(no subject) [message #726860 is a reply to message #726851] |
Mon, 19 September 2011 17:54 |
On 19-Sep-11 11:38, Art Held wrote:
> I suspect this is a VERY dumb new-user trick, however....
> I downloaded and installed the latest Eclipse for Java (32bit Indigo).
> I downloaded and installed the latest SDK (v7, 32bit).
> I successfully built and ran the basic "Hello World" tutorial.
> But when I try to follow the instructions for the SWT tutorial shown on
> the Tutorials Welcome page, titled "Create a Hello World SWT application"
> they do not work.
> The first step is:
> Open the Import wizard from the main menu via File > Import..., and
> select Plug-in Development > Plug-ins and Fragments. Click Next.
> However, there is no Plug-in Development menu item.
> I've tried:
> installing SWT separately, using the "Click to Perform" options,
> All fail.
> Sorry to take folks time with something so trivial, but any advice /
> suggestions on what basic step(s) I've missed? I'm stumped....
Which Eclipse package did you download? It may be one that doesn't have
support for plug-in development. I'm not certain which one has that; it
might be "Classic".
(no subject) [message #727206 is a reply to message #726860] |
Tue, 20 September 2011 15:42 |
Eric Rizzo Messages: 3070 Registered: July 2009 |
>> they do not work.
>> The first step is:
>> I've tried:
>> All fail.
> might be "Classic".
Either Eclipse Classic or "Eclipse for RCP and RAP Developers" would
work for SWT development.
You can also use Help > Install New Software... to install the PDE stuff
into your Eclipse. In the install dialog, select the Indigo repository
to work with, then find "Eclipse plug-in development environment" in the
list, select that, and install.
Eric
FUDForum. Page generated in 0.09016 seconds
