Home » Archived » M2M (model-to-model transformation) » [QVT] result of allSubobjects on sets
[QVT] result of allSubobjects on sets [message #727429] Wed, 21 September 2011 09:33 Go to next message
Wilbert Alberts is currently offline Wilbert AlbertsFriend
I'm having some troubles understanding the effect of invoking allSubobjects() on a set.
Assume that self.persons represents a set of Person.
Assume that a Person might have other references to Persons.
What is the difference between:
-1- self.persons.allSubobjects() and
-2- self.persons->allSubobjects()
when invoked in a QVT transformation?
Obviously I tried it and got
-1- [ p1, p2 ]
-2- [[ p1, p2 ]]
allSubobjects is specified as an operation that returns a Set(Element) when invoked on an Element.
However, what happens when allSubobjects is invokved on a Set(Element)?
Greetings,
Wilbert.
Re: [QVT] result of allSubobjects on sets [message #727518 is a reply to message #727429] Wed, 21 September 2011 13:49 Go to previous messageGo to next message
self.persons.allSubobjects() is a shortform for
self.persons->collect(allSubobjects()) so it should evaluate to a Bag.
self.persons->allSubobjects() is wrong; raise a Bugzilla.
allSubObjects() is defined on Element and Collections do not conform to
Element; therefore a semantic error should be reported. It looks as if
the implementation just uses eContents() behind the scenes and so
creates a Set of the internal collection. Even if QVT were to define
allSubObjects(), I doubt it would be defined as Set{self} when just self
would be simpler.
Ed Willink
On 21/09/2011 10:33, Wilbert Alberts wrote:
> -1- [ p1, p2 ]
> -2- [[ p1, p2 ]]
> Greetings,
> Wilbert.
Re: [QVT] result of allSubobjects on sets [message #727523 is a reply to message #727429] Wed, 21 September 2011 13:49 Go to previous messageGo to next message
would be simpler.
Ed Willink
> -1- [ p1, p2 ]
> -2- [[ p1, p2 ]]
> Greetings,
> Wilbert.
Re: [QVT] result of allSubobjects on sets [message #727536 is a reply to message #727429] Wed, 21 September 2011 13:49 Go to previous messageGo to next message
would be simpler.
Ed Willink
> -1- [ p1, p2 ]
> -2- [[ p1, p2 ]]
> Greetings,
> Wilbert.
Re: [QVT] result of allSubobjects on sets [message #727538 is a reply to message #727429] Wed, 21 September 2011 13:49 Go to previous messageGo to next message
would be simpler.
Ed Willink
> -1- [ p1, p2 ]
> -2- [[ p1, p2 ]]
> Greetings,
> Wilbert.
Re: [QVT] result of allSubobjects on sets [message #727544 is a reply to message #727429] Wed, 21 September 2011 13:49 Go to previous messageGo to next message
would be simpler.
Ed Willink
> -1- [ p1, p2 ]
> -2- [[ p1, p2 ]]
> Greetings,
> Wilbert.
Re: [QVT] result of allSubobjects on sets [message #727560 is a reply to message #727429] Wed, 21 September 2011 13:49 Go to previous messageGo to next message
would be simpler.
Ed Willink
> -1- [ p1, p2 ]
> -2- [[ p1, p2 ]]
> Greetings,
> Wilbert.
Re: [QVT] result of allSubobjects on sets [message #727562 is a reply to message #727429] Wed, 21 September 2011 13:49 Go to previous messageGo to next message
would be simpler.
Ed Willink
> -1- [ p1, p2 ]
> -2- [[ p1, p2 ]]
> Greetings,
> Wilbert.
Re: [QVT] result of allSubobjects on sets [message #727873 is a reply to message #727518] Thu, 22 September 2011 06:28 Go to previous message
Done so.
Wilbert.
Previous Topic:[QVTo] Metamodels list "reloading" in QVTo plugin
Next Topic:[QVTO] Accessing Java class members from transformations
Current Time: Sun Mar 29 19:41:55 GMT 2020
Powered by FUDForum. Page generated in 0.02738 seconds
