Loop through parameters/SQL statements [message #726979] |
Tue, 20 September 2011 05:49 |
fixed-term.raimond.eisele Messages: 2 Registered: September 2011 |
Junior Member |
Good morning,
I'm having a problem with the following task:
My first report calculates some data based on a SQL database which contains timing tests.
The user enters the testid as report parameter which is used in the Data Set SQL statement to get/calculate the values.
Quote:SELECT *, st_mittelwert-st_min AS "st_diff_min_mw", st_max-st_mittelwert AS "st_diff_max_mw"
FROM (
SELECT st_device_groupnumber, MIN("st_waittime") AS "st_min", MAX("st_waittime") AS "st_max", AVG("st_waittime") AS "st_mittelwert", STDDEV("st_waittime") AS "st_stddev", MEDIAN("st_waittime") as "st_median"
FROM step
WHERE execution_id IN (
SELECT execution_id
FROM execution
WHERE testlauf_id = ? --<---------Parameter
AND st_device_text LIKE 'MP_SI%'
--ORDER BY st_device_nodenumber ASC, execution_id
GROUP BY st_device_groupnumber
ORDER BY st_device_groupnumber
AS "zwischentabelle"
This is working great.
But now I have to create an additional (chart)report which should contain an overview of 9 different tests. The IDs of the 9 tests should be entered by the user. So I'll get 9 different parameters. But how can I tell the SQL statement that it should use the first parameter for the first request, the second one for the second request......
I'm quiet sure that there is a simple solution, but I couldn't find it...
I'd be thankful for any hints/pointers.
Rai
[Updated on: Tue, 20 September 2011 05:52] Report message to a moderator
Re: Loop through parameters/SQL statements [message #727194 is a reply to message #726979] |
Tue, 20 September 2011 15:13 |
Rai,
The ? in the sql are order specific, so the first will be the first
parameter, second the second parameter etc. How will the user select
the 9 parameters? Multi-select List box? If you were hard coding the 9
test ids how would you write the query? The reason I ask this is there
may be a better way to simplify the number of parameters in the query
using some script.
Jason
On 9/20/2011 1:49 AM, fixed-term.raimond.eisele wrote:
> Good morning,
> Quote:
>> FROM (
>> "st_median"
>> FROM step
>> SELECT execution_id FROM execution
>> ) AND st_device_text LIKE 'MP_SI%'
> But now I have to create an additional report which should contain an
> Rai
FUDForum. Page generated in 0.03463 seconds
