Re: [Announce] Extended Model Browser [message #679 is a reply to message #669] |
Wed, 04 March 2009 14:24 |
Dimitrios Kolovos Messages: 1776 Registered: July 2009 |
Hi Gabriel,
Thanks for the examples! Can you speculate on the timeframe in which
these enhancements would be implemented? If it's not among your
immediate priorities to implement them soon - and this would be
understandable :) - I can have a go at it and then submit a patch.
Dimitris
Gabriel wrote:
> Hello Dimitris,
> I think that we could manage a generic nsURI ("*" is a good example).
> And yes, you will have to implements NameProvider and/or IconProvider to
> associate an EObject to a label and/or icon.
> That's all !
> Here is examples for j2se5 and C# metamodels (it will be submitted soon)
> It is the plugin sources, I hope it will give you a lot of ideas :-)
> best regards,
> Gabriel
>>>>>>> Hi Gabriel,
> Looks great! Thanks for sharing this.
> In fact I'd like to provide an extension to contribute custom names and
> icons to EObjects based on particular annotations in the respective
> EClasses (as per http://www.eclipse.org/gmt/epsilon/doc/Exeed.pdf). To
> do this, I would like to be able to specify my extensions not for a
> particular nsURI but for any nsURI.
> In the current version, this is doesn't seem to be possible as each
> extension needs to define a specific nsURI (id). I was wondering if a
> future version of the editor could also provide support for a generic
> nsURI (e.g. "*") which I could use to define that my extension applies
> to any nsURI. In this case I suspect that the NameProvider and
> IconProvider interfaces might need to be enhanced to also support a
> providesName(EObject) and providesIcon(EObject) method respectively to
> allow such extensions specify exactly which EObjects they can provide
> names and icons for.
> Any thoughts on this?
> Cheers,
> Dimitris
Re: [Announce] Extended Model Browser [message #572838 is a reply to message #669] |
Hi Gabriel,
Dimitris
Gabriel wrote:
> Hello Dimitris,
> That's all !
> best regards,
> Gabriel
>>>>>>> Hi Gabriel,
> Cheers,
> Dimitris
FUDForum. Page generated in 0.05220 seconds
