Home » Archived » BIRT » Get Parameter Display Text(Can I really get the Parameter Display Text for multi select parameters)
Get Parameter Display Text [message #735460] Tue, 11 October 2011 21:26 Go to next message
Mark Victory is currently offline Mark VictoryFriend
Hi All,
Sorry to ask this again as I see it in other threads but I didn't see a definitive answer.
Is it possible to get the Display Values for the selected values of a parameter, even in multiselect parameters and cascading parameters? There seem to be conflicting opinions on whether that should/will work.
Thanks a lot,
Mark
Re: Get Parameter Display Text [message #735678 is a reply to message #735460] Wed, 12 October 2011 14:16 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Mark,
You can get the display text using the RE api in the beforeFactory
event. Take a look at the attached example.
Jason
On 10/11/2011 5:26 PM, Mark Victory wrote:
> Hi All,
> definitive answer.
> Thanks a lot,
> Mark
Re: Get Parameter Display Text [message #735683 is a reply to message #735460] Wed, 12 October 2011 14:16 Go to previous messageGo to next message
Mark,
Jason
> Hi All,
> definitive answer.
> Thanks a lot,
> Mark
Re: Get Parameter Display Text [message #735696 is a reply to message #735678] Wed, 12 October 2011 14:53 Go to previous messageGo to next message
Thanks a lot Jason (as always, very helpful),
Do you know what version of BIRT that code will work with?
Currently, I have to use 2.5.2.
Thanks again,
Mark
Re: Get Parameter Display Text [message #735712 is a reply to message #735460] Wed, 12 October 2011 14:16 Go to previous messageGo to next message
Mark,
Jason
> Hi All,
> definitive answer.
> Thanks a lot,
> Mark
Re: Get Parameter Display Text [message #735740 is a reply to message #735696] Wed, 12 October 2011 15:24 Go to previous message
Yes the code should still work with 2.5.2.
Jason
> Thanks again,
> Mark
Previous Topic:Tree of cascaded parameters
Next Topic:Can I get all possible values of dynamic parameter from RE?
Current Time: Tue Apr 16 15:12:05 GMT 2024
Powered by FUDForum. Page generated in 0.40925 seconds
