MeasureItem event listener problem on Windows 7 [message #734048] |
Thu, 06 October 2011 14:00 |
H.ORTIZ Messages: 22 Registered: July 2009 |
I added a MeasureItem event listener to a virtual table.
It works fine on Linux (SUSE 11) but it runs into an infinite loop on Windows 7.
The snippet below shows the problem (I modified the class Snippet144 to add a MeasureItem event listener). Have I done something wrong ?
package org.eclipse.swt.snippets;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.RowData;
import org.eclipse.swt.layout.RowLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Event;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Listener;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Table;
import org.eclipse.swt.widgets.TableItem;
public class Snippet144 {
static final int COUNT = 100;
Display display = new Display ();
final Shell shell = new Shell (display);
shell.setLayout (new RowLayout (SWT.VERTICAL));
final Table table = new Table (shell, SWT.VIRTUAL | SWT.BORDER);
table.addListener (SWT.SetData, new Listener () {
public void handleEvent (Event event) {
TableItem item = (TableItem) event.item;
int index = table.indexOf (item);
item.setText ("Item " + index);
System.out.println (item.getText ());
table.setLayoutData (new RowData (200, 200));
Button button = new Button (shell, SWT.PUSH);
button.setText ("Add Items");
final Label label = new Label(shell, SWT.NONE);
button.addListener (SWT.Selection, new Listener () {
long t1 = System.currentTimeMillis ();
table.setItemCount (COUNT);
long t2 = System.currentTimeMillis ();
label.setText ("Items: " + COUNT + ", Time: " + (t2 - t1) + " (ms)");
shell.layout ();
table.addListener(SWT.MeasureItem, new Listener() {
public void handleEvent(Event event) {
System.out.println("measure");
event.height += 1;
shell.pack ();
shell.open ();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
Re: MeasureItem event listener problem on Windows 7 [message #734400 is a reply to message #734048] |
Fri, 07 October 2011 15:54 |
Grant Gayed Messages: 2150 Registered: July 2009 |
The event.height += 1 is the cause, it should just set event.height to
the final desired item height. The frequency of SWT.MeasureItem
invocations is not spec'd, and a difference here is why you're seeing
the behaviour difference between win32 and gtk. The Table on win32 will
(at least temporarily) stop calling MeasureItem for an item once there
is an invocation for which event.height is not changed.
Grant
> import org.eclipse.swt.widgets.Display;
> public static void main(String[] args) {
> t1) + " (ms)");
> shell.layout ();
> event.height += 1;
> shell.pack ();
> shell.open ();
> display.dispose ();
FUDForum. Page generated in 0.02824 seconds
