Home » Eclipse Projects » EGit / JGit » Symbolic links in Linux(Symbolic links should be ignored by Egit)
icon8.gif  Symbolic links in Linux [message #724106] Sat, 10 September 2011 19:48 Go to next message
Loknath Bharti is currently offline Loknath BhartiFriend
I have some symbolic links in my source and the git console has no problems. Whenever I try to commit or switch using EGit, it wants me to commit the symbolic link files which never completes because those files are already committed in another folder.
Please add a feature to ignore symbolic links, so that Egit can be used in Linux with sources containing symbolic links.
[Updated on: Sat, 10 September 2011 19:49]
Report message to a moderator
Re: Symbolic links in Linux [message #724187 is a reply to message #724106] Sun, 11 September 2011 09:30 Go to previous messageGo to next message
Matthias Sohn is currently offline Matthias SohnFriend
You want https://bugs.eclipse.org/bugs/show_bug.cgi?id=354367
Re: Symbolic links in Linux [message #724232 is a reply to message #724187] Sun, 11 September 2011 16:36 Go to previous messageGo to next message
I don't think so, because that talks of adding support. I am talking about having same behavior as git terminal program does, which is able to understand that the files in the symbolic linked folder have already been committed, and ignores them.
Re: Symbolic links in Linux [message #724255 is a reply to message #724232] Sun, 11 September 2011 19:07 Go to previous message
Robin Rosenberg is currently offline Robin RosenbergFriend
Loknath Bharti skrev 2011-09-11 18.36:
The request in bugzilla, by implication should solve your problem. JGit
today does not understand symbolic links in any way. It sees folders and
files.
People are looking at implementing a plugin to to the work when EGit is
run with Java 7. Since most of our users, I believe, don't use symbolic
links for cross-platform reasons. Our repos must be usable in Windows
too), it is not a show stopper.
If you want something else, it is not clear from the description.
-- robin
Previous Topic:Error when commiting
Next Topic:Possible to unstage/reset a single file?
Current Time: Sun Jul 25 01:10:43 GMT 2021
Powered by FUDForum. Page generated in 0.07242 seconds
