Home » Language IDEs » Java Development Tools (JDT) » Eclipse suggest meaningless parameter name
Eclipse suggest meaningless parameter name [message #727221] Tue, 20 September 2011 12:29 Go to next message
My Eclipse is showing code completion for method parameters with meaningless names, for example:
aString.substring(int arg0, int arg1)
How can I make it show meaningful names, e.g substring(int beginIndex, int endIndex) ?
java collection
[Updated on: Sun, 04 December 2011 18:23] by Moderator
Re: Eclipse suggest meaningless parameter name [message #727238 is a reply to message #727221] Tue, 20 September 2011 12:34 Go to previous messageGo to next message
On 20.09.2011 18:29, java_fan wrote:
> Hello,
> int endIndex) ?
Use a Java SDK which has the source compared to a JRE. Another solution
is to have the Javadoc installed locally. Eclipse can also fetch it from
the web but this can timeout for slow connections in which case you get
arg0, arg1, etc..
Dani
> Thanks.
Re: Eclipse suggest meaningless parameter name [message #727239 is a reply to message #727221] Tue, 20 September 2011 12:35 Go to previous messageGo to next message
Originally posted by: Rich Kulp
Is this happening on everything, or just on code that is coming from
Java, such as String.
If it is on stuff from Java then I assume you do not have the Java
source attached. It get's the names for arguments out of the source or
java doc and if it can't find them then it can only do arg0, arg1, etc.
Rich Kulp
Re: Eclipse suggest meaningless parameter name [message #727370 is a reply to message #727239] Wed, 21 September 2011 01:40 Go to previous messageGo to next message
You could also change the preference to use the best guessed names too -
Windows->Preferences->Java->Editor->Conent Assist, select 'Insert best guessed names'.
Re: Eclipse suggest meaningless parameter name [message #727615 is a reply to message #727370] Wed, 21 September 2011 12:25 Go to previous message
Thanks guys, I change the preferences and it works!
java collection
Previous Topic:show null array entries not working in 4.1
Next Topic:Java compiler suddenly very slow.
Current Time: Mon Mar 17 18:29:27 EDT 2025
Powered by FUDForum. Page generated in 0.03185 seconds
