Home » Modeling » GMF (Graphical Modeling Framework) » Scrolling diagram nodes into view
Scrolling diagram nodes into view [message #730694] Wed, 28 September 2011 21:46 Go to next message
Thomas Spall is currently offline Thomas SpallFriend
I would like to select a particular diagram node - respectively potentially multiple nodes - and then scroll them into the user's visible field on a best effort approach. I.e. if there is only one node or the selected nodes are conveniently close, the view is scrolled and centred on the cluster and the user indeed can see all selected nodes. Otherwise, it does something default like e.g. always scrolling to the first node.
Main question is: Does anyone know if this functionality or something similar is already existing in the GMF framework somewhere?
If not, where would be a good point to insert this or start from?
Thomas
[Updated on: Wed, 28 September 2011 21:46]
Report message to a moderator
Re: Scrolling diagram nodes into view [message #1032829 is a reply to message #730694] Wed, 03 April 2013 13:40 Go to previous messageGo to next message
Dan Tololoi is currently offline Dan TololoiFriend
Member
Hi Thomas,
I reached this topic also looking for some ideas. Do you have any updates?
Thanks!
Re: Scrolling diagram nodes into view [message #1033410 is a reply to message #1032829] Thu, 04 April 2013 07:56 Go to previous messageGo to next message
Ralph Gerbig is currently offline Ralph GerbigFriend
you need two things 1) Your DiragramEditor (editor) and 2) The edit part (editPart) you want to scroll to. Then do the following:
editor.getDiagramGraphicalViewer().select(editPart);
editor.getDiagramGraphicalViewer().reveal(editPart);
Ralph
Re: Scrolling diagram nodes into view [message #1034427 is a reply to message #1033410] Fri, 05 April 2013 12:17 Go to previous message
Member
Hi Ralph,
Thanks for the reply. I managed to do in the following lines of code:
GraphicalViewer gv = (GraphicalViewer)editor.getAdapter(GraphicalViewer.class);
FigureCanvas figureCanvas = (FigureCanvas) gv.getControl();
figureCanvas.scrollTo(coordinatesRectangle.x,coordinatesRectangle.y);
where the editor is the DiagramEditor and the x and y are the new values the scroll should take place.
Hope this helps to somebody else also.
Previous Topic:recursive relation in same class
Next Topic:How to edit a label mapped by ExpressionLabelMapping?
Current Time: Tue Apr 16 17:10:11 GMT 2024
Powered by FUDForum. Page generated in 1.01191 seconds
