Home » Eclipse Projects » GEF » Node Deselection
icon4.gif  Node Deselection [message #733901] Wed, 05 October 2011 22:07 Go to next message
Mahdi Yusuf is currently offline Mahdi YusufFriend
I am having an issue when a node is selected, I am unable to deselect it by click the background/white space on the graph. The only way I can currently do it is by crtl + clicking, or by selecting another node. I would like it so that if I want to deselect the current node is to simply click the background/whitespace on which the nodes are displayed.
I would greatly appreciate some direction as to where this can be resolved.
Thanks!
Re: Node Deselection [message #733908 is a reply to message #733901] Wed, 05 October 2011 22:38 Go to previous messageGo to next message
Fabian Steeg is currently offline Fabian SteegFriend
Member
If this is about Zest, it is a bug that is fixed in the repositories and should work in future builds.
Re: Node Deselection [message #734044 is a reply to message #733908] Thu, 06 October 2011 13:49 Go to previous messageGo to next message
When is there going to be a new release of zest? Where can I can test the current development version?
Re: Node Deselection [message #734149 is a reply to message #734044] Thu, 06 October 2011 21:26 Go to previous messageGo to next message
Bump!
Re: Node Deselection [message #734272 is a reply to message #734149] Fri, 07 October 2011 10:49 Go to previous messageGo to next message
Member
You can install the latest nightly build from https://hudson.eclipse.org/hudson/job/gef-zest-nightly/lastSuccessfulBuild/artifact/targetPlatform/
There's some more information available on the wiki: http://wiki.eclipse.org/Zest
Re: Node Deselection [message #743559 is a reply to message #734272] Fri, 21 October 2011 15:22 Go to previous messageGo to next message
I am using the version 1.*, you have pointed me at the 2.* version which break most of the api we are using to work with it. Is there a mirror for 1.* version?
Re: Node Deselection [message #744073 is a reply to message #743559] Fri, 21 October 2011 23:08 Go to previous message
Member
The fix is in the latest integration build of 1.x, which can be downloaded here:
http://modeling.eclipse.org/gef/downloads/drops/3.8.0/I201110202050/GEF-zest-sdk-I201110202050.zip
About API breakage I'd be very interested in details. We are documenting changes here:
http://wiki.eclipse.org/Zest#Migration_from_Zest_1.x_to_Zest_2.x
Do you have issues that are not mentioned in that section? If you have, it would be great to hear about them so we can ease the transition.
Previous Topic:[Zest] New layout algorithm ?
Next Topic:best approach for sort of a gui builder
Current Time: Wed Dec 01 04:22:14 GMT 2021
Powered by FUDForum. Page generated in 0.02414 seconds
