Home » Modeling » GMF (Graphical Modeling Framework) » Drag and dropping ports into tasks
Drag and dropping ports into tasks [message #728390] |
Fri, 23 September 2011 07:37 |
Iban Ayestaran Messages: 58 Registered: September 2011 |
Member |
I have designed a meta-model in Ecore, and now I am designing a graphical modeling tool with the GMF.
In the meta-model I have declared somethig called task, and something called port. In the diagram, I can now draw ports and tasks separately, but I want to force the user to draw the ports only inside the tasks, by drag-and-dropping the ports inside tasks.
Tasks have an atribute called InPorts, where all the ports of the task have to be declared. I would also like the ports to be declared automatically when they are drag-and-dropped inside the tasks.
How can I do this?
Thanks in advance.
[Updated on: Fri, 23 September 2011 08:37] Report message to a moderator
Re: Drag and dropping ports into tasks [message #728485 is a reply to message #728457] |
Fri, 23 September 2011 10:50 |
Member |
Hi!
"In your ecore, do you have ports contained in tasks?" Yes.
"In your gmfmap, do you have a NodeMapping ChildReference on your Task node?" No, I don´t know how to do it. I have two doubts:
1. I define a childreference, but how should I configure the parameters?:
- Child: Node Mapping <In:InputPort/InputPort>
- Child Feature: task.in:InputPort
- Compartment: CompartmentMapping<>
- Containment Feature: ??? (What should I write here?)
- Referenced Child: Node Mapping <In:InputPort/InputPort>
2. I also define a compartmentMapping:
- Children: ChildReference <|In:InputPort/InputPort>
- Compartment: ??? (I have nothing to choose here!)
[Updated on: Fri, 23 September 2011 10:50] Report message to a moderator
Re: Drag and dropping ports into tasks [message #728501 is a reply to message #728485] |
Fri, 23 September 2011 11:14 |
On 23/09/2011 12:50, Iban wrote:
> Hi!
> 1. I define a childreference, but how should I configure the parameters:
Let's ignore compartment for the first iteration.
According to your Ecore, you should set the containment feature to task.in.
You don't have to use a compartment in a first time. You can add it once
the containment works.
HTH
http://mickaelistria.wordpress.com
http://twitter.com/#!/mickaelistria
http://www.petalslink.com
Re: Drag and dropping ports into tasks [message #731957 is a reply to message #728504] |
Mon, 03 October 2011 14:53 |
Member |
Hello again,
related to this topic, I have another question now. I want to make something similar to what I did with ports and tasks (that is, to draw ports only inside tasks), but I need something different.
The thing is that I have some blocks called modules, and I want to force the designer to draw first the modules, then the tasks inside modules, and then the ports inside tasks. But in my ecore modules do not contain tasks, they only have a reference to tasks and tasks are contained by the "MainProgram" block. The reason for this is that I want a single tasks to be able to be called from different modules.
So my question is: is it possible to force the designer to draw tasks only inside modules, if tasks are not contained in modules?
Re: Drag and dropping ports into tasks [message #733481 is a reply to message #731957] |
Tue, 04 October 2011 21:05 |
Svyatoslav Kovalsky Messages: 12 Registered: October 2011 |
This is straightforward, except the one step at the end.
So you should proceed exactly like the tasks are contained in modules:
- create Top Reference and node mapping for Module, set up everything for it as always
- inside it create child reference for Task, set the children feature to (non-containment) Module#tasks, set containment feature to your actual containment for Tasks - say, to your RootElement#tasksContainment
- inside it create the same structure for Ports as before
- run Create Generator Model as always
You will have the validation error for map model - 'Containment feature must be owned by class or superclass...', just ignore it, by checking Ignore Validation Error's check box for the Mapping Model Validation Result page of Create Generator model wizard.
- generate the code
- go to the generated TaskCreateCommand, you will see the code like this:
protected CommandResult doExecuteWithResult(IProgressMonitor monitor, IAdaptable info) throws ExecutionException {
Task newElement = XXXFactory.eINSTANCE.createTask();
RootElement owner = (RootElement) getElementToEdit(); //<HERE IS ERROR>
owner.getTasksContainment().add(newElement);
Module childHolder = (Module) getElementToEdit();
childHolder.getTasks().add(newElement);
//... the rest omitted
The line marked with <HERE IS ERROR> is, well, an error - getElementToEdit will actually be the Module, not the RootElement, so you will get ClassCast here. (should not be a surprise - you had been told that there may be a problems with code, when you were presented with a Warning earlier).
So you have to replace the error line with @generated NOT version that correctly navigates from Module childHolder to your actual container and correctly adds the new created Task to correct containment;
So you will have something like
* @generated NOT
//custom code:
RootElement owner = customFindRootElementFor(chldHolder);
Svyatoslav Kovalsky
at Montages Think Tank, Prague, Czech Republic
Montages AG, Zürich, Switzerland
[Updated on: Tue, 04 October 2011 21:57] Report message to a moderator
Re: Drag and dropping ports into tasks [message #735988 is a reply to message #735090] |
Thu, 13 October 2011 10:00 |
Member |
Hello!
I tried what you said, by typing this:
RootElement owner = (RootElement) childHolder.eContainer();
owner.getTasks().add(newElement);
Now, in the diagram I can draw tasks inside ports as I wanted, but in the model the tasks appears defined twice, one in the RootElement (as I want) and another inside the Module (and I don't want that, I just want to make a reference to the task contained by the RootElement).
Now, from the model file (not the diagram file, I mean), I can drag and drop a task to other modules, but if I delete a task, all the tasks are deleted, including the one in the RootElement. I mean, it seems that what I define in the Module is not really a reference to the task, but the task itself, that it is repeated in all the modules an in the RootElement.
I think the problem is in the "childHolder.getTasks().add(newElement);" statement. How can I specify not to be a contained element, but just a reference to the task contained by the RootElement? I was thinking of typing "childHolder.setTasks();", but that gives an error....
Thanks for all your answers!!
[Updated on: Thu, 13 October 2011 10:11] Report message to a moderator
Current Time: Thu Apr 25 14:54:39 GMT 2024
Powered by FUDForum. Page generated in 0.04834 seconds
