Home » Eclipse Projects » Standard Widget Toolkit (SWT) » maximize shell
maximize shell [message #731704] |
Sun, 02 October 2011 15:38 |
Originally posted by: Prasanth Ravi
hi i want to know how to control the maximum size of a shell(the main
one in my case).
I currently use this method -->
private Shell sh;
public void controlResized(ControlEvent e) {
Rectangle rt=((Shell) e.widget).getBounds();
if(rt.height>500)
sh.setBounds(rt.x,rt.y, rt.width, 500);
However this results in flickering ,
the shell has the setMinimumsize() , but how do i do it to restrict a
window's height on resizing?
Re: maximize shell [message #731807 is a reply to message #731785] |
Mon, 03 October 2011 06:53 |
On 10/3/2011 9:47 AM, vijay wrote:
> Did u try shell.setFullScren(true)?
i want to limit the size of the shell when the user tries to resize( ie
the shell should have a maximum size).
Re: maximize shell [message #731830 is a reply to message #731807] |
Mon, 03 October 2011 09:02 |
Vijay Raj Messages: 608 Registered: July 2009 |
ohh sorry
there is a bug entry for this
https://bugs.eclipse.org/bugs/show_bug.cgi?id=74001
its an old one, re opened again,this seems to be a genuine request and i don't know why it took so long..the fix also seems to be simple,which can be done in
LRESULT WM_GETMINMAXINFO (int /*long*/ wParam, int /*long*/ lParam) {
LRESULT result = super.WM_GETMINMAXINFO (wParam, lParam);
if (result != null) return result;
if (minWidth != SWT.DEFAULT || minHeight != SWT.DEFAULT) {
MINMAXINFO info = new MINMAXINFO ();
OS.MoveMemory (info, lParam, MINMAXINFO.sizeof);
if (minWidth != SWT.DEFAULT) info.ptMinTrackSize_x = minWidth;
//CHANGE ADD if (minWidth != SWT.DEFAULT) info.ptMaxTrackSize_x = maxWidth;
if (minHeight != SWT.DEFAULT) info.ptMinTrackSize_y = minHeight;
//CHANGE ADD if (minWidth != SWT.DEFAULT) info.ptMaxTrackSize_y = maxHeight;
OS.MoveMemory (lParam, info, MINMAXINFO.sizeof);
return LRESULT.ZERO;
return result;
if the fix is urgent you can download the development release of the SWT and merge the related changes to rebuild SWT(may lead to more problems)
why, mr. Anderson, why, why do you persist?
Because I Choose To.
Vijay
[Updated on: Mon, 03 October 2011 09:04] Report message to a moderator
Re: maximize shell [message #731861 is a reply to message #731830] |
Mon, 03 October 2011 10:23 |
Prasanth Ravi Messages: 8 Registered: October 2011 |
On 10/3/2011 2:32 PM, vijay wrote:
> ohh sorry
> don't know why its taking so long..the fix also seems to be simple,which
> can be done in
> maxHeight;
> return result;
thnx for the code .. i'll try it though i'm new to SWT. Meanwhile i
think i'll try to change so that i don't require that functionality and
i really don't want to go into the internals of SWT yet.
Re: maximize shell [message #731862 is a reply to message #731830] |
Mon, 03 October 2011 10:24 |
> ohh sorry
> can be done in
> maxHeight;
> return result;
Re: maximize shell [message #731863 is a reply to message #731830] |
Mon, 03 October 2011 10:25 |
> ohh sorry
> can be done in
> maxHeight;
> return result;
Re: maximize shell [message #731864 is a reply to message #731830] |
> ohh sorry
> can be done in
> maxHeight;
> return result;
Re: maximize shell [message #731865 is a reply to message #731830] |
> ohh sorry
> can be done in
> maxHeight;
> return result;
Re: maximize shell [message #731866 is a reply to message #731830] |
> ohh sorry
> can be done in
> maxHeight;
> return result;
Current Time: Wed Apr 24 16:14:20 GMT 2024
Powered by FUDForum. Page generated in 0.04203 seconds
