Re: Toggle DataPoint Visibility using Legend Interactivity [message #735688 is a reply to message #735638] |
Wed, 12 October 2011 14:33 |
Toggle data point visibility shoule be set here:
Value(Y) Series -> Mouse Click -> Toggle Datapoint Visibility
Look at the attached example. This only works for SVG charts and when
you preview the report the browser needs to support SVG. Look at this
preference:
Window->Preferences->Report Design->Preview
There is a check box for Enable SVG Chart. Make sure it is checked.
You can also use an external browser. I believe SVG is supported
natively in Firefox.
Jason
On 10/12/2011 9:04 AM, robinsonjas wrote:
> I'm having difficulty getting my line chart to toggle visibility of my
> Y-Series datapoints.
> I have a single grouped Y-series...12 groups on chart.
> My legend shows these groups, but no matter what combination of Toggle
> selections I set in the Chart properties I can not get it to toggle the
> groups off/on.
> Chart settings:
> ChartArea -> Y-Axis -> Mouse Click -> Toggle Visibility
> Legend -> Behavior -> None
> Legend -> Mouse Click -> Toggle Visibility
> I'm new to BIRT, sorry for the noob question, but any help is greatly
> appreciated.
> Thx
Re: Toggle DataPoint Visibility using Legend Interactivity [message #735717 is a reply to message #735638] |
preference:
Jason
> groups off/on.
> Chart settings:
> appreciated.
> Thx
Re: Toggle DataPoint Visibility using Legend Interactivity [message #735741 is a reply to message #735708] |
Wed, 12 October 2011 15:25 |
I believe toggle was in 2.2.1. Did you check the preferences?
Jason
On 10/12/2011 11:10 AM, robinsonjas wrote:
> I get error: "The report file of version "3.2.21" is not supported"
> I am running 2.2.1 because it is being integrated into IBM TCR - and
> that's the version they support.
> Will toggle still work in 2.2.1?
Re: Toggle DataPoint Visibility using Legend Interactivity [message #735819 is a reply to message #735800] |
Wed, 12 October 2011 19:17 |
If you have the svg check box checked, and you just preview with the tab
at the bottom of the editor it should work.
Jason
On 10/12/2011 2:27 PM, robinsonjas wrote:
> Hmm, something's definitely not right. I open your rptdesign file and
> deploy to TCR server... Still doesn't work.
> I set my preferences to Firefox (external) but it doesn't launch...so I
> can't locally preview the report you sent.
> Should I just start from scratch and reinstall 2.2.1?
Re: Toggle DataPoint Visibility using Legend Interactivity [message #736112 is a reply to message #736069] |
Thu, 13 October 2011 15:22 |
Does the TCR server use the RE API to run the reports or the BIRT Viewer?
Jason
On 10/13/2011 9:39 AM, robinsonjas wrote:
> Making progress...
> I unzipped a fresh packange of BIRT 2.2.1 on new pc.
> Opened your test, previewed w/ SVG Pref & it works!
> So I exported to Archive, deploy to TCR server and no dice.
> The web source shows it as PNG? even though in the rptdesign it's SVG.
> Any ideas? Browser is IE, I did Adobe install of SVG 3.0 and
> tested...looks good to me.
> Thanks
Re: Toggle DataPoint Visibility using Legend Interactivity [message #736154 is a reply to message #736145] |
Thu, 13 October 2011 17:06 |
You could try to put the following script in the beforeFactory:
var xyz =
reportContext.getRenderOption().getOption("supportedImageFormats");
reportContext.getRenderOption().setOption("supportedImageFormats", xyz
+";SVG");
But I do not think this will work.
Jason
On 10/13/2011 12:53 PM, robinsonjas wrote:
> It looks like Eclipse can run it's own webserver, should I just go that
> route?
FUDForum. Page generated in 0.06275 seconds
