cant start profiling -> error [message #7061] |
Wed, 23 February 2005 14:53  |
Originally posted by: eclipse.knowthem.de
Hyades 3.2
Eclipse 3.0.1
Test connection success.
If I want to start profiling this message comes up:
IWAT0007I Either the agent controller is not started, or the java path is
incorrect. See log for more details
and the log:
Launching process failed, platform specific error is 267.
Path=C:\Programme\Java\jre1.5.0_01\bin\java.exe Process command line =
"C:\Programme\Java\jre1.5.0_01\bin\java.exe"
-XrunpiAgent:server=controlled -Xmx256m editor.Editor" severity="55"
version="1.0.1">
The Java Path is correct.
The Agent controller is running.
Re: cant start profiling -> error [message #8102 is a reply to message #8040] |
Mon, 28 February 2005 14:20   |
Hi Paul,
I tested a little bit (also with the new TPTP 4.0 nightly build): Other
applications working normally with hyades. The app with the problem is a
RMI client. So must I run anything on the server from hyades? but i want
only profiling the client application.
Thanks for your help.
Gerrit
Paul Slauenwhite wrote:
> Hi Gerrit,
> If you can confirm that the Agent Controller is running, the paths are
> correct and the editor.Editor is on the classpath, this appears to be a JVM
> 1.5.x defect. Please open a defect with all the information presented in
> this post.
> Paul
> "Gerrit Brehmer" <eclipse@knowthem.de> wrote in message
> news:cvi5ck$i56$1@www.eclipse.org...
>> Hyades 3.2
>> Eclipse 3.0.1
>> and the log:
>> Path=C:ProgrammeJavajre1.5.0_01binjava.exe Process command line =
>> "C:ProgrammeJavajre1.5.0_01binjava.exe"
>> version="1.0.1">
Re: cant start profiling -> error [message #18782 is a reply to message #7061] |
Fri, 27 May 2005 08:21  |
Originally posted by: roger.hrzsoft.cn
I got the same error of IWAT0007I ..... while following the step
"Tutorial: Analyzing profiling data" that comes with Eclipse Help.
Hyades 4.0.0
Eclipse 3.1M7
OS: Fedora Core 2
I'm sure RAServer is running, but I'm not sure if Java Path is correct.
How could I check the path?
My error log:
org.eclipse.hyades.internal.execution.local.control.NoSuchAp plicationException
at org.eclipse.hyades.internal.execution.local.control.ProcessI mpl.launch(ProcessImpl.java:154)
at org.eclipse.hyades.trace.ui.internal.util.PDCoreUtil.launchT race(PDCoreUtil.java:757)
at org.eclipse.hyades.trace.ui.internal.launcher.ProfileJavaApp licationDelegate.launch(ProfileJavaApplicationDelegate.java: 76)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:590)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:515)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:734)
at org.eclipse.debug.internal.ui.DebugUIPlugin$6.run(DebugUIPlu gin.java:932)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:67)
Any suggestions?
On Wed, 23 Feb 2005 14:53:08 +0000, Gerrit Brehmer wrote:
> Hyades 3.2
> Eclipse 3.0.1
> and the log:
> version="1.0.1">
FUDForum. Page generated in 0.02196 seconds
