Home » Language IDEs » C / C++ IDE (CDT) » Disable code analysis on a per file basis?
Disable code analysis on a per file basis? [message #734842] Mon, 10 October 2011 03:08 Go to next message
Hi all!
I am trying to disable the code analysis tool on a per file basis.
I found two different ways to ignore files for the "Run C/C++ code analysis" context menu operation.
In the build configuration, we can either exclude files to be ignored from build or we can add the to the code analysis rules' exclusion pattern.
But in both case if the user opens an ignored file, the code analysis is performed anyway at file opening. Is there a way to avoid performing this code analysis when opening an editor on a file that should be ignored by the code analysis tool?
Is it a bug?
Thanks for any help
[Updated on: Mon, 10 October 2011 03:09] by Moderator
Re: Disable code analysis on a per file basis? [message #926525 is a reply to message #734842] Fri, 28 September 2012 14:44 Go to previous messageGo to next message
I am trying to do the same thing in Eclipse-4.2, with CDT-8.1.
I want Code Analysis to ignore files with a specific extension (.m4).
Has anyone done this?
Re: Disable code analysis on a per file basis? [message #930907 is a reply to message #734842] Tue, 02 October 2012 14:54 Go to previous messageGo to next message
Could this be due to the editor used to open the file?
If you chose "Open With" -> "Text Editor", does the Code Analysis still run on the file?
Re: Disable code analysis on a per file basis? [message #931533 is a reply to message #930907] Wed, 03 October 2012 05:39 Go to previous messageGo to next message
as far as I know Code Analysis uses the same file types as CDT.
So you could try this:
Open "Windows -> Preferences -> C/C++ -> File Types"
and remove the *.m4" from the list of the files types.
Open "Windows -> Preferences -> General -> Editors -> File Association"
and add a new file type *.m4 to this list and associate the file type to your preferred editor, probably C/C++ Editor.
Maybe you must trigger a index rebuild after changing the setting.
If that does not work for you you probably could use this method:
Open "Windows -> Preferences -> C/C++ -> Code Analysis"
Here you can customize each checker to exclude or include specific files.
http://wiki.eclipse.org/CDT/User/NewIn80#Scope_filters
A short feedback which one of this version work for you is welcome.
regards,
Klaus
Re: Disable code analysis on a per file basis? [message #934107 is a reply to message #931533] Fri, 05 October 2012 12:59 Go to previous message
.m4 is not listed.
.m4 already exists, associated with "Autoconf Editor (default)".
Changing to /C++ Editor and reopening the file, I don't see the errors any longer.
No need to re-index (Right click Project->Index->Rebuild)
Perfect. Thank you.
Previous Topic:Another problem with Hello World project
Next Topic:Indexer syntax error false positive
Current Time: Thu Jul 17 21:31:24 EDT 2025
Powered by FUDForum. Page generated in 0.08993 seconds
