Re: No targetnamespace set for local elements inside complextype [message #77519 is a reply to message #77496] |
Thu, 19 March 2009 12:17 |
Ed Merks Messages: 33113 Registered: July 2009 |
Bhuvan,
Comments below.
Bhuvan wrote:
> Hello,
> I have defined a complextype in an wsdl inside <types> section under
> schema, as below :
> test.wsdl
> <?xml version="1.0" encoding="UTF-8" standalone="no"?>
> <wsdl:definitions xmlns:soap="http://schemas.xmlsoap.org/wsdl/soap/"
> xmlns:tns="http://www.example.org/test/"
> xmlns:wsdl="http://schemas.xmlsoap.org/wsdl/"
> xmlns:xsd="http://www.w3.org/2001/XMLSchema" name="test"
> targetNamespace="http://www.example.org/test/">
> <wsdl:types>
> <xsd:schema targetNamespace="http://www.example.org/test/">
> <xsd:complexType name="ct1">
> <xsd:sequence>
> <xsd:element name="ele1" type="xsd:string"/>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> </wsdl:types>
> </wsdl:definitions>
> Now i am using below code snippet :
> String sourceLoc = "C:\\test.wsdl";
> File file1 = new File(sourceLoc);
> final ResourceSet resourceSet = new ResourceSetImpl();
> final Resource res1 =
> resourceSet.getResource(URI.createURI(file1.toURI().toString ()), true);
> WSDLResourceImpl wsdlr = (WSDLResourceImpl)res1;
> Definition definition = wsdlr.getDefinition();
> Types types = definition.getETypes();
> XSDSchema schema = (XSDSchema) types.getSchemas().get(0);
> XSDComplexTypeDefinition complexType = (XSDComplexTypeDefinition)
> schema.getTypeDefinitions().get(0);
> final XSDElementDeclaration element =
> (XSDElementDeclaration)((XSDModelGroup)((XSDParticle)complex Type.getContent()).getContent()).
> getContents().iterator().next().getContent();
> System.out.println(element.getName());
> System.out.println(element.getTargetNamespace());
> So now when i get the targetNamespace for ele1 which is defined in
> complex type "ct1" then it is returnd as "null", where as it should be
> "http://www.example.org/test/".
No, local element declarations by default have form="unqualified" and
the schema itself by default has elementFormDefault="unqualified" so
unless you take explicit action to set one of these two things to
"qualified" the element will be unqualified and hence will have null
target namespace.
> This case works fine when we have this schema defined in an XSD file
> and process it ??
It will work the same way or are you asserting otherwise?
> It seems there is something wrong in the "XSDSchema" which is returned
> by wsdl "Definition".
No, I think your expectations are incorrect.
> Thanks and best regards,
> Bhuvan Mehta
Ed Merks
Re: No targetnamespace set for local elements inside complextype [message #604133 is a reply to message #77496] |
Bhuvan,
Comments below.
Bhuvan wrote:
> Hello,
> schema, as below :
> test.wsdl
> <wsdl:types>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> </wsdl:types>
> </wsdl:definitions>
target namespace.
> and process it ??
> Bhuvan Mehta
Ed Merks
FUDForum. Page generated in 0.02890 seconds
