Selection Job titile error [message #77870] |
Wed, 06 August 2008 22:36 |
Originally posted by: jcd.cals.arizona.edu
Hi All,
I just installed eclipse Version: 3.4.0 Build id: I20080617-2000 and the
latest stable PDT on Ubuntu 8.x.
I'm getting this error.
An internal error occurred during: "Selection Job titile".
org.eclipse.dltk.core.SourceParserUtil.getModuleDeclaration( Lorg/eclipse/dltk/core/ISourceModule;)Lorg/eclipse/dltk/ast/ declarations/ModuleDeclaration;
I created a script to run sudo, and poked around The Internets quite a bit
but didn't find any solutions to this problem save one that had to do with
nightly builds.
Thoughts?
Sincerely,
John Dale
Application Systems Analyst
The Water Resources Center
The University of Arizona
Tucson, Arizona
jcd@cals.arizona.edu
Re: Selection Job titile error [message #77887 is a reply to message #77870] |
Thu, 07 August 2008 09:57 |
Originally posted by: mark.howellsfamily.org.uk
John Dale wrote:
> Hi All,
See the wiki. http://wiki.eclipse.org/PDT/Installation#Known_Problems
Cheers
Mark
Re: Selection Job titile error [message #77902 is a reply to message #77887] |
Thu, 07 August 2008 18:19 |
Originally posted by: matthew.leonhardt.gmail.com
Hello, I am having the same problem. Followed the directions on the wiki,
but still get the error popups.
PDT Feature 2.0.0.v20080722
DLTK 0.95.0.v20080611
Any suggestions?
Matt
Re: Selection Job titile error [message #81886 is a reply to message #77914] |
Tue, 14 October 2008 08:41 |
Originally posted by: dafish.soundtrack-board.de
Shawn Clark schrieb:
> Matt,
> I have noticed that the DLTK is being updated fairly actively along with
> the PDT. It would be best if you are getting the I or N builds of it to
> also get the I builds of DLTK.
> Not sure if that will fix your problem but it is a good start.
> Shawn Clark
>> wiki, but still get the error popups.
>> Any suggestions?
>> Matt
I tried to install the latest DLTK integration build but when it is
about to be installed, I get several of the following error messages:
Cannot find a solution where both Match[requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.swt/[3.4.1.v3449c,3.4. 1.v3449c]]
and Match[requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.swt/[3.4.0.v3448f,3.4. 0.v3448f]]
can be satisfied.
I'd be happy about suggestions, too.
-Marcus
FUDForum. Page generated in 0.03360 seconds
