Tomcat failed to start [message #725428] |
Wed, 14 September 2011 18:30 |
chandrurajendran.1217 Messages: 1 Registered: September 2011 |
Please help me,
when i changed the versions of tomcat in my eclipse the problem started, it's been already two that the tomcat error ruined my work, i have tried everything but my eclipse says the tomcat failed to start, after many fine tunes now it shows this error msg,
"Server Tomcat v7.0 Server at localhost was unable to start within 45 seconds. If the server requires more time, try increasing the timeout in the server editor."
even after increasing start time the same error returns, my console says,
14 Sep, 2011 11:55:30 PM org.apache.catalina.core.AprLifecycleListener init
INFO: Loaded APR based Apache Tomcat Native library 1.1.22.
INFO: APR capabilities: IPv6 [false], sendfile [true], accept filters [false], random [true].
14 Sep, 2011 11:55:30 PM org.apache.tomcat.util.digester.SetPropertiesRule begin
WARNING: [SetPropertiesRule]{Server/Service/Engine/Host/Context} Setting property 'source' to 'org.eclipse.jst.jee.server:jsep' did not find a matching property.
14 Sep, 2011 11:55:31 PM org.apache.coyote.AbstractProtocol init
INFO: Initializing ProtocolHandler ["http-apr-8080"]
INFO: Initializing ProtocolHandler ["ajp-apr-8009"]
14 Sep, 2011 11:55:31 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 1163 ms
14 Sep, 2011 11:55:31 PM org.apache.catalina.core.StandardService startInternal
INFO: Starting service Catalina
14 Sep, 2011 11:55:31 PM org.apache.catalina.core.StandardEngine startInternal
INFO: Starting Servlet Engine: Apache Tomcat/7.0.21
14 Sep, 2011 11:55:31 PM org.apache.catalina.startup.Catalina start
SEVERE: Catalina.start:
org.apache.catalina.LifecycleException: Failed to start component [StandardServer[8005]]
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:152)
at org.apache.catalina.startup.Catalina.start(Catalina.java:621)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:322)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:450)
Caused by: org.apache.catalina.LifecycleException: Failed to start component [StandardService[Catalina]]
at org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:727)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:148)
... 7 more
Caused by: org.apache.catalina.LifecycleException: Failed to start component [StandardEngine[Catalina]]
at org.apache.catalina.core.StandardService.startInternal(StandardService.java:443)
... 9 more
Caused by: org.apache.catalina.LifecycleException: Failed to start component [StandardEngine[Catalina].StandardHost[localhost]]
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:1033)
at org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:291)
... 11 more
Caused by: org.apache.catalina.LifecycleException: Failed to start component [StandardEngine[Catalina].StandardHost[localhost].StandardContext[]]
at org.apache.catalina.core.StandardHost.startInternal(StandardHost.java:774)
... 14 more
Caused by: java.lang.NoSuchMethodError: javax.servlet.ServletContext.getSessionCookieConfig()Ljavax/servlet/SessionCookieConfig;
at org.apache.catalina.deploy.WebXml.configureContext(WebXml.java:1308)
at org.apache.catalina.startup.ContextConfig.webConfig(ContextConfig.java:1390)
at org.apache.catalina.startup.ContextConfig.configureStart(ContextConfig.java:896)
at org.apache.catalina.startup.ContextConfig.lifecycleEvent(ContextConfig.java:322)
at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:119)
at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:90)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5103)
... 17 more
INFO: Server startup in 216 ms
what could be wrong, what i can do start the tomcat, somebody please help me..!!!
Re: Tomcat failed to start [message #725478 is a reply to message #725428] |
Wed, 14 September 2011 21:32 |
On 14-Sep-11 12:30, chandrurajendran.1217 wrote:
> Please help me,
> [snip]
> help me..!!!
This is a question for the Eclipse web tools forum. In the meantime, you
should look at http://wiki.eclipse.org/WTP_Tomcat_FAQ
FUDForum. Page generated in 0.07969 seconds
