Home » Archived » XML Schema Definition (XSD) » WSDL Validator issue
WSDL Validator issue [message #77916] Mon, 29 June 2009 12:23 Go to next message
khaled sharief is currently offline khaled shariefFriend
As per WSDL 1.1 Spec its not valid to have extensibility elements in the
porttype element but when i place any extensibility element in porttype
e.g.
<jaxws:bindings>
<jaxws:class name="Service1"/>
</jaxws:bindings>
the validator doesn't report any problem. This is also the same in Altova
XML Spy.
Did i miss anything in the specification or will this be a bug in WSDL
validator and Altova XML Spy validator.
Reference - http://www.w3.org/TR/wsdl#A3
Khaled Sharief
Re: WSDL Validator issue [message #77935 is a reply to message #77916] Mon, 29 June 2009 12:41 Go to previous messageGo to next message
Khaled,
This is the XSD newsgroup, not a WSDL newsgroup. It's best to ask on
the Web Tools newsgroup, which I've added to the "to" list of the reply,
so no need to repost. You might want to clarify which version of WTP
you're using.
khaled sharief wrote:
> the porttype element but when i place any extensibility element in
> porttype
> e.g.
> <jaxws:bindings>
> </jaxws:bindings>
> Altova XML Spy.
> Regards,
> Khaled Sharief
Ed Merks
Re: WSDL Validator issue [message #77952 is a reply to message #77935] Tue, 30 June 2009 05:29 Go to previous messageGo to next message
Hi Ed,
This is the version of WTP that I'm using.
Version: 3.0.3.v200809250443
Thanks & Regards,
Mohammad Khaled Sharief
Re: WSDL Validator issue [message #77969 is a reply to message #77952] Tue, 30 June 2009 15:24 Go to previous message
Originally posted by: valentinbaciu.hotmail.com
Hi Khaled, the WTP WSDL tools, the validator included, conform to the WSDL
schema provided by the WS-I Basic Profile 1.1. See the last paragraph here
http://www.ws-i.org/Profiles/BasicProfile-1.1-2004-08-24.htm l#WSDL_Extensions.
As you've pointed out, some of the WS* specifications require extensibility
elements in places not supported by the original WSDL 1.1 W3C note. The
underlying Java object models used to manipulate WSDL (JWSDL/WSDL4J and the
WTP WSDL EMF model) have also evolved to allow extensibility elements for
all WSDL elements.
I hope this helps.
Regards, Valentin
"khaled sharief" <khaledsharief@gmail.com> wrote in message
news:b1ef36f70688811ff5686162e3ab8b0b$1@www.eclipse.org...
> Hi Ed,
> Thanks & Regards,
Re: WSDL Validator issue [message #604250 is a reply to message #77916] Mon, 29 June 2009 12:41 Go to previous message
Khaled,
you're using.
> porttype
> e.g.
> <jaxws:bindings>
> </jaxws:bindings>
> Altova XML Spy.
> Regards,
> Khaled Sharief
Ed Merks
Re: WSDL Validator issue [message #604255 is a reply to message #77935] Tue, 30 June 2009 05:29 Go to previous message
Hi Ed,
Thanks & Regards,
Re: WSDL Validator issue [message #604260 is a reply to message #77952] Tue, 30 June 2009 15:24 Go to previous message
Valentin is currently offline ValentinFriend
Member
all WSDL elements.
I hope this helps.
Regards, Valentin
> Hi Ed,
> Thanks & Regards,
Previous Topic:WSDL Validator issue
Next Topic:How to copy XSDSchema object
Current Time: Tue Apr 16 15:00:01 GMT 2024
Powered by FUDForum. Page generated in 0.55716 seconds
