duplicate bundles in virgo 3 [message #730385] |
Wed, 28 September 2011 09:41 |
Jose u Messages: 2 Registered: September 2011 |
Hi all,
we have been using virgo 2 for some time, more or less it has been ok. We upgraded to virgo 3 last week and since then we have found some issues and we are not sure about the reason.
The effect is that we see that some bundles are deployed two times or duplicated.
We have a plan where we define our bundles and configuration, we leave this plan in the pickup directory, We use the default repository virgo/repository/usr for the artifacts and we have an extra repository for our configuration properties files.
The thing is that we detected in the logs that some bundles are loaded two times. One of them seems to be loaded by a thread that I didn't see before in virgo 2 "Listener Event Queue". The other seems to be loaded for the normal thread fs-watcher
from our logs
[2011/09/28 11:03:01 755] Listener Event Queue c.n.p.r.d.c.osgi.XXXActivator I- Start Foofoofoo Service Tracker
[2011/09/28 11:03:01 759] fs-watcher c.n.p.r.d.c.osgi.XXXActivator I- Start Foofoofoo Service Tracker
And if I open in the web admin and I look at the 2 bundles duplicated I see that one of the bundle is located in the repository and the other in the staging.
Viewing bundle 'com.foo.foo.core: 0.1.0'
Bundle Symbolic name com.foo.foo.core
Bundle Version 0.1.0
Bundle ID 121
Region org.eclipse.virgo.region.user
Hosts/Fragments NA
Spring powered No
State Active
Bundle Location [email]org.eclipse.virgo.region.user@file[/email]:/opt/aaa/virgo/./repository/usr/foo.core-0.1.0-SNAPSHOT.jar
Bundle ID 134
Hosts/Fragments NA
Spring powered No
State Active
Bundle Location [email]org.eclipse.virgo.region.user@file[/email]:/opt/aaa/virgo/work/org.eclipse.virgo.kernel.deployer_3.0.1.RELEASE/staging/global/bundle/com.foo.foo.core/0.1.0
We had similar problems in other application developed by us when we upgraded to virgo 3.
I dont know if someone can throw some ideas. Or at least have some information about the thread "Listener Event Queue".
Thank you very much in advance
[Updated on: Wed, 28 September 2011 12:52] Report message to a moderator
FUDForum. Page generated in 0.02743 seconds
