Home » Eclipse Projects » SWTBot » Three identical tests, first one fails on Mac OS X
Re: Three identical tests, first one fails on Mac OS X [message #726180 is a reply to message #726145] |
Fri, 16 September 2011 17:33 |
Bernhard Pieber Messages: 11 Registered: July 2009 |
Am 16.09.11 18:28, schrieb Bernhard Pieber:
> Thanks for your answer! We added the shell activation to our tests (see
> below). However, the behavior is unchanged. The first test fails, but
> the other two succeed.
I just saw that the failure is a different one, though. This time I got:
org.eclipse.swtbot.swt.finder.widgets.TimeoutException: Timeout after:
5000 ms.: Timed out waiting for Shell {Test} to get activated
Before we got:
com.softwaregeneration.learning.SWTBotFinderTest
testFindButton1(com.softwaregeneration.learning.SWTBotFinderTest)
org.eclipse.swtbot.swt.finder.exceptions.WidgetNotFoundException: Could
not find widget.
We wanted to get the simplest possible test to work from the SWTBot
class comment:
SWTBot bot = new SWTBot();
bot.button("hello world").click();
Our original test class looks like this:
package com.softwaregeneration.learning;
import org.eclipse.swt.SWT;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swtbot.swt.finder.SWTBot;
import org.junit.Test;
public class SWTBotTest {
@Test
public void testClickButton() throws Exception {
Display display = new Display();
Shell shell = new Shell(display);
shell.setText("Test");
shell.setSize(200, 150);
Button button = new Button(shell, SWT.PUSH);
button.setText("hello world");
shell.open();
bot.shell("Test").activate();
However, we get
Without the activate we get:
not find widget.
Thanks for your support!
Bernhard
Re: Three identical tests, first one fails on Mac OS X [message #727016 is a reply to message #726180] |
Tue, 20 September 2011 07:41 |
Can any Mac user reproduce this behavior, or am I the only one who
experiences this?
Thanks for your support.
Bernhard
Am 16.09.11 19:33, schrieb Bernhard Pieber:
> Before we got:
> not find widget.
> class comment:
> import org.eclipse.swt.widgets.Display;
> @Test
> shell.open();
> However, we get
> not find widget.
> Cheers,
> Bernhard
Re: Three identical tests, first one fails on Mac OS X [message #727227 is a reply to message #726145] |
Tue, 20 September 2011 16:20 |
Ketan Padegaonkar Messages: 873 Registered: July 2009 |
> Do you have any idea why?
I think I may know why.
SWTBot requires that the tests run on a non-ui thread. Which means that
your tests must run on a thread different from the thread that starts
the app.
However in the case of your snippet, your test app and swtbot run on the
same thread, which is why you're seeing these weird errors.
Unfortunately in case of cocoa, the UI thread must start on the main
thread, implying that the tests should run on a non-main thread.
Unfortunately this has the side-effect that plain swt apps cannot be
tested with swtbot on a mac.
I was in the middle of fixing this issue, but it's been a while since
anyone mentioned swt and cocoa :) So here's what you'd need to do:
Copy the class BaseSWTTest
(https://github.com/ketan/SWTBot/commit/dadb1782247f0d169a6717f6819cfccc5cd4861a#diff-23)
and all required dependencies to make the class compile
(UIThreadTestRunner, UIThread)
You'll eventually need to subclass BaseSWTTest and run your tests using
"run as > junit tests"
Hope that helps.
-- Ketan
Re: Three identical tests, first one fails on Mac OS X [message #731317 is a reply to message #727227] |
Fri, 30 September 2011 15:48 |
Hi Ketan,
Thank you very much for your answer. I just wanted to let you know that
I did not ignore it. I just did not have time to try your suggestion
yet. As soon as I have tried I will give you feedback.
Could I also just use your fork, or wouldn't it work for some reason?
Bernhard
Am 20.09.11 18:20, schrieb Ketan Padegaonkar:
> the app.
> Hope that helps.
> -- Ketan
Re: Three identical tests, first one fails on Mac OS X [message #732028 is a reply to message #731317] |
Mon, 03 October 2011 18:07 |
I've recently merged this into trunk, so this should be a bit simpler.
You may use the artifacts generated by the build machine at
https://hudson.eclipse.org/hudson/view/SWTBot/job/swtbot-e36/lastSuccessfulBuild/artifact/org.eclipse.swtbot.releng/artifacts/
and let me know if this version works for you.
To write your SWTBot tests, checkout this example I put together for you
https://gist.github.com/18f4760c92da2a7c0767. If this works for you, let
me know and I'll document it properly.
-- Ketan
On 9/30/11 8:48 AM, Bernhard Pieber wrote:
> Hi Ketan,
> Cheers,
> Bernhard
>> the app.
>> Hope that helps.
>> -- Ketan
Re: Three identical tests, first one fails on Mac OS X [message #732340 is a reply to message #732028] |
Tue, 04 October 2011 13:45 |
Hi Ketan,
Thank you for your answer. We tried to follow your advice. However, we
were unsure which of the artifacts to use. We added the following jars
to the classpath:
org.eclipse.swtbot.junit4_x_2.0.5.20111003_1754-3676ac8-dev-e36.jar
org.eclipse.swtbot.swt.finder_2.0.5.20111003_1754-3676ac8-dev-e36.jar
org.apache.log4j_1.2.13.v200903072027.jar
When we tried out your example from
https://gist.github.com/18f4760c92da2a7c0767, we miss the class
RunUIThreadRule and the annotation UIThread.
Which jar or jars are we missing?
How do we set up your example correctly?
Bernhard & Görge
Am 03.10.11 20:07, schrieb Ketan Padegaonkar:
> -- Ketan
>> Hi Ketan,
>> Cheers,
>> Bernhard
>>> the app.
>>> Hope that helps.
>>> -- Ketan
Re: Three identical tests, first one fails on Mac OS X [message #733543 is a reply to message #732340] |
Wed, 05 October 2011 01:49 |
I'd suggest downloading(https://github.com/ketan/SWTBot/downloads) the
source code and looking at the existing swtbot tests in the
swt.finder.tests plugin. Pick a simple SWTBotButtonTest and find your
way to the superclass and copy over the classes needed.
Hope that helps.
-- Ketan
On 10/4/11 6:45 AM, Bernhard Pieber wrote:
> Hi Ketan,
> to the classpath:
> Cheers,
> Bernhard & Görge
>> -- Ketan
>>> Hi Ketan,
>>> Cheers,
>>> Bernhard
>>>>> (see
>>>> the app.
>>>> the
>>>> Hope that helps.
>>>> -- Ketan
Re: Three identical tests, first one fails on Mac OS X [message #733544 is a reply to message #732340] |
Hope that helps.
-- Ketan
> Hi Ketan,
> to the classpath:
> Cheers,
> Bernhard & Görge
>> -- Ketan
>>> Hi Ketan,
>>> Cheers,
>>> Bernhard
>>>>> (see
>>>> the app.
>>>> the
>>>> Hope that helps.
>>>> -- Ketan
Current Time: Thu Apr 25 14:08:05 GMT 2024
Powered by FUDForum. Page generated in 0.03325 seconds
