Re: BIRT Report Export to Office 2002 [message #724561 is a reply to message #724523] |
Mon, 12 September 2011 14:27 |
If a new emitter is required the plugin that implements it will have to
be added to the current BIRT runtime, but if the application is like the
viewer this is a simple copy that does not require that the system be
restarted.
Jason
On 9/12/2011 10:20 AM, LBck wrote:
> We are using a third party CRM System. I have written a BIRT report
> (using v2.5.2) for this system. With this CRM system I have only an
> ability to upload the rpt.design into the system. I have completely no
> idea about the Emitter behind the scence.
> I have tested my BIRT report at home. It does work absolutely fine with
> WORD 2003 or newer. Unfortunately in our company we are still using WORD
> 2002. And of course, when I tried to export my report on the computer
> with WORD 2002, it failed.
> I understand that BIRT exporter uses XML format which is only available
> from WORD 2003.
> In this case, are there anything I could do with my BIRT report to
> resolve this problem?
> I have read the post message #msg_704132 in this forum. In this message,
> an open-source emitter was mentioned. Am I right to say, that if a new
> emitter is required, this emitter should be intergrated with the CRM
> System which BIRT report runs?
> Thanks much in advance.
> Lien
FUDForum. Page generated in 0.03726 seconds
