Re: 'birtutility' is undefined [message #730549 is a reply to message #730291] |
Wed, 28 September 2011 15:30 |
How do you have the viewer deployed? Are you getting this error in the
designer?
Jason
On 9/28/2011 1:27 AM, Vivek wrote:
> I am using BIRT ECLIPSE VERSION 2010 in windows 7 (with 1GB RAM) with IE8 in
> compatible mode as my project doesn't support IE8.
> Few days back the report tool was working fine.
> However, I am getting some error from the last two days
> The error shown by the Browser is:
> Webpage error details
> Message: 'Constants' is undefined
> Line: 1958
> Char: 2
> Code: 0
> Line: 1980
> Char: 5
> Code: 0
> Message: Object expected
> Line: 2024
> Char: 3
> Code: 0
> Message: 'birtUtility' is undefined
> Line: 2048
> Char: 4
> Code: 0
> But I didn't made any changes in the birtutility.js or any other file.
> I am attaching the screen shot foe reference.
Re: 'birtutility' is undefined [message #730939 is a reply to message #730748] |
Thu, 29 September 2011 14:49 |
What version of BIRT and JBOSS are you using? How did you deploy it?
Jason
On 9/29/2011 12:10 AM, Vivek wrote:
> Hi Jason Weathersby,
> No I am not getting this error in the designer but I am getting this
> error when i deployed it on local server using the JBOSS server.
Re: 'birtutility' is undefined [message #765750 is a reply to message #765372] |
Wed, 14 December 2011 15:54 |
I did not get the error. Vivek did. Is yours happening in JBoss as
well? If so what version and how did you deploy?
Jason
On 12/13/2011 6:24 PM, Fisco wrote:
> Hi Jason I have the same problem
> Could you tell me how didi you solve this problem????
> Thanks
Re: 'birtutility' is undefined [message #768011 is a reply to message #765750] |
Mon, 19 December 2011 11:39 |
Jeevan Sunkersett Messages: 8 Registered: July 2009 |
Is there any solution to this issue ?
I am getting the same error and same screen like originally posted by Vivek (birtError.png)
My environment:
Application server is JBoss 5.1-GA,
Fronted by an Apache httpd server (using mod_jk)
BIRT report viewer: I think the same as what has been mentioned by others in this post. (I do not how to find that out, please explain)
Further to this, my reports work fine when viewed with a local I.P address, eg. 10.0.1.9 (that is inside the local network), but when viewed using the registered domain (e.g. https://www.mydomain.com/reports) , it shows up as originally described by Vivek.
I did a bit of debugging and found,
the URL of the image, is something like
https://online.sai.org.in/frameset?__id=birtViewer&__report=%2FWEB-INF%2Freport%2FOnline_Transaction_History.rptdesign&__masterpage=true&__format=html
Using developer tools (firebug) found the element to be:
<input name="parameter" title="Run report" class="birtviewer_clickable" type="image" alt="Run report" src="birt/images/Report_parameters.gif"/>
if I replace the src parameter with the fully qualified path;
meaning src='https://online.sai.org.in/webcontent/birt/images/Report_parameters.gif'
the image is displayed.
Can somebody shed some light on this/ give me a few pointers ?
thank you,
Jeevan
Re: 'birtutility' is undefined [message #768139 is a reply to message #768011] |
Mon, 19 December 2011 16:39 |
Jeevan,
Look over this thread.
http://www.birt-exchange.org/org/forum/index.php/topic/21462-networking-problem-with-birt-generated-resource-urls/
Jason
On 12/19/2011 6:40 AM, Jeevan Sunkersett wrote:
> My environment:
> Application server is JBoss 5.1-GA, Fronted by an Apache httpd server
> (using mod_jk)
> by Vivek.
> if I replace the src parameter with the fully qualified path; meaning
> thank you,
> Jeevan
FUDForum. Page generated in 0.04499 seconds
