411 seconds
