Re: How traverse on composite Nebula widget DateChooserCombo [message #809482 is a reply to message #809453] |
Tue, 28 February 2012 23:20 |
Mariusz P. Messages: 85 Registered: February 2010 |
Member |
package datechoosercomboexample;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.TraverseEvent;
import org.eclipse.swt.events.TraverseListener;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Group;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Text;
import org.eclipse.nebula.widgets.datechooser.DateChooserCombo;
public class DateChooserComboExample {
protected Shell shell;
private Text text;
private Text text_1;
* Launch the application.
* @param args
try {
DateChooserComboExample window = new DateChooserComboExample();
window.open();
} catch (Exception e) {
e.printStackTrace();
* Open the window.
public void open() {
Display display = Display.getDefault();
createContents();
shell.open();
shell.layout();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) {
display.sleep();
* Create contents of the window.
protected void createContents() {
shell = new Shell();
shell.setSize(493, 459);
shell.setText("SWT Application");
Group grpTabTraversal = new Group(shell, SWT.NONE);
grpTabTraversal.setText("TAB TRAVERSAL");
grpTabTraversal.setBounds(10, 10, 443, 125);
Button btnButton = new Button(grpTabTraversal, SWT.NONE);
btnButton.setBounds(41, 60, 75, 25);
btnButton.setText("Button");
DateChooserCombo dateChooserCombo = new DateChooserCombo(grpTabTraversal, SWT.NONE);
dateChooserCombo.setBounds(157, 68, 86, 17);
text = new Text(grpTabTraversal, SWT.BORDER);
text.setBounds(280, 64, 76, 21);
Group grpArrowDownTraversal = new Group(shell, SWT.NONE);
grpArrowDownTraversal.setText("ARROW DOWN TRAVERSAL");
grpArrowDownTraversal.setBounds(10, 152, 443, 266);
Button btnButton_1 = new Button(grpArrowDownTraversal, SWT.NONE);
btnButton_1.setBounds(39, 80, 75, 25);
btnButton_1.setText("Button");
btnButton_1.addTraverseListener(new TraverseListener() {
public void keyTraversed(TraverseEvent e) {
if (e.detail == SWT.TRAVERSE_RETURN || e.keyCode == SWT.ARROW_DOWN) {
e.detail = SWT.TRAVERSE_TAB_NEXT;
} else if (e.keyCode == SWT.ARROW_UP) {
e.detail = SWT.TRAVERSE_TAB_PREVIOUS;
e.doit = true;
DateChooserCombo dateChooserCombo_1 = new DateChooserCombo(grpArrowDownTraversal, SWT.NONE);
dateChooserCombo_1.setBounds(162, 88, 86, 17);
dateChooserCombo_1.addTraverseListener(new TraverseListener() {
e.doit = true;
text_1 = new Text(grpArrowDownTraversal, SWT.BORDER);
text_1.setBounds(280, 84, 76, 21);
text_1.addTraverseListener(new TraverseListener() {
e.doit = true;
Problem is it in group "ARROW DOWN TRAVERSAL". ARROW DOWN key is stopped on button in widget DateChooserCombo. I would like to have also traversing: Button -> DateChooserCombo -> Text (text widget in widget DateChooserCombo and button in widget DateChooserCombo as one step).
[Updated on: Wed, 29 February 2012 00:17] Report message to a moderator
Re: How traverse on composite Nebula widget DateChooserCombo [message #809513 is a reply to message #809482] |
Wed, 29 February 2012 00:25 |
Ah yes. The DateChooserCombo is a composite widget. The trick is to expose the button on the control.
You can subclass DateChooserCombo and expose the button:
package datechoosercombo;
import org.eclipse.swt.widgets.Composite;
public class MyCombo extends DateChooserCombo {
private Button buttonControl;
public MyCombo(Composite parent, int style) {
super(parent, style);
protected Button createButtonControl(int style) {
buttonControl = super.createButtonControl(style);
return getButtonControl();
public Button getButtonControl() {
return buttonControl;
Then add the traverse listener to the button like this:
dateChooserCombo_1.getButtonControl().addTraverseListener(new TraverseListener() {
e.doit = true;
works like a charm
Re: How traverse on composite Nebula widget DateChooserCombo [message #809523 is a reply to message #809513] |
Wed, 29 February 2012 00:43 |
Member |
This it's the same:
DateChooserCombo dateChooserCombo = new DateChooserCombo(shell, SWT.NONE);
Control[] control = dateChooserCombo.getChildren();
Control textInDateChooserCombo = control[0];
Control buttonInDateChooserCombo = control[1];
buttonInDateChooserCombo.addTraverseListener(new TraverseListener() {
e.doit = true;
Question is: "How in one step (one key pressing) traversing all widget DateChooserCombo ("text field & button together in DateChooserCombo)?
[Updated on: Wed, 29 February 2012 00:47] Report message to a moderator
FUDForum. Page generated in 0.03449 seconds
