Re: Using GMF without code generation [message #732242 is a reply to message #731823] |
Tue, 04 October 2011 10:03 |
On 03/10/2011 10:26, Vainolo wrote:
> Hi everyone.
> I have tried using GMF a number of times but never managed to do so. The
> most problematic aspect I found was that the model transformation are in
> only one direction, so when I had my model wrong things just could not
> evolve... And also the code generated by GMF was simply unreadable.
Please open bug reports and, if you can, provide contributions to
GMF-Tooling to make it better.
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=GMP
> But still, GMF has very nice graphic properties that are missing from GEF
> and I was wondering if there is ANY way to work with GMF like it is done
> in GEF (only programming with no models/transformations/etc - except
> obviously for the EMF model which is a must).
GMF = GEF + EMF. GMF requires an EMF model, and is efficient to deal
with EMF model. It is a mature API that you can obviously use to write
your own editor code.
Then, just do it ;)
http://mickaelistria.wordpress.com
http://twitter.com/#!/mickaelistria
http://www.petalslink.com
Re: Using GMF without code generation [message #733636 is a reply to message #733485] |
Wed, 05 October 2011 09:06 |
>>> Hi everyone.
> Before I start reporting bugs I would like to learn more about the
> framework but sadly have found little documentation. Can you give me any
> pointers?
http://wiki.eclipse.org/Graphical_Modeling_Framework
>> Then, just do it ;)
> It is not only GEF+EMF. There seems to be a lot of extra complexity doing
> the connections that has been really hard for me to understand. Again,
> any pointers? The tutorials in the web are a bit outdated...
Without details, I can't help you, but there is probably something
helpful in the wiki.
FUDForum. Page generated in 0.03338 seconds
