Home » Eclipse Projects » BIRT » jdbc driver(connection problem)
jdbc driver [message #730787] Thu, 29 September 2011 07:29 Go to next message
bppt Missing name is currently offline bppt Missing nameFriend
Hi everyone,
I am happy to be one of the birt user,
I have tried to connect different db to generate report
I am able to connect the odbc-jdbc from ms access (.mdb) &
flatfile (.csv)
But i cannot connect to mysql successfully.
I have download the driver bundle with mysql server.
the mysql-connector-java-5.1.15-bin.jar
I have added to the "jar files"
I tried this "jdbc:mysql://localhost:3306/abc"
when i clicked test connection, there was no response.
I read through the internet but i am still in this problem,
pls. help. thx.
Re: jdbc driver [message #730944 is a reply to message #730787] Thu, 29 September 2011 15:12 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Remove it from the jar files and use the manage drivers button in the
jdbc data source or just copy it to
eclipse\plugins\org.eclipse.birt.report.data.oda.jdbc_version\drivers
Jason
On 9/29/2011 3:29 AM, bppt wrote:
> "jar files"
Re: jdbc driver [message #731441 is a reply to message #730944] Sat, 01 October 2011 02:48 Go to previous messageGo to next message
Jason Weathersby wrote on Thu, 29 September 2011 11:12
Jason
> "jar files"
thanks Jason.
the version of eclipse i used is "eclipse-java-galileo-SR1-win32"
I have followed your instructions.
--> the "jar file" that i mention exactly the same as your described. It is the "JDBC data source" --> "manage drivers" --> "add" "mysql-connector-java-5.1.15-bin.jar"
after that i config.
Driver class : com.mysql.jdbc.driver(v5.1)
Database URL : jdbc:mysql://localhost/mysql
User Name : root
Password : xxxxx
But still no response after clicked "test connection"
--> then i tried to remove the "jar", close eclipse, copy the "muysql......jar" to "eclipse\plugins\org.eclipse.birt.report.data.oda.jdbc_version\drivers", restart "eclipse -clean" , go back to jdbc data source, i found this "com.mysql.jdbc.driver(v5.1)" from driver class again. Very Happy
but i still got the same problem.
Finally , i gave up this version of eclipse ( not sure about the version )
I tried to download the latest eclipse with birt and extract it into another new folder, created another new workspace and performed the same procedures.
Then, it is done!
I wonder there are some conflict between different plugin ( android ,..... )
So a clean version is ok.
Re: jdbc driver [message #731924 is a reply to message #731441] Mon, 03 October 2011 13:49 Go to previous messageGo to next message
May be a conflict with the driver version. I have used that version
with mysql-connector-java-5.0.4-bin.jar and it worked for me.
Jason
>> Jason
>> > "jar files"
> thanks Jason.
> User Name : root
> Password : xxxxx
> "com.mysql.jdbc.driver(v5.1)" from driver class again. :d
> procedures.
> Then, it is done!
Re: jdbc driver [message #731927 is a reply to message #731441] Mon, 03 October 2011 13:49 Go to previous messageGo to next message
Jason
>> Jason
>> > "jar files"
> thanks Jason.
> User Name : root
> Password : xxxxx
> procedures.
> Then, it is done!
Re: jdbc driver [message #749647 is a reply to message #730787] Tue, 25 October 2011 10:51 Go to previous messageGo to next message
Thx, Jason.
I can make it. I tried another new copies of eclipse.
The previous eclipse i used was integrated with ADB ... android things.
NOw, i have another problem, about the deployment,
i read empty report but i can do it in preview in eclipse.
My report is linked with JDBC:ODBC: DSN microsoft access .mdb/
pls.help thx.
Re: jdbc driver [message #750056 is a reply to message #749647] Tue, 25 October 2011 15:52 Go to previous messageGo to next message
Do you have the jdbc:odbc driver deployed?
http://www.eclipse.org/birt/phoenix/deploy/viewerSetup.php#install_jdbc
Jason
On 10/25/2011 6:51 AM, bppt wrote:
> Thx, Jason.
> pls.help thx.
Re: jdbc driver [message #751820 is a reply to message #750056] Wed, 26 October 2011 07:10 Go to previous messageGo to next message
Yes, i have followed the instructions on manual.
I copied rt.jar from java/lib into WebViewer's classpath (eg WEB-INF/lib).
And the log :
2011-10-25 10:55:19 org.eclipse.birt.data.engine.odaconsumer.ConnectionManager openConnection
: Unable to open connection.
org.eclipse.birt.report.data.oda.jdbc.JDBCException: There is an error in get connection, [Microsoft][ODBC Microsoft Access Driver] '(unknown)' is not a valid path. Make sure that the path name is spelled correctly and that you are connected to the server on which the file resides..
Re: jdbc driver [message #752764 is a reply to message #751820] Wed, 26 October 2011 14:06 Go to previous message
I had forgotten this driver was in rt.jar. Remove it from the
web-inf/lib because it should already be in the classpath. If you are
using windows 7, did you add the mdb to the using the odbcad32.exe under
%WINDIR%\SYSWOW64?
Jason
> And the log :
> 2011-10-25 10:55:19
Previous Topic:Asynchrony Testing
Next Topic:Math formulas in a BIRT report
Current Time: Sat Nov 17 16:51:04 GMT 2018
Powered by FUDForum. Page generated in 0.01500 seconds
