Home » Language IDEs » PHP Development Tools (PDT) » Can't install by Update - wst.web_ui dependency
Can't install by Update - wst.web_ui dependency [message #77650] Sat, 02 August 2008 21:23 Go to next message
Poletto Guillaume is currently offline Poletto GuillaumeFriend
I tried during some hours to find PDT dependencies to install it
through Software Update tool.
Now, i think the needed package is already installed but for some
reason, it doesn't "satisfy the requirements"
"Cannot complete the request. See the details.
Cannot find a solution satisfying the following requirements
Match[requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.wst.web_ui.feature.fea ture.group/[3.0.0.v200806110525-7R0ELQE8Krvy5z-NjIludKQn86QP ,3.0.0.v200806110525-7R0ELQE8Krvy5z-NjIludKQn86QP]]. "
I installed all the packages provided by the "Web Tools Project" update
site, and the "WST Web UI" package seems to have been included.
Maybe, it's an x86_64 issue (my system is amd64 and so is the jre and
the base eclipse).
The base eclipse installation was a CDT bundle, but i also tried with
the J2EE pack, same problem.
I tried the PDT bundle but i couldn't launch it (perhaps it's only
designed for x86)
Re: Can't install by Update - wst.web_ui dependency [message #77682 is a reply to message #77650] Sun, 03 August 2008 06:23 Go to previous messageGo to next message
Originally posted by: codeslave.ca.ibm.com
Try this:
http://wiki.eclipse.org/PDT/Installation#Eclipse_3.4_.2F_Gan ymede_.2F_PDT_2.0
And note this:
http://wiki.eclipse.org/PDT/Installation#Known_Problems
I tried it last night and it worked fine... with
eclipse-jee-ganymede-linux-gtk.tar.gz, Sun JDK 5, Linux x86 32-bit,
kernel 2.6.22.
There's nothing in PDT that should be OS-specific, but you must use the
OS-specific platform (Eclipse "Classic" or "Ganymede JEE bundle" for
64-bit). Or use the 32-bit one with a 32-bit JVM.
See also:
http://ubuntuforums.org/archive/index.php/t-320899.html
http://www.google.com/search?ie=UTF-8&oe=UTF-8&sourc eid=navclient&gfns=1&q=eclipse+amd_64
And if your system has more than one JVM installed (eg., 32- and 64-bit
versions), you'll want to launch Eclipse like this:
../eclipse -vm /path/to/the/right/bin/java
http://wiki.eclipse.org/IRC_FAQ#How_do_I_start_Eclipse.3F
Good luck!
Guillaume Poletto wrote:
> Hello,
> the base eclipse).
> designed for x86)
> Thanks
Nick Boldt :: Release Engineer, IBM Toronto Lab
Eclipse Modeling :: http://www.eclipse.org/modeling
http://wiki.eclipse.org/index.php/User:Nickb
Re: Can't install by Update - wst.web_ui dependency [message #77699 is a reply to message #77682] Sun, 03 August 2008 10:24 Go to previous message
It worked with this
http://wiki.eclipse.org/PDT/Installation#Eclipse_3.4_.2F_Gan ymede_.2F_PDT_2..0 !
Thanks!
G.
Le Sun, 03 Aug 2008 02:23:46 -0400,
Nick Boldt <codeslave@ca.ibm.com> a écrit :
> Try this:
> And note this:
> kernel 2.6.22.
> the OS-specific platform (Eclipse "Classic" or "Ganymede JEE bundle"
> for 64-bit). Or use the 32-bit one with a 32-bit JVM.
> See also:
> 64-bit versions), you'll want to launch Eclipse like this:
> Good luck!
> > Hello,
> > update site, and the "WST Web UI" package seems to have been
> > included.
> > and the base eclipse).
> > with the J2EE pack, same problem.
> > designed for x86)
> > Thanks
Previous Topic:Auto-Complete takes too long
Next Topic:PHP items on "Run as..." menu still visible in Java and other perspectives
Current Time: Sun Apr 21 20:32:03 GMT 2024
Powered by FUDForum. Page generated in 0.03910 seconds
