Emfatic text from Ecore [message #725696] |
Thu, 15 September 2011 10:31  |
I would like to generate Emfatic(the text displayed by OCLinEcore Editor) text from Ecore file in standalone application for view.
Any suggesions?
Re: Emfatic text from Ecore [message #727471 is a reply to message #727467] |
Wed, 21 September 2011 07:58   |
public static void main(String args[]) {
URI uri1 = URI.createFileURI("C:\\Users\\KhurramS\\Desktop\\ulrik\\test3.ecore");
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("ecore", new EcoreResourceFactoryImpl());
Resource resource = resourceSet.getResource(uri1, true);
try {
OCLinEcoreStandaloneSetup.doSetup();
OCLinEcoreDocumentCS document = Ecore2OCLinEcore.importFromEcore(resourceSet, "alias", resource);
Resource r2 = resourceSet.createResource(uri1.trimFileExtension().appendFileExtension("oclinecore"), OCLinEcoreCSTPackage.eCONTENT_TYPE);
r2.getContents().add(document);
r2.save(null);
} catch (IOException ex) {
Exceptions.printStackTrace(ex);
i get exception : OCLinEcoreDocumentCS document = Ecore2OCLinEcore.importFromEcore(resourceSet, "alias", resource);
Exception in thread "main" org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature 'xmi' not found. (file:/C:/Users/KhurramS/Desktop/ulrik/test3.ecore, 5, 80)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:315)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:397)
Attachment: test3.ecore
(Size: 1.40KB, Downloaded 266 times)
[Updated on: Wed, 21 September 2011 07:59] by Moderator
Re: Emfatic text from Ecore [message #727490 is a reply to message #727480] |
Wed, 21 September 2011 08:43   |
hi,
I have checked my class path but i am still getting following exception from your main method, Do you have any idea why is this happening?
Exception in thread "main" com.google.inject.ProvisionException: Guice provision errors:
1) Error injecting method, org.eclipse.emf.common.util.WrappedException: org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'EClassifier' is not found or is abstract. (classpath:/org/eclipse/ocl/examples/xtext/oclinecore/OCLinEcore.xmi, 18, 123)
at org.eclipse.xtext.conversion.impl.AbstractDeclarativeValueConverterService.setGrammar(AbstractDeclarativeValueConverterService.java:50)
while locating org.eclipse.ocl.examples.xtext.oclinecore.services.OCLinEcoreValueConverterService
while locating org.eclipse.xtext.conversion.IValueConverterService
for field at org.eclipse.xtext.linking.impl.LinkingHelper.valueConverter(LinkingHelper.java:25)
while locating org.eclipse.xtext.linking.impl.LinkingHelper
for field at org.eclipse.xtext.parsetree.reconstr.impl.CrossReferenceSerializer.linkingHelper(CrossReferenceSerializer.java:33)
while locating org.eclipse.ocl.examples.xtext.oclinecore.services.OCLinEcoreCrossReferenceSerializer
while locating org.eclipse.xtext.parsetree.reconstr.ITokenSerializer$ICrossReferenceSerializer
for field at org.eclipse.xtext.parsetree.reconstr.impl.AbstractParseTreeConstructor.crossRefSerializer(AbstractParseTreeConstructor.java:58)
while locating org.eclipse.ocl.examples.xtext.oclinecore.parseTreeConstruction.OCLinEcoreParsetreeConstructor
while locating org.eclipse.xtext.parsetree.reconstr.IParseTreeConstructor
for parameter 0 at org.eclipse.xtext.parsetree.reconstr.Serializer.<init>(Serializer.java:38)
while locating org.eclipse.xtext.parsetree.reconstr.Serializer
for field at org.eclipse.xtext.resource.XtextResource.serializer(XtextResource.java:349)
while locating org.eclipse.xtext.linking.lazy.LazyLinkingResource
while locating org.eclipse.xtext.resource.XtextResource
Caused by: org.eclipse.emf.common.util.WrappedException: org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'EClassifier' is not found or is abstract. (classpath:/org/eclipse/ocl/examples/xtext/oclinecore/OCLinEcore.xmi, 18, 123)
at org.eclipse.xtext.parser.BaseEPackageAccess.loadResource(BaseEPackageAccess.java:57)
at org.eclipse.xtext.parser.BaseEPackageAccess.loadGrammarFile(BaseEPackageAccess.java:44)
at org.eclipse.xtext.service.GrammarProvider.getGrammar(GrammarProvider.java:49)
at org.eclipse.ocl.examples.xtext.oclinecore.services.OCLinEcoreGrammarAccess.getGrammar(OCLinEcoreGrammarAccess.java:3525)
at $org.eclipse.xtext.conversion.impl.AbstractDeclarativeValueConverterService$$FastClassByGuice$$7fdb40ee.invoke(<generated>)
at com.google.inject.internal.cglib.reflect.FastMethod.invoke(FastMethod.java:53)
at com.google.inject.SingleMethodInjector$1.invoke(SingleMethodInjector.java:59)
at com.google.inject.SingleMethodInjector.inject(SingleMethodInjector.java:91)
at com.google.inject.MembersInjectorImpl.injectMembers(MembersInjectorImpl.java:99)
at com.google.inject.ConstructorInjector.construct(ConstructorInjector.java:94)
at com.google.inject.ConstructorBindingImpl$Factory.get(ConstructorBindingImpl.java:111)
at com.google.inject.FactoryProxy.get(FactoryProxy.java:56)
at com.google.inject.SingleFieldInjector.inject(SingleFieldInjector.java:56)
at com.google.inject.SingleParameterInjector.inject(SingleParameterInjector.java:42)
at com.google.inject.SingleParameterInjector.getAll(SingleParameterInjector.java:66)
at com.google.inject.ConstructorInjector.construct(ConstructorInjector.java:84)
at com.google.inject.InjectorImpl$4$1.call(InjectorImpl.java:758)
at com.google.inject.InjectorImpl.callInContext(InjectorImpl.java:804)
at com.google.inject.InjectorImpl$4.get(InjectorImpl.java:754)
at org.eclipse.xtext.resource.XtextResourceFactory.createResource(XtextResourceFactory.java:19)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.createResource(ResourceSetImpl.java:425)
at org.eclipse.ocl.examples.xtext.oclinecore.resource.Ecore2OCLinEcore.importResource(Ecore2OCLinEcore.java:822)
at org.eclipse.ocl.examples.xtext.oclinecore.resource.Ecore2OCLinEcore.getDocument(Ecore2OCLinEcore.java:815)
at org.eclipse.ocl.examples.xtext.oclinecore.resource.Ecore2OCLinEcore.importFromEcore(Ecore2OCLinEcore.java:119)
at abstractmodeller.model.prm.ECoreGenerator.main(ECoreGenerator.java:921)
Caused by: org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'EClassifier' is not found or is abstract. (classpath:/org/eclipse/ocl/examples/xtext/oclinecore/OCLinEcore.xmi, 18, 123)
at org.eclipse.xtext.resource.SynchronizedXtextResourceSet.getResource(SynchronizedXtextResourceSet.java:23)
at org.eclipse.xtext.parser.BaseEPackageAccess.loadResource(BaseEPackageAccess.java:52)
... 44 more
Caused by: org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'EClassifier' is not found or is abstract. (classpath:/org/eclipse/ocl/examples/xtext/oclinecore/OCLinEcore.xmi, 18, 123)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.validateCreateObjectFromFactory(XMLHandler.java:2244)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.validateCreateObjectFromFactory(XMLHandler.java:2368)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFeatureType(XMLHandler.java:2163)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObject(XMLHandler.java:2035)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.createObject(XMIHandler.java:134)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLHandler.java:1840)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XMLHandler.java:1023)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMIHandler.java:87)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:1001)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:712)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHandler.java:169)
at org.apache.xerces.parsers.AbstractSAXParser.startElement(Unknown Source)
at org.apache.xerces.parsers.AbstractXMLDocumentParser.emptyElement(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanStartElement(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:395)
Re: OCLinEcore text from Ecore (was Emfatic text from Ecore) [message #727508 is a reply to message #727497] |
Wed, 21 September 2011 09:23  |
Ah; the critical detail. NetBeans.
It's probably an OSGI problem. I don't understand the OSGI magic that
underlies Eclipse 3.x, but it works and sorts out classpaths. Quite
probably NetBeans is different, either at the platform level or at the
Guice integration level. I doubt that you will find many Eclipse users
who are familiar with NetBeans. Try the NetBeans user groups.
Ed Willink
On 21/09/2011 14:12, ModelGeek wrote:
> I forgot to tell i am working in Netbeans. But when i run the main
> method in eclipse environment then there is no error and every thing
> works fine, but when i run Netbeans then the ealier mentioned
> exception comes.
> Any hint why it is happening?
> I will be very greatful for your help!
Re: OCLinEcore text from Ecore (was Emfatic text from Ecore) [message #727510 is a reply to message #727490] |
Wed, 21 September 2011 09:14  |
Christian has provided you with a 100% working Java file, that should be
easy to wrap up into a plugin project. Are you using precisely
Christian's code? If not, try doing so. If so, ZIP your entire project
so that we can see what strange things you have managed to do.
Ed Willink
On 21/09/2011 13:43, ModelGeek wrote:
> hi,
> happening?
Re: OCLinEcore text from Ecore (was Emfatic text from Ecore) [message #727511 is a reply to message #727497] |
Ed Willink
> exception comes.
