Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » ClassCastExeption with Elistwrapper
ClassCastExeption with Elistwrapper [message #79914] |
Mon, 16 April 2007 16:12 |
Originally posted by: daniel.bret.w.wanadoo.fr
hi,
I get an error when I try to update a record in the database (but no problem
to add a new one ?)
Data access failure: Could not invoke JDO makePersistent(Object) method;
nested exception is java.lang.ClassCastException:
org.eclipse.emf.teneo.jpox.elist.EListWrapper$1
org.springframework.dao.InvalidDataAccessResourceUsageExcept ion: Could not
invoke JDO makePersistent(Object) method; nested exception is
org.eclipse.emf.teneo.jpox.elist.EListWrapper$1 at
org.eclipse.emf.teneo.jpox.elist.EListWrapper.attachCopy(ELi stWrapper.java:431)
at
org.jpox.state.AttachFieldManager.storeObjectField(AttachFie ldManager.java:157)
at
org.jpox.state.StateManagerImpl.providedObjectField(StateMan agerImpl.java:2748)
at org.MyClassImpl.jdoProvideField(MyClassImpl.java) at....
the error is a ClassCastException thrown from the spring webcontainer method
public class JdoTemplate extends JdoAccessor implements JdoOperations {
public void makePersistent(final Object entity) throws DataAccessException {
execute(new JdoCallback() {
public Object doInJdo(PersistenceManager pm) throws JDOException {
try {
return makePersistentMethod.invoke(pm, new Object[] {entity});
catch (InvocationTargetException ex) {
throw new InvalidDataAccessResourceUsageException(
"Could not invoke JDO makePersistent(Object) method",
ex.getTargetException());
and the eclipse debugger seems to say that there is a nullPointerException
in the EListWrapper attachCopy method execution :
public class EListWrapper<E> extends PersistableEList<E> implements SCO,
Queryable, SCOList {
public void attachCopy(Object value) {
// if not loaded then nothing changed so nothing to attach
assert (value instanceof PersistableEList);
if (!((PersistableEList) value).isLoaded())
return;
because "binding error on value"... which is null ("binding ==null for
value")
but the call, from the org.jpox.state.StateManager to the teneo sco class
(ElistWapper) seems to be good
public class AttachFieldManager extends AbstractFieldManager
public void storeObjectField(int fieldNumber, Object value)
sco.attachCopy(value);
sco and value are ElistWapper$1, empty but not null
the teneo log seems to be good :
15:53:55,625 (http-8080-Processor23) DEBUG
[org.eclipse.emf.teneo.mapping.elist.PersistableEList] - Loading EList of
type: org.eclipse.emf.teneo.jpox.elist.EListWrapper of member myField (that
cause the error) owned by MyClass with delegate list java.util.ArrayList
I use Eclipse3.2, EMF 2.2.2, teneo : emft-teneo-SDK-I200703301643, Jpox1.3
(to stay compatible withe Spring 1.2.X for syntax reason), Spring 1.2.8.
I've tried with Eclipse3.3, EMF 2.3, teneo : emft-teneo-SDK-I200703301643
etc... and that's the same
To be able to send you an example to reproduce to problem, I'tried to shrink
my webapp to the 3 or 4 classes with the field which cause the error... but
in this case, I have no error...?
I don't know where to search the error
Daniel
Re: ClassCastExeption with Elistwrapper [message #79929 is a reply to message #79914] |
Mon, 16 April 2007 18:07 |
Hi Daniel,
Is it a nullpointerexception or a classcastexception (you mention both)?
You can't upgrade to jpox 1.1.7?
Which line in elistwrapper does it happen (my line 431 in cvs seems to be iter.hasNext which I can't
imagine to be the cause of the classcastexception)?
gr. Martin
daniel wrote:
> hi,
> to add a new one ?)
> at
> at
> try {
> return;
> value")
> Thanks
> Daniel
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: ClassCastExeption with Elistwrapper [message #79946 is a reply to message #79929] |
Mon, 16 April 2007 21:21 |
------=_NextPart_000_0007_01C7807E.16D4ADE0
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
hi Martin
it happens like this :
a ClassCastException is thrown from the spring webcontainer method, by =
the catch
public void makePersistent(final Object entity) throws =
try { ///// this try fails so the following catch send the =
ClassCastException
(1) return makePersistentMethod.invoke(pm, new Object[] {entity});
catch (InvocationTargetException ex) { ///send the ClassCastException =20
"Could not invoke JDO makePersistent(Object) method", =
but the call within this try (1) ("return =
makePersistentMethod.invoke(pm, new Object[] {entity});") fails =
because... according to the Eclipse debugger, =20
a nullPointerException occur in the EListWrapper attachCopy method =
execution, (=3D=3D> called by the "makePersistentMethod.invoke" )
and the line 431 is "if (!((PersistableEList) value).isLoaded())"=20
public class EListWrapper<E> extends PersistableEList<E> implements SCO, =
line430 >> assert (value instanceof PersistableEList);
line431 >> if (!((PersistableEList) value).isLoaded())=20
return;
upgrade to jpox 1.1.7? I've read somewhere in Jpox forum that "above =
Jpox 113 only Spring 2 is compatible and I didn't want to change my jsp =
code for the spring 2 forms syntax...
but, I just try with jpox117 and...=20
1- it doesn't seem to make problems with spring forms syntax, at first =
look...
2- error messages from the eclipse debugger is a bit clearer :
for line 430 execution : >> value instanceof PersistableEList"=3D false=20
for line 431 execution : >> ClassCastException: Cannot cast =
org.eclipse.emf.teneo.jpox.elist.EListWrapper$1 (id=3D217) to =
org.eclipse.emf.teneo.mapping.elist.PersistableEList=20
gr. Daniel
"Martin Taal" <mtaal@elver.org> a =E9crit dans le message de news: =
f00e1v$88a$1@build.eclipse.org...
> Hi Daniel,
> Is it a nullpointerexception or a classcastexception (you mention =
both)?
>=20
> Which line in elistwrapper does it happen (my line 431 in cvs seems to =
be iter.hasNext which I can't=20
>=20
> gr. Martin
>=20
> daniel wrote:
>> hi,
>> I get an error when I try to update a record in the database (but no =
problem=20
>> to add a new one ?)
>> Data access failure: Could not invoke JDO makePersistent(Object) =
method;=20
>> nested exception is java.lang.ClassCastException:=20
>> org.springframework.dao.InvalidDataAccessResourceUsageExcept ion: =
Could not=20
>> invoke JDO makePersistent(Object) method; nested exception is=20
>> org.eclipse.emf.teneo.jpox.elist.EListWrapper$1=20
>> org.eclipse.emf.teneo.jpox.elist.EListWrapper$1 at=20
org.eclipse.emf.teneo.jpox.elist.EListWrapper.attachCopy(ELi stWrapper.jav=
a:431)=20
>> at=20
org.jpox.state.AttachFieldManager.storeObjectField(AttachFie ldManager.jav=
a:157)=20
>> at=20
org.jpox.state.StateManagerImpl.providedObjectField(StateMan agerImpl.java=
:2748)=20
>>=20
>> the error is a ClassCastException thrown from the spring webcontainer =
method
>> public class JdoTemplate extends JdoAccessor implements JdoOperations =
>> try {
>> "Could not invoke JDO makePersistent(Object) method",=20
>>=20
>> and the eclipse debugger seems to say that there is a =
nullPointerException=20
>> public class EListWrapper<E> extends PersistableEList<E> implements =
SCO,=20
>> return;
=3D=3Dnull for=20
>> value")
>>=20
>> but the call, from the org.jpox.state.StateManager to the teneo sco =
class=20
>>=20
>> 15:53:55,625 (http-8080-Processor23) DEBUG=20
>> [org.eclipse.emf.teneo.mapping.elist.PersistableEList] - Loading =
EList of=20
>> type: org.eclipse.emf.teneo.jpox.elist.EListWrapper of member myField =
(that=20
>> cause the error) owned by MyClass with delegate list =
java.util.ArrayList
>> I use Eclipse3.2, EMF 2.2.2, teneo : emft-teneo-SDK-I200703301643, =
Jpox1.3=20
>> (to stay compatible withe Spring 1.2.X for syntax reason), Spring =
1.2.8.
>> I've tried with Eclipse3.3, EMF 2.3, teneo : =
emft-teneo-SDK-I200703301643=20
>>=20
>> To be able to send you an example to reproduce to problem, I'tried to =
shrink=20
>> my webapp to the 3 or 4 classes with the field which cause the =
error... but=20
>>=20
>> Thanks
>> Daniel=20
>>=20
>>=20
>=20
>=20
> --=20
>=20
>=20
> The Netherlands
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.6000.16414" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2>hi Martin</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>it happens like this :</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>a ClassCastException is thrown =
from the spring=20
webcontainer method, by the catch</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>public class JdoTemplate extends =
JdoAccessor=20
implements JdoOperations {</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>.....</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>public void makePersistent(final Object =
entity)=20
throws DataAccessException {</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>execute(new JdoCallback() =
{</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>public Object =
doInJdo(PersistenceManager pm) throws=20
JDOException {</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>try { <FONT color=3D#ff0000>///// this =
try fails so=20
the following catch send the ClassCastException</FONT></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>(1) return =
makePersistentMethod.invoke(pm, new=20
Object[] {entity});</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>}</FONT></DIV>
<DIV><FONT face=3DArial size=3D2><FONT color=3D#ff0000>catch</FONT>=20
(InvocationTargetException ex) { ///send the=20
ClassCastException</FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>throw new=20
InvalidDataAccessResourceUsageException(</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>"Could not invoke JDO =
makePersistent(Object)=20
method", ex.getTargetException());</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>......</FONT></DIV>
<P><FONT face=3DArial size=3D2></FONT> </P>
<DIV><FONT face=3DArial size=3D2>but the call within this try (1) =
("return=20
because...=20
according to the Eclipse debugger, </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>a nullPointerException occur in the =
EListWrapper=20
attachCopy method execution, (=3D=3D> called by=20
the "makePersistentMethod.invoke" )</FONT ></DIV>
<DIV><FONT face=3DArial size=3D2>and the line 431 is "if =
(!((PersistableEList)=20
value).isLoaded())" </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>public class EListWrapper<E> =
extends=20
PersistableEList<E> implements SCO, Queryable, SCOList =
{</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>....</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>public void attachCopy(Object value) =
{</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>// if not loaded then nothing changed =
so nothing to=20
attach</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>line430 >> assert (value =
instanceof=20
PersistableEList);</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>line431 >> if =
value).isLoaded()) </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>return;</FONT></DIV>
<P><FONT face=3DArial size=3D2>upgrade to jpox 1.1.7? I've read =
somewhere in Jpox=20
forum that "above Jpox 113 only Spring 2 is compatible and I didn't want =
to=20
change my jsp code for the spring 2 forms syntax...</FONT></P>
<P><FONT face=3DArial size=3D2>but, I just try with jpox117 and... =
</FONT></P>
<DIV><FONT face=3DArial size=3D2>1- it doesn't seem to make problems =
with spring=20
forms syntax, at first look...</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>2- error messages from the eclipse =
debugger is a=20
bit clearer :</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>for line 430 execution : >> <FONT =
color=3D#ff0000><STRONG>value instanceof PersistableEList"=3D=20
false</STRONG></FONT> </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>for line 431 execution : >> <FONT =
color=3D#ff0000><STRONG>ClassCastException: Cannot cast=20
org.eclipse.emf.teneo.jpox.elist.EListWrapper$1 (id=3D217) to=20
org.eclipse.emf.teneo.mapping.elist.PersistableEList</STRONG ></FONT> =
;<BR></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>gr. Daniel</FONT></DIV>
<DIV><FONT face=3DArial size=3D2> </DIV>
<DIV><BR></DIV></FONT>
<DIV><FONT face=3DArial size=3D2>"Martin Taal" <</FONT><A=20
href=3D"mailto:mtaal@elver.org"><FONT face=3DArial=20
size=3D2>mtaal@elver.org</FONT></A><FONT face=3DArial size=3D2>> a =
=E9crit dans le=20
message de news: </FONT><A =
href=3D"mailto:f00e1v$88a$1@build.eclipse.org"><FONT=20
face=3DArial size=3D2>f00e1v$88a$1@build.eclipse.org</FONT></A><FONT =
face=3DArial=20
size=3D2>...</FONT></DIV><FONT face=3DArial size=3D2>> Hi =
Daniel,<BR>> Is it a=20
nullpointerexception or a classcastexception (you mention both)?<BR>> =
You=20
can't upgrade to jpox 1.1.7?<BR>> <BR>> Which line in elistwrapper =
does it=20
happen (my line 431 in cvs seems to be iter.hasNext which I can't =
<BR>>=20
imagine to be the cause of the classcastexception)?<BR>> <BR>> gr. =
Martin<BR>> <BR>> daniel wrote:<BR>>> hi,<BR>>> I get =
an error=20
when I try to update a record in the database (but no problem =
<BR>>> to=20
add a new one ?)<BR>>> Data access failure: Could not invoke JDO=20
makePersistent(Object) method; <BR>>> nested exception is=20
java.lang.ClassCastException: <BR>>>=20
org.eclipse.emf.teneo.jpox.elist.EListWrapper$1<BR>>>=20
org.springframework.dao.InvalidDataAccessResourceUsageExcept ion: Could =
not=20
<BR>>> invoke JDO makePersistent(Object) method; nested exception =
is=20
<BR>>> java.lang.ClassCastException: <BR>>>=20
org.eclipse.emf.teneo.jpox.elist.EListWrapper$1 <BR>>>=20
org.eclipse.emf.teneo.jpox.elist.EListWrapper$1 at <BR>>>=20
a:431)=20
<BR>>> at <BR>>>=20
a:157)=20
<BR>>> at <BR>>>=20
:2748)=20
<BR>>> at org.MyClassImpl.jdoProvideField(MyClassImpl.java)=20
at....<BR>>> <BR>>> the error is a ClassCastException thrown =
from=20
the spring webcontainer method<BR>>> public class JdoTemplate =
extends=20
JdoAccessor implements JdoOperations {<BR>>> ......<BR>>> =
public=20
void makePersistent(final Object entity) throws DataAccessException=20
{<BR>>> execute(new JdoCallback() {<BR>>> public Object=20
doInJdo(PersistenceManager pm) throws JDOException {<BR>>> try=20
{<BR>>> return makePersistentMethod.invoke(pm, new Object[]=20
{entity});<BR>>> }<BR>>> catch (InvocationTargetException =
ex)=20
{<BR>>> throw new =
InvalidDataAccessResourceUsageException(<BR>>>=20
"Could not invoke JDO makePersistent(Object) method", <BR>>>=20
ex.getTargetException());<BR>>> .......<BR>>> <BR>>> =
and the=20
eclipse debugger seems to say that there is a nullPointerException =
<BR>>>=20
in the EListWrapper attachCopy method execution :<BR>>> public =
class=20
EListWrapper<E> extends PersistableEList<E> implements SCO,=20
<BR>>> Queryable, SCOList {<BR>>> .....<BR>>> public =
void=20
attachCopy(Object value) {<BR>>> // if not loaded then nothing =
changed so=20
nothing to attach<BR>>> assert (value instanceof=20
PersistableEList);<BR>>> if (!((PersistableEList)=20
value).isLoaded())<BR>>> return;<BR>>> .....<BR>>> =
because=20
"binding error on value"... which is null ("binding =3D=3Dnull for =
<BR>>>=20
value")<BR>>> <BR>>> but the call, from the=20
org.jpox.state.StateManager to the teneo sco class <BR>>> =
(ElistWapper)=20
seems to be good<BR>>> public class AttachFieldManager extends=20
AbstractFieldManager<BR>>> {<BR>>> ......<BR>>> public =
void=20
storeObjectField(int fieldNumber, Object value)<BR>>> =
{<BR>>>=20
.......<BR>>> sco.attachCopy(value);<BR>>> ......<BR>>> =
sco and=20
value are ElistWapper$1, empty but not null<BR>>> <BR>>> the =
teneo=20
log seems to be good :<BR>>> ....<BR>>> 15:53:55,625=20
(http-8080-Processor23) DEBUG <BR>>>=20
[org.eclipse.emf.teneo.mapping.elist.PersistableEList] - Loading EList =
of=20
<BR>>> type: org.eclipse.emf.teneo.jpox.elist.EListWrapper of =
member=20
myField (that <BR>>> cause the error) owned by MyClass with =
delegate list=20
java.util.ArrayList<BR>>> ....<BR>>> I use Eclipse3.2, EMF =
2.2.2,=20
teneo : emft-teneo-SDK-I200703301643, Jpox1.3 <BR>>> (to stay =
compatible=20
withe Spring 1.2.X for syntax reason), Spring 1.2.8.<BR>>> I've =
tried with=20
Eclipse3.3, EMF 2.3, teneo : emft-teneo-SDK-I200703301643 <BR>>> =
etc...=20
and that's the same<BR>>> <BR>>> To be able to send you an =
example=20
to reproduce to problem, I'tried to shrink <BR>>> my webapp to the =
3 or 4=20
classes with the field which cause the error... but <BR>>> in this =
case, I=20
have no error...?<BR>>> I don't know where to search the =
error<BR>>>=20
<BR>>> Thanks<BR>>> Daniel <BR>>> <BR>>> =
<BR>>=20
<BR>> <BR>> -- <BR>> <BR>> With Regards, Martin Taal<BR>> =
<BR>> Springsite/Elver.org<BR>> Office: Hardwareweg 4, 3821 BV=20
Amersfoort<BR>> Postal: Nassaulaan 7, 3941 EC Doorn<BR>> The=20
Netherlands<BR>> Tel: +31 (0)84 420 2397<BR>> Fax: +31 (0)84 225=20
9307<BR>> Mail: </FONT><A href=3D"mailto:mtaal@springsite.com"><FONT =
face=3DArial=20
size=3D2>mtaal@springsite.com</FONT></A><FONT face=3DArial size=3D2> - =
</FONT><A=20
size=3D2>mtaal@elver.org</FONT></A><BR><FONT face=3DArial size=3D2>> =
Web: </FONT><A=20
href=3D"http://www.springsite.com"><FONT face=3DArial=20
size=3D2>www.springsite.com</FONT></A><FONT face=3DArial size=3D2> - =
</FONT><A=20
href=3D"http://www.elver.org"><FONT face=3DArial=20
size=3D2>www.elver.org</FONT></A></BODY></HTML>
------=_NextPart_000_0007_01C7807E.16D4ADE0--
Re: ClassCastExeption with Elistwrapper [message #79960 is a reply to message #79946] |
Mon, 16 April 2007 21:45 |
Hi Daniel,
Was the instance (EListWrapper$1) created before in a call to detachcopy?
If so then this is a bug and the class casting should not happen in the attachcopy (or the
classcasting should only happen after checking that the instance is a PersistableEList.
You can file a bugzilla for this.
gr. Martin
daniel wrote:
> hi Martin
> the catch
> ClassCastException
> execution, (==> called by the "makePersistentMethod.invoke" )
> return;
> look...
> for line 430 execution : >> *value instanceof PersistableEList"= false*
> for line 431 execution : >> *ClassCastException: Cannot cast
> org.eclipse.emf.teneo.jpox.elist.EListWrapper$1 (id=217) to
> org.eclipse.emf.teneo.mapping.elist.PersistableEList*
> gr. Daniel
> "Martin Taal" <mtaal@elver.org <mailto:mtaal@elver.org>> a écrit dans le
> message de news: f00e1v$88a$1@build.eclipse.org
> <mailto:f00e1v$88a$1@build.eclipse.org>...
> > Hi Daniel,
> > gr. Martin
> > daniel wrote:
> >> hi,
> problem
> >> to add a new one ?)
> method;
> Could not
> >> at
> >> at
> webcontainer method
> >> try {
> SCO,
> >> return;
> >> value")
> class
> EList of
> myField (that
> Jpox1.3
> to shrink
> error... but
> >> Thanks
> >> Daniel
> > The Netherlands
> > Mail: mtaal@springsite.com <mailto:mtaal@springsite.com> -
> > Web: www.springsite.com <http://www.springsite.com> - www.elver.org
> <http://www.elver.org>
The Netherlands
Re: ClassCastExeption with Elistwrapper [message #79993 is a reply to message #79960] |
Tue, 17 April 2007 08:59 |
Hi Martin
the instance (EListWrapper$1) seems to be created in the
KanPatientImpl.jdoProvideField(int) method execution (uneasy because jdo
method are not accessible by debugger) (see jpg debug_01)
after that, the call to EListWrapper seems to be good, with real instance
(not null) (see jpg debug_02)
ant finaly, in the EListWrapper.attachCopy(object) :
1- the "assert (value instanceof PersistableEList);" should send an
exception whereas "value instanceof PersistableEList"= false, shouldn't it ?
2- why value instanceof PersistableEList"= false and why the value
(EListWrapper$1 (id=xxx) cannot be cast to PersistableEList if EListWrapper
is a subclass of PersistableEList (public class EListWrapper<E> extends
PersistableEList<E>.) ? (see jpg debug_03)
I can report that on Eclipse bugzilla EMFT, if you like
gr. Daniel
Attachment: debug_01.jpg
(Size: 130.51KB, Downloaded 136 times) -
Attachment: debug_02.jpg
(Size: 150.76KB, Downloaded 138 times) -
Attachment: debug_03.jpg
(Size: 114.49KB, Downloaded 164 times)
Re: ClassCastExeption with Elistwrapper [message #80024 is a reply to message #79993] |
Tue, 17 April 2007 13:52 |
Hi Daniel,
Afaik the EListWrapper$1 is not the EListWrapper itself but an anonymous inner class. My guess is
that this one is created in the detachCopy method (you can try by setting a breakpoint there). So
the attachcopy method check on PersistableEList should also check if the type is a PersistableEList
and only check isloaded in that case and allow other cases to pass on.
Can you enter a bugzilla for this?
gr. Martin
daniel wrote:
> Hi Martin
> gr. Daniel
> "Martin Taal" <mtaal@elver.org> a écrit dans le message de news:
> f00qqi$q1e$1@build.eclipse.org...
>> Hi Daniel,
>> attachcopy (or the
>> PersistableEList.
>> gr. Martin
>> daniel wrote:
>>> hi Martin
>>> the catch
>>> ClassCastException
>>> return;
>>> look...
>>> gr. Daniel
>>> > Hi Daniel,
>>> both)?
>>> > gr. Martin
>>> > daniel wrote:
>>> >> hi,
>>> problem
>>> >> to add a new one ?)
>>> method;
>>> Could not
>>> >> at
>>> >> at
>>> webcontainer method
>>> >> try {
>>> SCO,
>>> >> return;
>>> for
>>> >> value")
>>> class
>>> EList of
>>> myField (that
>>> java.util.ArrayList
>>> Jpox1.3
>>> 1.2.8.
>>> to shrink
>>> error... but
>>> >> Thanks
>>> >> Daniel
>>> > The Netherlands
>> The Netherlands
The Netherlands
Re: ClassCastExeption with Elistwrapper [message #604761 is a reply to message #79914] |
Hi Daniel,
gr. Martin
daniel wrote:
> hi,
> to add a new one ?)
> at
> at
> try {
> return;
> value")
> Thanks
> Daniel
The Netherlands
Re: ClassCastExeption with Elistwrapper [message #604764 is a reply to message #79929] |
daniel Messages: 17 Registered: July 2009 |
hi Martin
the catch
ClassCastException
return;
look...
gr. Daniel
> Hi Daniel,
both)?
>=20
>=20
> gr. Martin
>=20
> daniel wrote:
>> hi,
problem=20
>> to add a new one ?)
method;=20
Could not=20
a:431)=20
>> at=20
a:157)=20
>> at=20
:2748)=20
>>=20
method
>> try {
>>=20
SCO,=20
>> return;
=3D=3Dnull for=20
>> value")
>>=20
class=20
>>=20
EList of=20
(that=20
java.util.ArrayList
Jpox1.3=20
1.2.8.
>>=20
shrink=20
error... but=20
>>=20
>> Thanks
>> Daniel=20
>>=20
>>=20
>=20
>=20
> --=20
>=20
>=20
> The Netherlands
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
<BODY>
from the spring=20
JdoAccessor=20
entity)=20
{</FONT></DIV>
try fails so=20
("return=20
because...=20
EListWrapper=20
extends=20
{</FONT></DIV>
{</FONT></DIV>
so nothing to=20
attach</FONT></DIV>
instanceof=20
to=20
</FONT></P>
with spring=20
debugger is a=20
;<BR></FONT></DIV>
=E9crit dans le=20
face=3DArial=20
You=20
does it=20
<BR>>=20
an error=20
<BR>>> to=20
not=20
is=20
a:431)=20
<BR>>> at <BR>>>=20
a:157)=20
<BR>>> at <BR>>>=20
:2748)=20
from=20
extends=20
public=20
ex)=20
{<BR>>> throw new =
and the=20
<BR>>>=20
class=20
void=20
changed so=20
because=20
<BR>>>=20
(ElistWapper)=20
void=20
{<BR>>>=20
sco and=20
teneo=20
of=20
member=20
delegate list=20
2.2.2,=20
compatible=20
tried with=20
etc...=20
example=20
3 or 4=20
case, I=20
error<BR>>>=20
<BR>>=20
face=3DArial=20
</FONT><A=20
Web: </FONT><A=20
</FONT><A=20
Re: ClassCastExeption with Elistwrapper [message #604767 is a reply to message #79946] |
Hi Daniel,
gr. Martin
daniel wrote:
> hi Martin
> the catch
> ClassCastException
> return;
> look...
> gr. Daniel
> > Hi Daniel,
> > gr. Martin
> > daniel wrote:
> >> hi,
> problem
> >> to add a new one ?)
> method;
> Could not
> >> at
> >> at
> webcontainer method
> >> try {
> SCO,
> >> return;
> >> value")
> class
> EList of
> myField (that
> Jpox1.3
> to shrink
> error... but
> >> Thanks
> >> Daniel
> > The Netherlands
The Netherlands
Re: ClassCastExeption with Elistwrapper [message #604782 is a reply to message #79993] |
Hi Daniel,
gr. Martin
daniel wrote:
> Hi Martin
> gr. Daniel
>> Hi Daniel,
>> attachcopy (or the
>> PersistableEList.
>> gr. Martin
>> daniel wrote:
>>> hi Martin
>>> the catch
>>> ClassCastException
>>> return;
>>> look...
>>> gr. Daniel
>>> > Hi Daniel,
>>> both)?
>>> > gr. Martin
>>> > daniel wrote:
>>> >> hi,
>>> problem
>>> >> to add a new one ?)
>>> method;
>>> Could not
>>> >> at
>>> >> at
>>> webcontainer method
>>> >> try {
>>> SCO,
>>> >> return;
>>> for
>>> >> value")
>>> class
>>> EList of
>>> myField (that
>>> java.util.ArrayList
>>> Jpox1.3
>>> 1.2.8.
>>> to shrink
>>> error... but
>>> >> Thanks
>>> >> Daniel
>>> > The Netherlands
>> The Netherlands
The Netherlands
Current Time: Thu Apr 25 12:42:46 GMT 2024
Powered by FUDForum. Page generated in 0.03674 seconds
