Home » Eclipse Projects » EclipseLink » Object: is not a known entity type.
Object: is not a known entity type. [message #728937] |
Sat, 24 September 2011 12:50 |
Patrick Philips Messages: 13 Registered: February 2011 |
Hi everyone,
I have a real problem where my entity to persist is not recognised. I have been banging my head against for several days now, and any help would be very much appreciated.
Eclipse Platform: Indigo Version: 3.7.0.v20110530
I have incorporated EclipseLink 2.3.0 JPA into my RCP project and am using the Apache Derby data base to persist data. No problems with installation and setting up data base in Eclipse. However when I try to persist data to the data base I get the following errors: (sorry for the long trace ... didn't want to leave out anything that was relevant!).
[EL Finest]: 2011-09-24 07:34:59.778--ServerSession(1136315517)--Thread(Thread[AWT-EventQueue-0,6,main])--Begin predeploying Persistence Unit JPA1PU; session bundleresource://4.fwk511811991:1_JPA1PU; state Initial; factoryCount 0
[EL Finest]: 2011-09-24 07:34:59.809--ServerSession(1136315517)--Thread(Thread[AWT-EventQueue-0,6,main])--property=eclipselink.orm.throw.exceptions; default value=true
[EL Finest]: 2011-09-24 07:34:59.809--ServerSession(1136315517)--Thread(Thread[AWT-EventQueue-0,6,main])--property=eclipselink.multitenant.tenants-share-cache; default value=false
[EL Finest]: 2011-09-24 07:34:59.825--ServerSession(1136315517)--Thread(Thread[AWT-EventQueue-0,6,main])--property=eclipselink.metadata-source; default value=null
[EL Finest]: 2011-09-24 07:34:59.825--ServerSession(1136315517)--Thread(Thread[AWT-EventQueue-0,6,main])--property=eclipselink.jpa.uppercase-column-names; default value=false
[EL Finer]: 2011-09-24 07:34:59.825--ServerSession(1136315517)--Thread(Thread[AWT-EventQueue-0,6,main])--Searching for default mapping file in bundleresource://4.fwk511811991:1
[EL Finer]: 2011-09-24 07:34:59.842--ServerSession(1136315517)--Thread(Thread[AWT-EventQueue-0,6,main])--Searching for default mapping file in bundleresource://4.fwk511811991:1
[EL Finest]: 2011-09-24 07:34:59.888--ServerSession(1136315517)--Thread(Thread[AWT-EventQueue-0,6,main])--End predeploying Persistence Unit JPA1PU; session bundleresource://4.fwk511811991:1_JPA1PU; state Predeployed; factoryCount 0
[EL Finer]: 2011-09-24 07:34:59.888--Thread(Thread[AWT-EventQueue-0,6,main])--JavaSECMPInitializer - transformer is null.
[EL Finest]: 2011-09-24 07:34:59.888--ServerSession(1136315517)--Thread(Thread[AWT-EventQueue-0,6,main])--Begin predeploying Persistence Unit JPA1PU; session bundleresource://4.fwk511811991:1_JPA1PU; state Predeployed; factoryCount 0
[EL Finest]: 2011-09-24 07:34:59.888--ServerSession(1136315517)--Thread(Thread[AWT-EventQueue-0,6,main])--End predeploying Persistence Unit JPA1PU; session bundleresource://4.fwk511811991:1_JPA1PU; state Predeployed; factoryCount 1
[EL Finest]: 2011-09-24 07:35:00.934--ServerSession(1136315517)--Thread(Thread[AWT-EventQueue-0,6,main])--Begin deploying Persistence Unit JPA1PU; session bundleresource://4.fwk511811991:1_JPA1PU; state Predeployed; factoryCount 1
[EL Finer]: 2011-09-24 07:35:00.934--ServerSession(1136315517)--Thread(Thread[AWT-EventQueue-0,6,main])--Could not initialize Validation Factory. Encountered following exception: java.lang.NoClassDefFoundError: javax/validation/Validation
[EL Finest]: 2011-09-24 07:35:00.934--ServerSession(1136315517)--Thread(Thread[AWT-EventQueue-0,6,main])--property=eclipselink.logging.level; value=FINEST; translated value=FINEST
[EL Finest]: 2011-09-24 07:35:00.949--ServerSession(1136315517)--Thread(Thread[AWT-EventQueue-0,6,main])--property=eclipselink.logging.level; value=FINEST; translated value=FINEST
[EL Finest]: 2011-09-24 07:35:00.949--ServerSession(1136315517)--Thread(Thread[AWT-EventQueue-0,6,main])--property=javax.persistence.jdbc.user; value=Patrick
[EL Finest]: 2011-09-24 07:35:00.949--ServerSession(1136315517)--Thread(Thread[AWT-EventQueue-0,6,main])--property=javax.persistence.jdbc.password; value=xxxxxx
[EL Finest]: 2011-09-24 07:35:23.211--ServerSession(1136315517)--Thread(Thread[AWT-EventQueue-0,6,main])--property=eclipselink.target-database; value=Derby; translated value=org.eclipse.persistence.platform.database.DerbyPlatform
[EL Finest]: 2011-09-24 07:35:23.227--ServerSession(1136315517)--Thread(Thread[AWT-EventQueue-0,6,main])--property=javax.persistence.jdbc.driver; value=org.apache.derby.jdbc.EmbeddedDriver
[EL Finest]: 2011-09-24 07:35:23.227--ServerSession(1136315517)--Thread(Thread[AWT-EventQueue-0,6,main])--property=javax.persistence.jdbc.url; value=jdbc:derby:/Users/Patrick/MyDB;create=true
[EL Info]: 2011-09-24 07:35:23.227--ServerSession(1136315517)--Thread(Thread[AWT-EventQueue-0,6,main])--EclipseLink, version: Eclipse Persistence Services - 2.3.0.v20110604-r9504
[EL Config]: 2011-09-24 07:35:23.227--ServerSession(1136315517)--Connection(1700797952)--Thread(Thread[AWT-EventQueue-0,6,main])--connecting(DatabaseLogin(
platform=>DerbyPlatform
user name=> "Patrick"
datasource URL=> "jdbc:derby:/Users/Patrick/MyDB;create=true"
[EL Finer]: 2011-09-24 07:35:23.665--ServerSession(1136315517)--Thread(Thread[AWT-EventQueue-0,6,main])--DriverManager connect failed, trying direct connect.
[EL Finer]: 2011-09-24 07:35:23.665--ServerSession(1136315517)--Thread(Thread[AWT-EventQueue-0,6,main])--java.sql.SQLException: No suitable driver found for jdbc:derby:/Users/Patrick/MyDB;create=true
at java.sql.DriverManager.getConnection(DriverManager.java:602)
at java.sql.DriverManager.getConnection(DriverManager.java:154)
at org.eclipse.persistence.sessions.DefaultConnector.connect(DefaultConnector.java:98)
at org.eclipse.persistence.sessions.DatasourceLogin.connectToDatasource(DatasourceLogin.java:162)
at org.eclipse.persistence.internal.databaseaccess.DatasourceAccessor.connectInternal(DatasourceAccessor.java:330)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.connectInternal(DatabaseAccessor.java:293)
at org.eclipse.persistence.internal.databaseaccess.DatasourceAccessor.connect(DatasourceAccessor.java:418)
at org.eclipse.persistence.sessions.server.ConnectionPool.buildConnection(ConnectionPool.java:216)
at org.eclipse.persistence.sessions.server.ConnectionPool.startUp(ConnectionPool.java:504)
at org.eclipse.persistence.sessions.server.ServerSession.connect(ServerSession.java:484)
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.login(DatabaseSessionImpl.java:630)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryProvider.login(EntityManagerFactoryProvider.java:208)
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:472)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.getDatabaseSession(EntityManagerFactoryDelegate.java:188)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.getMetamodel(EntityManagerFactoryDelegate.java:591)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.getMetamodel(EntityManagerFactoryImpl.java:502)
at emdd.test.JPATest.init(JPATest.java:59)
at emdd.test.WBTestAddPanel$4.mouseClicked(WBTestAddPanel.java:86)
at java.awt.AWTEventMulticaster.mouseClicked(AWTEventMulticaster.java:253)
at java.awt.Component.processMouseEvent(Component.java:6270)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3267)
at java.awt.Component.processEvent(Component.java:6032)
at java.awt.Container.processEvent(Container.java:2041)
at java.awt.Component.dispatchEventImpl(Component.java:4630)
at java.awt.Container.dispatchEventImpl(Container.java:2099)
at java.awt.Component.dispatchEvent(Component.java:4460)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4577)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4247)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4168)
at java.awt.Container.dispatchEventImpl(Container.java:2085)
at java.awt.Window.dispatchEventImpl(Window.java:2478)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:599)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
[EL Config]: 2011-09-24 07:35:24.117--ServerSession(1136315517)--Connection(534738380)--Thread(Thread[AWT-EventQueue-0,6,main])--Connected: jdbc:derby:/Users/Patrick/MyDB
User: Patrick
Database: Apache Derby Version: 10.8.1.2 - (1095077)
Driver: Apache Derby Embedded JDBC Driver Version: 10.8.1.2 - (1095077)
[EL Finest]: 2011-09-24 07:35:24.117--ServerSession(1136315517)--Connection(534738380)--Thread(Thread[AWT-EventQueue-0,6,main])--Connection acquired from connection pool [default].
[EL Finest]: 2011-09-24 07:35:24.133--ServerSession(1136315517)--Connection(534738380)--Thread(Thread[AWT-EventQueue-0,6,main])--Connection released to connection pool [default].
[EL Info]: 2011-09-24 07:35:24.133--ServerSession(1136315517)--Thread(Thread[AWT-EventQueue-0,6,main])--bundleresource://4.fwk511811991:1_JPA1PU login successful
[EL Warning]: 2011-09-24 07:35:24.164--Thread(Thread[AWT-EventQueue-0,6,main])--The collection of metamodel types is empty. Model classes may not have been found during entity search for Java SE and some Java EE container managed persistence units. Please verify that your entity classes are referenced in persistence.xml using either <class> elements or a global <exclude-unlisted-classes>false</exclude-unlisted-classes> element
[EL Finer]: 2011-09-24 07:35:24.164--ServerSession(1136315517)--Thread(Thread[AWT-EventQueue-0,6,main])--The collection of metamodel types is empty. Model classes may not have been found during entity search for Java SE and some Java EE container managed persistence units. Please verify that your entity classes are referenced in persistence.xml using either <class> elements or a global <exclude-unlisted-classes>false</exclude-unlisted-classes> element
[EL Finest]: 2011-09-24 07:35:24.164--ServerSession(1136315517)--Thread(Thread[AWT-EventQueue-0,6,main])--End deploying Persistence Unit JPA1PU; session bundleresource://4.fwk511811991:1_JPA1PU; state Deployed; factoryCount 1
MetaModel: MetamodelImpl@11975273 [ 0 Types: , 0 ManagedTypes: , 0 EntityTypes: , 0 MappedSuperclassTypes: , 0 EmbeddableTypes: ]
[EL Finer]: 2011-09-24 07:36:40.495--ServerSession(1136315517)--Thread(Thread[AWT-EventQueue-0,6,main])--client acquired: 592489859
[EL Finer]: 2011-09-24 07:36:40.511--ClientSession(592489859)--Thread(Thread[AWT-EventQueue-0,6,main])--acquire unit of work: 2018338552
Exception in thread "AWT-EventQueue-0" java.lang.IllegalArgumentException: Object: mailto:org.persistence.Entity2@2dec3ffd is not a known entity type.
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.registerNewObjectForPersist(UnitOfWorkImpl.java:4158)
at org.eclipse.persistence.internal.jpa.EntityManagerImpl.persist(EntityManagerImpl.java:440)
at emdd.test.JPATest.init(JPATest.java:73)
My persistence.xml file is:
<persistence version="2.0" xmlns="http://java.sun.com/xml/ns/persistence" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://java.sun.com/xml/ns/persistence http://java.sun.com/xml/ns/persistence/persistence_2_0.xsd">
<persistence-unit name="JPA1PU" transaction-type="RESOURCE_LOCAL">
<provider>org.eclipse.persistence.jpa.PersistenceProvider</provider>
<class>org.persistence.Entity2</class>
<class>org.persistence.Entity1</class>
<properties>
<property name="javax.persistence.jdbc.driver" value="org.apache.derby.jdbc.EmbeddedDriver"/>
<property name="eclipselink.target-database" value="Derby"/>
<property name="javax.persistence.jdbc.user" value="Patrick"/>
<property name="eclipselink.logging.level" value="FINEST"/>
<property name="javax.persistence.jdbc.url" value="jdbc:derby:/Users/Patrick/MyDB;create=true"/>
<property name="javax.persistence.jdbc.password" value="xxxxxx"/>
<property name="eclipselink.ddl-generation" value="create-tables"/>
<property name="eclipselink.ddl-generation.output-mode" value="database"/>
</properties>
</persistence-unit>
</persistence>
which includes references to the <class> elements and <exclude-unlisted-classes>false</exclude-unlisted-classes> so I don't see the problem in the persistence.xml file.
The test code I am using to exercise the connection and persist some test data is:
public ClassLoader getJPAClassLoader() {
//return this.getClass().getClassLoader();
return org.apache.derby.jdbc.EmbeddedDriver.class.getClassLoader();
public void init(){
HashMap properties = new HashMap();
ClassLoader cL = getJPAClassLoader();
properties.put(PersistenceUnitProperties.CLASSLOADER, cL);
emFactory = new org.eclipse.persistence.jpa.PersistenceProvider().createEntityManagerFactory(PERSISTENCE_UNIT_NAME, properties);
System.out.println("MetaModel: " + emFactory.getMetamodel());
em = emFactory.createEntityManager();
em.getTransaction().begin();
Entity1 ent1 = new Entity1();
Entity2 ent2 = new org.persistence.Entity2();
ent1.setADDRESS("My Address1");
ent2.setAddress("My Addresss2");
ent1.setSTREET("My Street1");
em.persist(ent2);
em.persist(ent1);
em.getTransaction().commit();
em.close();
My entity file Entity2 is as follows:
package org.persistence;
import java.io.Serializable;
import java.lang.String;
import javax.persistence.*;
* Entity implementation class for Entity: Entity2
@Entity
public class Entity2 implements Serializable {
@Id
private long Id;
private String Address;
private static final long serialVersionUID = 1L;
public Entity2() {
super();
public long getId() {
return this.Id;
public void setId(long Id) {
this.Id = Id;
public String getAddress() {
return this.Address;
public void setAddress(String Address) {
this.Address = Address;
Any help would really be appreciated as I have exhausted my web-site search options hoping to find an answer to this one.
Thanks in advance.
Patrick.
Current Time: Thu Mar 28 18:21:10 GMT 2024
Powered by FUDForum. Page generated in 0.06208 seconds
