Home » Eclipse Projects » EGit / JGit » Updating to latest Egit from N-build
Updating to latest Egit from N-build [message #725748] Thu, 15 September 2011 16:34 Go to next message
Olivier Thomann is currently offline Olivier ThomannFriend
Am I the only that cannot properly install egit from the nightly build p2 repo ?
When I try to install it, it finds a new version. But when I try to install it, I am getting:
An error occurred while collecting items to be installed
session context was:(profile=SDKProfile, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
Multiple problems occurred while downloading.
Artifact not found: http://download.eclipse.org/egit/updates-nightly/plugins/org.eclipse.egit_1.1.0.201109141926.jar.pack.gz.
Artifact not found: http://download.eclipse.org/egit/updates-nightly/plugins/org.eclipse.egit.core_1.1.0.201109141926.jar.pack.gz.
Artifact not found: http://download.eclipse.org/egit/updates-nightly/plugins/org.eclipse.egit.doc_1.1.0.201109141926.jar.pack.gz.
Artifact not found: http://download.eclipse.org/egit/updates-nightly/features/org.eclipse.egit_1.1.0.201109141926.jar.pack.gz.
Artifact not found: http://download.eclipse.org/egit/updates-nightly/features/org.eclipse.egit.psf_1.1.0.201109141926.jar.pack.gz.
Artifact not found: http://download.eclipse.org/egit/updates-nightly/plugins/org.eclipse.egit.ui_1.1.0.201109141926.jar.pack.gz.
Would someone have any idea what it is going on ?
Thanks.
Olivier
Re: Updating to latest Egit from N-build [message #725766 is a reply to message #725748] Thu, 15 September 2011 17:53 Go to previous messageGo to next message
Manuel Doninger is currently offline Manuel DoningerFriend
The last nightly builds failed, so there are no artifacts with timestamp from 14th. Somehow the metadata got updated anyway. You can try the update site directly created by Hudson. The url is https://hudson.eclipse.org/hudson/job/egit/lastSuccessfulBuild/artifact/org.eclipse.egit-updatesite/target/site/
Re: Updating to latest Egit from N-build [message #725956 is a reply to message #725766] Fri, 16 September 2011 09:27 Go to previous messageGo to next message
Matthias Sohn is currently offline Matthias SohnFriend
Try again, I cleaned up the download folder and did another build
Re: Updating to latest Egit from N-build [message #726042 is a reply to message #725956] Fri, 16 September 2011 13:16 Go to previous message
It seems to work now, but the contents is unsigned. Thanks for the fix.
Previous Topic:Check Home Directory warning message
Next Topic:JGIT, HTTPS and client certificates
Current Time: Sun Jul 25 16:31:36 GMT 2021
Powered by FUDForum. Page generated in 0.02443 seconds
