Re: Can I deploy a plan file to a Virgo server from the Servers view? [message #734930 is a reply to message #728056] |
Mon, 10 October 2011 13:06 |
Barbara Rosi-Schwartz Messages: 448 Registered: July 2009 |
I have not yet found out how to deploy a plan.
However, just in case it helps, I have found an answer to my main motivation do deploy a plan, which was to observe a certain order of deployment so that there are no delays during bundle activation that are due to missing services that are contributed by other bundles.
The solution is to edit the artefact-order.config file that is located inside the Servers node in the Package Explorer and place the various bundles in the required order. I can hardly believe it took me so long to see this file!!!
Please note that this file gets refreshed when adding/removing nodes, so it is advisable to store away a copy of it for easy replacement.
HTH,
B.
[Updated on: Mon, 10 October 2011 13:08] Report message to a moderator
FUDForum. Page generated in 0.02624 seconds
